Horn location - TheDieselGarage.com
Thread Details Posted by hhrecovery, this thread has received 7 replies and been viewed 4849 times.
Old 10-08-2005, 06:49 PM   #1
hhrecovery
MAFIA #8
hhrecovery's Avatar
Images: 1
Horn location
I am working on installing my horns and plan on adding a DPDT switch so I can use both horns with one switch. Where is the horn located or where is the easiest place to tap into my horn wires at. Thanks.
Aaron - 2004 F350 "Offroad Edition"
2003 F250 "Pulling Truck"
hhrecovery is offline   Reply With Quote
Old 10-08-2005, 06:58 PM   #2
PSDPlayer
Diesel Custom Tuner
Easiest place to tap into the horns is at the horn itself. The black wire going to the horns is the power and they are body grounded.
PSDPlayer is offline   Reply With Quote
Old 10-08-2005, 07:03 PM   #3
hhrecovery
MAFIA #8
hhrecovery's Avatar
Images: 1
where is the horn located on the truck at though?
Old 10-08-2005, 07:29 PM   #4
PSDPlayer
Diesel Custom Tuner
Coonector is located behind bumper on passenger side of truck.
Old 08-30-2010, 07:23 PM   #5
derbin
I have looked at all the posts and downloaded the pdf but for the life of me I can't find the horns or the wiring I have read that they are on the pass side behind the bumper. Do I have to remove the bumper? I bought the truck used its a 06 SD crew cab
derbin is offline   Reply With Quote
Old 08-30-2010, 11:34 PM   #6
lilpooh
lilpooh's Avatar
On my '04, it is on the pass side behind the bumper but up higher by the wheel well. I found it easier to take the screws out of the plastic wheel well and drop the wheel well out of the way to get to the wires. Even then I had trouble getting my hands in between the fender and plastic wheel well.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,Gyphon FICM tuner,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Thanks to:JASONS REPAIR AND PERFORMANCE-TELFORD,PA.
"Are diesel pickups hot rods? Yes,they are-perhaps the most versatile hot rods ever made"---Diesel Power Magazine
lilpooh is offline   Reply With Quote
Old 08-31-2010, 02:26 AM   #7
midnight2004
Just about Broke
midnight2004's Avatar
I tapped into mine here
http://www.commandocaralarms.com/wir...0Duty/540.html
HORN DARK BLUE (-) @ STEERING COLUMN HARNESS or VSM, See NOTE *2
Chris
2004 F250 Lariat 6.0L
Torqueshift, 4x4, Supercab, Shortbox.
AEM Brute Force HD Intake, GT4088 VGT Turbo, Spearco Intercooler, Custom EGR Cooler Delete,
H11 Head Studs, Fass 150/180, Custom Fuel lines, Custom Coolant Filter, Single 6" Stack, 2.5" Lift. 35x13.5 on 20's
midnight2004 is offline   Reply With Quote
Old 08-31-2010, 02:45 AM   #8
strokin6L
strokin6L's Avatar
isn't the horn located on passanger side behind the headlight near the windshield washer fluid tank on the inside quarter panel? Might hafta take the passanger side battery and windshield tank resevoir out to locate the horn.
2004 F-350 XLT SC 4x4: SCT, AFE stage II, autometer gauges(pyro, boost, tranny, fuel), edge insight, CFM large mouth intake elbow, spearco, snow performance water injection, 5" stacks, ARP's, fluidampr, hypermax fire rings, LIPD regulated return, FASS, fuelab, casserly 190's, 64/71/70 turbo(polished compressor housing)modded FICM(ID), Hellmann's sump, electirc fans
strokin6L is offline   Reply With Quote
Truck/Tractor pull Barren county Ky 7 Classes Rods Events and Gatherings 0 10-01-2005 01:21 PM
Pictures? FireRescuePSD Site Information 11 08-16-2005 08:08 PM
Where is it? Rich The Parking Lot 3 07-17-2005 05:40 AM
