| Thread Details Posted by PSDPlayer, this thread has received 8 replies and been viewed 1727 times. |
#1 |
Diesel Custom Tuner
Misfire, Lack Of Power, Buck/jerk, Excessive Smoke, Crank/no Start - 6.0l Engine - Di
FORD: 2003-2005 Excursion, F-Super Duty
2004-2005 E-Series, F-650, F-750 ISSUE: Some 6.0L vehicles may exhibit a misfire, lack of power, buck/jerk, excessive smoke or crank/no start. There are several potential causes for these symptoms, including injector concerns. ACTION: If normal diagnostics lead to an injector concern, use the following diagnostics to confirm the cause of injector failure and/or to rule out other conditions which may cause the same symptoms as a failed injector. NOTE: IF DIAGNOSING A LACK OF POWER CONDITION, BE AWARE 2005 MODEL YEAR VEHICLES HAVE A "FORCED LIMITED POWER" STRATEGY WHICH LIMITS ICP PRESSURE WHEN THE FUEL LEVEL IN THE TANK GETS VERY LOW (WELL AFTER THE LOW FUEL LIGHT COMES ON). WHEN THIS OCCURS, DTC P115A WILL BE STORED IN THE PCM. LOW OR NEGATIVE FUEL PRESSURE Internal injector damage can be caused by lack of fuel system supply pressure. Restricted fuel filters and/or fuel line(s), or an inoperative fuel pump can create a low or negative fuel supply pressure. Low or negative pressures may hinder the return stroke of the injector intensifier plunger to its rest position, leading to internal injector damage. To diagnose for low or negative fuel pressure and to confirm if any injectors have been damaged: Perform standard diagnostic procedures including verification of supply fuel pressure while the symptom is evident. Repair causes for low pressure on the supply side of the fuel system. Diagnose for failed injector(s) only after rectifying fuel supply pressure. COMBUSTION GAS ENTERING THE FUEL SYSTEM Inert combustion gas in an injector can cause a random misfire in one or many cylinders. Combustion gas may leak past the injector's needle and seat, or the copper combustion seal. Once the combustion gas enters the fuel rail in the cylinder head, it then distributes to other injectors, typically on the same bank. To diagnose for combustion gas entering the fuel system: Remove outlet fuel lines from the fuel filter housing on top of engine. Install a balloon over each fuel line with a zip tie. Disable the fuel pump and FICM relays. Crank engine and watch for compression pulses in the balloon. For each line where compression pulses are evident, remove all but one of the glow plugs from the affected cylinder head(s). Crank engine and watch again for compression pulses. Remove the glow plug and transfer it to the next cylinder in the head and repeat Step 6. For each cylinder where compression pulses are evident remove injector(s) and inspect copper gasket and lower O-ring, replace if necessary. If gasket(s) and O-ring(s) are OK replace injector(s). Retest to confirm repair. ERRATIC HIGH PRESSURE OIL SUPPLY Erratic supply of high pressure oil to injectors may cause a rough running engine. High pressure oil flow can be disrupted by faulty check valve(s) or a faulty IPR valve. To diagnose, first perform a slow neutral run up in park/neutral. If the engine runs rough between 1200 and 1900 RPM proceed to Check Valve Diagnosis; if the engine runs rough between 3000 and 4000 RPM replace the IPR valve. Check Valve Diagnosis To isolate the bank with the faulty check valve, disconnect all of the injector electrical connectors on one bank. Perform a Power Balance test. Engine misfires should be constant on the four disconnected cylinders and the operational cylinders should be contributing evenly. Repeat steps 1 and 2 on the opposite bank. If the operating contribution is erratic on one bank, replace the check valve on that bank. Notice that if the fuel pressure goes low you can kill an injector. The PCM also limits the ICP pressure if you are running on empty. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Too much into it now...
OK, but what if you have done the banjo bolt mod, and have increased the fuel pressure?
My concern was: "DIAG & ADVISE LACKS POWER & SMOKES BADLY - COLD STARTS ONLY. VERIFY FAULT. PERFORM DIESEL DIAG, WDS TESTS - MULTIPLE CODES RETRIEVED. EGR TEST INT, RELATIVE COMPRESSION TEST - PASS, POWER BALANCE ALL OVER. CHECK PCM CALIBRATION & REFLASH TO LATEST LEVEL AS PER SSM 17437. DIAG EGR CODE, VALVE STICKING - REPLACE EGR VALVE, CLEAN INTAKE PORTS, RETEST - PASS. ROAD TEST 30KM, OKAY." After this was done, it still starts terrible in the mornings. (EGR plugged in or not) My oil analysis comes back with NO fuel contamination at all. Wondering why I still have a louzy cold start... I also run Stanadyne on every tank...usually overtreat it as well. Can you tell me why I had a power balance all over...what does this mean?? :shrug: :thanks: |
#4 |
Diesel Custom Tuner
I will be asking for it to be moved to the tech forum but i wanted the visability. So it would not get passed over.
#6 |
Hey psd,
would this forced limited power by limiting icp be noticible to the driver of a 2005 my that was on empty...??? And will the code clear at the next starting event???ie.. how long will it continue to force limited power..Very interesting topic.. j.schall |
#7 |
Diesel Custom Tuner
This forced limited power will be really noticable. It has happend to me and it feels like you are driving a Dodge getting hauled back by a Ford.
#8 |
I think it has happened to me also that is why i asked....does it go away as soon as the next key cycle event or did it take yours a couple starts???
j.schall |
#9 |
Diesel Custom Tuner
It only sets the code but it will clear itself out once the fuel level goes back above low. Its not the type of DTC that does anything to prevent the truck from being in closed loop and looking at all the sensors.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Stolen Husky 372xp Replacement ? | BROKER | The Parking Lot | 12 | 08-07-2007 01:25 PM |
| wanted 01 gmc grill and bumper | gunracer1 | Whats Been Sold | 3 | 10-04-2005 08:23 PM |
| How do you calculate fuel mileage? | PSDPlayer | 2003-2007 6.0L Power Stroke | 11 | 09-24-2005 11:14 PM |
| Intake | Notorious6.0 | 2003-2007 6.0L Power Stroke | 12 | 08-20-2005 03:52 PM |
| Need Help with Plug-in Tuners | Paxamus | 2003-2007 6.0L Power Stroke | 4 | 08-19-2005 03:08 PM |
| New To Site? | Need Help? | TDG Specials |
