SAE to GM/FORD/CHRYSLER Bellhousing Adapter - TheDieselGarage.com
Go Back   TheDieselGarage.com > Diesel Conversion > Diesel Conversion
Thread Details Posted by ARAMP1, this thread has received 6 replies and been viewed 8015 times.
Old 11-08-2007, 06:24 AM   #1
ARAMP1
ARAMP1's Avatar
Anyone ever use this company? They make adapters for SAE bellhousings to Chevy/Ford/Chrysler transmissions. I'm thinking about buying an adapter to use a regular trans behind my Detroit Diesel. Right now, I currently have a Roadranger in the plans. With the adapter, I could use really any heavy duty truck manual transmission. Seems like it'd be less work and better driveablility. Thoughts?
Phoenix Casting and Machining Inc.
ARAMP1 is offline   Reply With Quote
Old 11-10-2007, 01:42 AM   #2
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
Never saw those before but thanks for the useful info!
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
Old 11-13-2007, 08:01 AM   #3
ARAMP1
ARAMP1's Avatar
No problems! I think I'm going to end up giving them a try with my detroit powered truck.
Old 12-21-2011, 09:39 PM   #4
Trojan117
So I realize that this thread is 4 years old but I was wondering how that adapter worked out for you? I am thinking about putting a 3-71 in a 72 4x4 shortbox but I really want to keep the SM465. I was just curious how that whole operation worked out for you.
Trojan117 is offline   Reply With Quote
Old 12-21-2011, 10:47 PM   #5
1964reo
i just sold one for a chevy the only touble you have to use two flywheel just remeber you 371 only runs 2100
i never used mine i paid 570.00 for mine and sold it for 400.00
i think you will need a overdrive cause of the gear in the 465 are not very good to wide between gears
1964reo is offline   Reply With Quote
Old 12-21-2011, 11:24 PM   #6
Trojan117
Yea I know that speed wont be its strong point. I was thinking more of 4.56 gears and make a rock crawler
Also I have been looking at some other detroits and do you know where I could get ahold of an SAE #1 to GM bellhousing?
Old 12-22-2011, 12:36 AM   #7
1964reo
they make sae numbe 2 3 4 to chevy only you can change you belhousing to a number 2 off from a 471 or 671 you just make shure you get the same belhousing with the blower is on the same side and you need the flywheel to
