AFC Housing - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins 12 Valve (1994-1998.5)
Thread Details Posted by Big Gray dodge, this thread has received 5 replies and been viewed 1035 times.
Old 02-02-2008, 01:24 AM   #1
Big Gray dodge
Dirty Dozen
Cool AFC Housing
Anyone ever tried running without the afc arm I was just reading about it and wondered how that would drive like. I was also thinking about going with the star wheel full forward and the housing full foward do you think that would be too smokey.:smoke
Brett
1994 Dodge 2500 12v 6in stack, BHAF,laser cuts, 435's 60# Springs, 4k gsk, some pump mods, Fully built Tranny, Isspro Boost, Pyro and Tranny gauges, 33" tires
Dodge Makes It The 12 Valve Shakes It .
Big Gray dodge is offline   Reply With Quote
Old 02-02-2008, 04:19 AM   #2
imported_smokindodge12v
i am running without mine. Its great. My starwheel is all the way forward and not to sure about the housing. We grinded the fuel plate down to a 0 and no arm back in it
96 12v, rebult injectors, aftermarket manifold, intake, southbend clutch, straightpipe 4' pipe to a 6' tip, isspro gauges. #10 fuel plate, audio stuff, smoking like crazy. :smoke
imported_smokindodge12v is offline   Reply With Quote
Old 02-02-2008, 04:34 AM   #3
Dual K20s
Professional Amateur
If you don't have an arm, it doesn't matter how your starwheel is setup or if its there for that matter
I don't know if you'd like it more with or without it. Thats a decision you'll have to make on your own I don't like a lot of smoke, but maybe you do :shrug: Try it and if you don't like it put it back. That goes for everything, play with it until you like it
I think of the AFC as a driving tool. If you want smoke set it on the heavy fueling side, if you don't set it so it just gives you a haze throughout the rpms/boost levels. You'll get consistent results every time.
If you remove the arm then just stand in it @0psi and 1000rpm it will smoke a lot and may never build much boost or power. You also have a chance of getting cylinder washout and damaging your rings
My name's Derek and this is my ride:
Singles Club Member #58
98 Dodge 2500 Motor: 12 valve, BHAF, 4K GSK, O-ringed head, .020 over HG, studs, Modified AFC, DDP4 injectors, DDP DVs, 17.5* timing, 16cm^2 ex. housing, Drivetrain: 5-speed 4x4 w/ SB clutch (13" OFE 450Hp)
83 Chevy K20 with turbo 6.2 Sold
It's not what you buy, It's what you build
Dual K20s is offline   Reply With Quote
Old 02-02-2008, 11:26 PM   #4
Big Gray dodge
Dirty Dozen
Ya I just put the 191's in a little bit ago I like them alot but I might try playing with the star wheel tomorow and see what I like.
Brett
Old 02-04-2008, 02:54 AM   #5
mock12v
riding in the dirty dozen
i like smoke and all but now with it diesel being 350ish up here i just think to my self well.....there went 10 bucks. but it nice when people ride ur butt or when someone is blaring there rap really loud with the windows down...or just a nice ol' convertable.....but im thinking about really fine tuning my pump to where its got enough smoke for occasions
1998 Dodge cummins 12v, #10 plate and afc FF, BHAF, Isspro guges, homemade boost elbow,tabbed kdp
coming soon stacks,tires:Thumbup:
mock12v is offline   Reply With Quote
Old 02-05-2008, 02:44 AM   #6
Yellow Yota
I wonder why people complain about our trucks?!?
Yellow Yota is offline   Reply With Quote
