glow plug problems - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > 7.3L and 6.9 IDI (Pre 1994)
Thread Details Posted by rwaltonky, this thread has received 7 replies and been viewed 2862 times.
Old 01-27-2008, 12:55 AM   #1
rwaltonky
TDG MAFIA MEMBER #75
Send a message via AIM to rwaltonky Send a message via Yahoo to rwaltonky
Angry glow plug problems
Ok here's what happened. I put 8 new autolite glowplugs in my 6.9 on wedsday. Thursday I used them 1 time and only for 8 seconds then they wouldn't work the rest of the day. I was driving home and all of a sudden it starts make a pinging noise so I pulled over and checked it out. still had plenty of power like nothing was wrong but it made that pinging noise. The first thing I thought was the glowplugs broke off. The next day I pulled a glowplug out and sure enough it had, so I pulled the rest of them out and every one was broke off. I was mad. So I don't know why they done it but someone going to pay. I'm thinking about driving it and letting them burn out or I may pull the heads, that's something I really don't want to do that. Any suggestings. Thanks
Ray
1985 Ford F-250 4x4 200hp and 300ft. lb. torque. It has 3:55 gears, Dps high performance IP pump, Stage 1 injectors, Aftermarket hypermax turbo 3 1/2 in. straight pipe with 5in. tip, Holley electric fuel pump, and home made K&N ram air intake. Also keyless entry and power window kit installed, cowl induction hood and it all sits on a set of 33x12.50x16.5
1991 Ford ranger 2wd 5 speed. No mods, Cheap on gas
MY VIDEO LINKS
http://video.thedieselgarage.com/cat...ac0161c12e.htm
http://video.thedieselgarage.com/cat...93011b0897.htm
http://video.thedieselgarage.com/cat...39011bc6c4.htm
My Pics
http://www.thedieselgarage.com/galle...=9&userid=5065
rwaltonky is offline   Reply With Quote
Old 01-27-2008, 06:34 PM   #2
Chobeeman
Grumpy Old Member
Chobeeman's Avatar
First off, you need to pull the heads and get those pieces out. Yep that sucks but they can cause serious damage. Second thing, you didn't say if the GPs are still operated by the controller or if you have a pushbutton. If the operate by the controller you must have a bad controller or a bad solenoid, the puzzling thing is if the GPs had power your GP light should have been on. If you are using a pushbutton you may look into upgrading to 12v GPs, they take a little longer to warm up but there's a lot less chance of frying them from holding the button down to long. Either way something kept the GPs on and you'll need to find out what.
John
Singles Club Member 100
In loving memory (86 F250 6.9 non turbo, 4 spd, 457,000 miles)
SAM HOUSTON KNEW HOW TO HANDLE THE PROBLEM OF ILLEGAL IMIGRANTS,,,JUST ASK SANTA ANNA
Chobeeman is offline   Reply With Quote
Old 01-27-2008, 10:42 PM   #3
IDIeselman
IDIeselman's Avatar
Another victim of the autolite glow plugs:squish . When you get it back together and hopefully everything is OK. Use Motorcraft/beru or bosch GP's only. The autolite and champion Gp's are known to swell and break off if over heated while the much better Motorcraft/beru or bosch will handel the heat better and just burn out if the controller stay's on. SOB as much posting/reading as you do I surely thought you would have known already. Good luck to you man on getting that beast smoking again. Autozone should still have them Part # ZD9- 7.3IDI Bullet. ZD1A-6.9 Spade. ZD11-powerstroke's ?. So if you have done the 7.3 solid state conversion order the ZD9's.
1979 f350 4x4 6.9 Diesel,Everything new or better than.
Mechanically injected cause chips are for dippin
IDIeselman is offline   Reply With Quote
Old 01-28-2008, 12:56 AM   #4
rwaltonky
My glow plugs are on a switch and I only used them twice before the problem. The reason why I got autolite was I went to the nearest parts house and that's what they had and they are 12 volt plugs. I had never used autolite plugs before and will never use them again. I think they had a part defect and I'm going to push them to pay to have my truck fix, don't know how far I will get but I'll try. I always used AC Delco plugs and never had any problems.
Ray
MY VIDEO LINKS
My Pics
Old 02-02-2008, 10:53 AM   #5
fellro86
We don't cary them at Autozone any more, Oreilly's has the Motorcraft. Autozone does still carry the Bosch for about the same price as the Motorcrafts.
The workhorse: 86 F250 6.9 4 speed 4wd 4.10 gears, electric fuel pump
The other workhorse: 92 F350 2wd crew cab, 92 6BT Cummins, NV4500 and GV overdrive unit, 4.10 rear axle
fellro86 is offline   Reply With Quote
Old 02-03-2008, 04:14 PM   #6
jvbutter
just to let a few of the uneducated ones on the site know what happens if things bang around inside the engine...
here is the article
jvbutter is offline   Reply With Quote
Old 02-04-2008, 12:13 AM   #7
John_G
Super Moderator
John_G's Avatar
Yep, no aftermarked GPs in a diesel, it's EXPENSIVE.
That sucks, but when the tips break off, you gotta get them out. Sometimes you get a little time if the tips are big enough - they won't pass thru the pre-combustion chamber hole, and you can drive it for a WHILE. But they will get progressively smaller, and eventually make it into the combustion chamber and if they happen to wedge between the piston and cylinder head, the piston loses, and you get carnage as shown in the above linked photos.
Pull the heads, and you may need to have the pre-cups removed to get all the pieces out, then re-install after you KNOW there is nothing to cause damage stuck in there.
I vote for LIBERTY!
Old 02-04-2008, 05:16 AM   #8
bgkast
here is the article
Thanks for the link.
Should I consider pulling out my working glow plugs and replacing them with motorcraft plugs as preventative maintenance? I do not know what brand is in the truck now (just bought the truck)
1986 Ford F-250 4x4, 150K Miles - 6.9 IDI/C6 Auto/33" BFGs
1979 Mercedes 240D, 310K miles - 4 speed manual, 5 cyl 3.0L Turbo-Diesel engine swap, Air/water intercooler, 2.5 exhaust, VDO pyrometer and boost gauges
bgkast is offline   Reply With Quote
