nv4500 stuck in 5th gear - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins 12 Valve (1994-1998.5)
Thread Details Posted by baker9713, this thread has received 4 replies and been viewed 2904 times.
Old 02-12-2008, 10:27 PM   #1
baker9713
Send a message via AIM to baker9713
truck is a 95 2500 4x4. driving to work this morning, slowing down for a stop sign, tried to downshift and it won't come out of 5th. clutch is working, but the shifter won't budge. I spoke to the previous owner today, he said he would suspect the 5th gear nut came loose (about 20k miles on rebuilt tranny). If that's the problem, is there a way to get to it without dropping the tranny? The book I have doesn't cover much for the tranny (Haynes) so I haven't found an exploded view yet. Any help would be appreciated
Mike
95 Dodge 2500 4x4 12v CTD
Keystone Heights, FL
baker9713 is offline   Reply With Quote
Old 02-13-2008, 01:07 AM   #2
cummins kid
cummins kid's Avatar
It is really easy to do. I had to fix the 5th gear in my truck to. Remove the driveshaft,transfer case, and then the tail shaft housing from the trans and there is 5th gear. Go to your local dodge dealer they can print you of a diagram of it, while your there you might as well order the fix kit for it.
I belive that this is the right part number 5013887-AA.
1998 12v x-cab long box 4x4, built auto, 100plate, 191 dvs, 3gsk, HX-40, exhaust, intake, gauges, 3.55 gears.
309 HP 12/10/2009 on stock turbo.
cummins kid is offline   Reply With Quote
Old 02-13-2008, 03:52 AM   #3
Dual K20s
Professional Amateur
http://quad4x4.com/NV4500%205th%20Ge...0Solutions.htm
I dought thats the problem. When the nut comes loose the gear slides off of the back of the splines so when you engage fifth the gears spin but don't line up.
I'd look for binding. Take the tower off and have a look :2cents
My name's Derek and this is my ride:
Singles Club Member #58
98 Dodge 2500 Motor: 12 valve, BHAF, 4K GSK, O-ringed head, .020 over HG, studs, Modified AFC, DDP4 injectors, DDP DVs, 17.5* timing, 16cm^2 ex. housing, Drivetrain: 5-speed 4x4 w/ SB clutch (13" OFE 450Hp)
83 Chevy K20 with turbo 6.2 Sold
It's not what you buy, It's what you build
Dual K20s is offline   Reply With Quote
Old 02-13-2008, 11:05 AM   #4
baker9713
Thank you both. I've heard from several people about the 5th gear nut, but my gut feeling after looking at some diagrams would be a shift fork issue. I'll have to do some more digging until I have time to crack her open. Thanks again.
Mike
Old 08-28-2009, 02:28 AM   #5
cookzchoice
Send a message via MSN to cookzchoice
i have a 94 and i have the same problem i know its not the 5th gear nut i have the trans all apart i'm sure its in the tower but can't see anything wrong with it
cookzchoice is offline   Reply With Quote
