Oil pan removal - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (2003-2007.5)
Thread Details Posted by dieselfreak01, this thread has received 8 replies and been viewed 5299 times.
Old 01-15-2008, 06:07 AM   #1
dieselfreak01
Exclamation Oil pan removal
Has anyone ever removed their oil pan on an 03-07 common rail? I am tring to pull one to check the rods and mains. I have removed the engine mount bolts, jacked the engine up as far as possible, removed the suck tube, and still cant get it to come out! I have pulled the before on a 12 valve. I am thinking that the cross member has been modified. This is a 2wd by the way. Does the flywheel housing have to come off, or pull the engine? That sthe last resort. Thanks for your help!:smoke
dieselfreak01 is offline   Reply With Quote
Old 01-16-2008, 02:07 PM   #2
dieselfreak01
Alright everyone! The pan is out! I have answered my own question on this one. The Tranny has to come out, then the flywheel has to come off. After I did that, it slid right out the back. Well first I had to bar the engine around to get the number 2 rod cap out of the way. This is the most retarded design I have ever seen! I sure wouldnt own a dodge diesel!
Old 01-16-2008, 06:20 PM   #3
Mopar1973Man
2nd Gen Guru
Mopar1973Man's Avatar
Send a message via Yahoo to Mopar1973Man
Awww... It can't be that bad...
I've seen worse on other makes and models of trucks... It could be worse to have to jack the cab up off the frame to get a engine out...
Michael Nelson - 2002 Dodge Cummins & 1996 Dodge Ram 5.9L Gasser
116K Miles On My VP44 - 4 Years of 2 Cycle Oil Diet! - Mixed at 128:1 Ratio - 25.3 MPG maxed out!
Mopar1973Man is offline   Reply With Quote
Old 01-16-2008, 06:28 PM   #4
imported_BillM2004
Got Tunnel Vision??
laugh :
2004.5 Quad Cab SLT w/navigation, K&N intake system,CFM+, Smarty TNT, MP-8, II Silver Bullet, GDP 392, DDP 90's, Studded, Nitrous, Boost Fooler, DIY Boost Controller, DIY CP3 mod, TC Lockup Switch, Billet Fuel Filter Cap, Missing Cat, Silverline Muffler, HTS built trans. w/double laminated flex plate, Suncoast TC, Billet input and output shafts, Mag-Hytech DD pan, Autometer C2 Boost, Trans Temp, Oil Press, Fuel Press, Nitrous press guages, A pillar tripple guage pod, Dual steering column pod
10 seconds, here I come!
:evil:
Soon to install: Dual CP3 kit.
imported_BillM2004 is offline   Reply With Quote
Old 01-16-2008, 11:46 PM   #5
robfrass
robfrass's Avatar
I love my Dodge, but would like to choke that engineer that designed that thing. I had a problem where I wanted to get my oil pan off, but couldn't b/c of all the tools and time and space needed!!
2003, 2wd, quad cab, long bed, automatic, AEM intake, Striker II, Isspro guages, 203k miles
robfrass is offline   Reply With Quote
Old 01-17-2008, 06:01 AM   #6
dieselfreak01
Would you rather jack the from off the cab, or take out the engine or tranny to change an oil pan gasket???
Old 01-17-2008, 03:30 PM   #7
Mopar1973Man
2nd Gen Guru
What I was saying all manufactures of vehicle have there up's annd down's in designs. Like my Mom had a Chevy S10 pickup. You were required to jack the entire cab up 9" to get enough clearance to pull the engine.
Like my 73 Dodge Charger I must pull the entire engine to even pull the pan off...
On my 76 Dodge Motorhome I've got to pull the trans out to get the oil pan off so I can change the rear crank seal.
But on my 72 Dodge P/U the pan can right off the truck easy... So did my Mom's old 76 Dodge truck is was the same design...
So Every manufactures and models has hi's and lo's...:Thumbup:
(Naw... I haven't been turning any wrenches before... )
Old 01-17-2008, 04:47 PM   #8
dieselfreak01
Lol. Thats true lol. I work at at a Cummins distributor. Out of all of the engines I have worked on, this is the worst lol. I have got the rear main seals in motor homes down pat lol. On some of the new Internationals, the cab has to be removed to pull the engine. The cab mounts are in the road.
Old 01-31-2008, 10:50 PM   #9
jcoby
After you removed the tranny. did you still have to lift the motor from its mounts?
jcoby is offline   Reply With Quote
