double frame - stupid question - TheDieselGarage.com
Thread Details Posted by duunoit, this thread has received 8 replies and been viewed 3006 times.
Old 01-24-2008, 05:16 PM   #1
duunoit
What's the purpose of a double frame? The only thing that I can think of would be to raise the bed of the vehicle. Thanks
duunoit is offline   Reply With Quote
Old 01-24-2008, 05:18 PM   #2
wastedwagesracing
Banned
Not sure what your referring to exactly. But I'm thinking it's a double wall frame not one frame on top of the other. So frame strength would be the purpose.
wastedwagesracing is offline   Reply With Quote
Old 01-24-2008, 05:27 PM   #3
navistar73
The double frame is for higher GVW trucks.
navistar73 is offline   Reply With Quote
Old 01-25-2008, 01:33 AM   #4
Duke
'Ol Builder guy
Duke's Avatar
A double frame on a truck is for strength, but what I think you mean is the subframe that sits on top of the main frame of the chassis that you commonly see on smaller dumps.
Usually it's a smaller frame that the dump body hinges off and the hoist is mounted to. That way it comes as one single piece that's just bolted to the chassis frame of the host truck. It does create extra clearance above the truck chassis.
Duke is offline   Reply With Quote
Old 01-27-2008, 03:36 AM   #5
thejdman04
A double frame to me what I have always heard of it refered to is a frame ( c channel) inside of another frame (c channel) for higher gvrw vehicles, takes some of the twist and flex out of very very very rough terrain applications
1996 Gmc k2500 4x4 6.5 turbo diesel, with mods Blew the head gasket, put all new heads, valves, injecotrs gaskets etc on the truck only to get it together and find out it had no oil pressure, and sounded horrible (pry a spun bearing). SOLD
2007 chevrolet 2500hd Duramax loaded. GM LEMON BUYBACK
2007 Chevrolet LBZ 1 ton crew cab 8ft box
on star, xm, tow mirrors, 145 amp alt,
#23 Singles Club
thejdman04 is offline   Reply With Quote
Old 01-29-2008, 03:07 AM   #6
navistar45
good rule of thumb on trucks to carry work bodies, beds, etc, go with a double frame. as stated, it takes the flex out of higher weight carrying trucks, that are subject to off road use. concrete,dump and oil field trucks that are bought for this intended purpose, nearly always have a double frame. running a dump bed on a single frame truck is doable, i have done it, and seen others do it with sucess. general rule of thumb, a dump bed with it's own sub frame is the ticket under these circumstances. i have seen some take regular weld on dump beds, and install them on single frame trucks ,and hold up. but generally with time, problems arrise.
navistar45 is offline   Reply With Quote
Old 01-29-2008, 01:44 PM   #7
Duke
'Ol Builder guy
Duke's Avatar
A guy that hauls stone for me when I need 100's of tons has a single frame Pete tri-axle and runs a C-10 CAT in it (maybe 340HP?). He claims the lighter (non-doubled) frame, lighter diesl engine & driveline combined with a lighter aluminum bed, tanks, alcoas and air suspension allows him to carry 1.5 tons more stone on each haul than a double framed tri axle with a 500HP CAT with spring suspension. Of course he says that once loaded, the truck is slower than a 500HP truck, but unloaded it drives great. All those 1.5 ton extra loads add up!
He's an older guy that's been hauling for like 50 years and I respect his opinion.
On a single axle or construction truck used on jobsites a lot, i'd recommend a double frame, too.
Old 01-29-2008, 11:39 PM   #8
KWT800
Still Diggin
KWT800's Avatar
MY kw is double framed from the back to the front spring shackels to keep it from giving. It is very heavy and does cut down on payload ,but the only time I run that hevy is haulin grain to town. Ive learned if you have to worry about scales the lighter you can spec your truck the better off you are.
94 Ford F-250, Reg cab, xlt, 12v cummins, 5 speed, 4:10s,
370's, edge jammer turbo, colt camshaft, tuned by Snap-on
99 Kenworth T800, C-12 cat power, 10 speed, 3:90 gears, ag200, ridewell tag, 24ft grain bed.
90 freightshaker, 3406a , 13 speed, um...it was cheap
KWT800 is offline   Reply With Quote
Old 02-02-2008, 06:41 PM   #9
diesel dan
Destroked
diesel dan's Avatar
All of our IH county highway trucks have double frame. We order them that way because of the weight of an underbody plow and the front plow. Our single axles loaded with sand, sander, and all the plows are probably pushing 55-60k. We have about 4 or 5 4900's with 290-300k miles on them and still runnin strong with zero frame issues.
'04.5 Chevy 2500HD LLY,Alli, CC, SB, 4x4, Sleeved, Braced, FASS, 4" SS Silverline exh, EGR Blocker, all thanks to MA, EFI Live tuning by me with Edge CTS switching DSP5 tunes, 68mm Danville turbo, ARP Studs with "C" gaskets, Transgo Jr., 20x9 Diamo Karat 8's wrapped in Terra Grapplers, Superlift AAL in rear, Ride Rite Air Bags, some stainless........yeah it shines.
2002 VW Jetta GLS TDI, auto, 18x8 ASA AR3 wheels with Goodyear Eagle GT's
diesel dan is offline   Reply With Quote
