P7100 pump on a VE cummins - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (Pre 1994)
Thread Details Posted by XXXcumminsXXX, this thread has received 16 replies and been viewed 6622 times.
Old 03-21-2008, 07:57 AM   #1
XXXcumminsXXX
i was reading my diesel world magazine when i came across an article on swapping for a P7100 injection pump rated for up to 500 horse. does anyone know about this swap? how hard is it and how much does it roughly cost? would this be a good investment or no? any info is much appreciated. thanks again. cheers,
nick
XXXcumminsXXX is offline   Reply With Quote
Old 03-21-2008, 08:14 AM   #2
jd_craft
Send a message via AIM to jd_craft
i have heard about it alot the pump aint gonna be cheap i will tell u that then ur are gonna need the lines inectors plus the gear for the pump ull have to take the whole front cover off and time the pump to the motor the pump they are talkin about should be about 400cc pump this stuff aint meant for ultra low sulfer diesel either need to upgrade the turbo too and is ur truck intercooled it is a great investment especially if u want performance
jd_craft is offline   Reply With Quote
Old 03-21-2008, 03:12 PM   #3
Philip
The VE timing cover is different from a P-pump cover add that to the list.
Unless you can find the parts real cheap. Most of the time the cost of parts will be higher than buying a complete P-pump engine.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, HX40/16, G56 /SBC Con-OFE, 307's axles' 2" skyjacker lift, B&W flatbed
Philip is offline   Reply With Quote
Old 03-21-2008, 04:17 PM   #4
cumminspride
T.D.G. Mafia Member #88
cumminspride's Avatar
For 500 HP I think it's a waste of money. A 14mm H&R for your rotary and some turbo you'd hit that.
06 Mega Cab 3500 CTD 4X4 Auto SRW
http://www.hoosiertruckclub.com/phpBB3/index.php
cumminspride is offline   Reply With Quote
Old 03-21-2008, 08:23 PM   #5
XXXcumminsXXX
Whats an H&R? also my truck is intercooled. Sorry im a little new to the whole first gen thing...but i LOVE my truck. Its a '93 W350 DRW. Thanks again,
Nick
Old 03-21-2008, 08:37 PM   #6
jd_craft
what is sayin to is build up the ve pump its an ok idea probably cheaper and it would work if u only want to go to about 500hp but if u want to go beyond that i would do the coversion i not for sure but i believe u can use the kit for the 24v conversion to a p-pump all but the lines
Old 03-21-2008, 09:55 PM   #7
jd_craft
what h&r stands for is head and rotor i found a place out in northern cali that has the 14mm head and rotor kit
http://www.rocken-tech.com/index.html give them a call see how much performance u will gain u would be different if u stayed with a ve pump i think 500 hp can be done with a turbo and built pump anyting over 500hp u need to do the conversion
Old 03-21-2008, 10:38 PM   #8
01duramax6spd
01duramax6spd's Avatar
I'm planning to do the swap but haven't taken time yet. I got a complete P-Pump'd truck that had a locked up motor so I have everything. That'd be the best way I think.
01 2500 Duramax/ZF6,returned to daily driver590/995
03 3500 Duramax/Ally S/C IV EFI Live {Brothers truck}
04 3500 Duramax/Ally EFI Live,feed truck with 3 bale Hydra-Bed,very sick trans
06 4500 Duramax/Ally 4x4 Monroe,EFI Live,Danville turbo, CM flatbed
11 2500 Duramax/Ally 4x4 H&S tuned and deleted {GF's truck}
13 3500 Duramax/Ally 4x4 stock for a very short time
Some Green Equipment and a heard of Black Angus cows
01duramax6spd is offline   Reply With Quote
Old 03-21-2008, 11:02 PM   #9
jd_craft
the ve pump can make good power numbers 2 it is unquie to to see a ve pump make great power but a p-pump is the best out there
Old 03-22-2008, 04:29 AM   #10
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
You would be better off buying the 14mm pump head. You might as well buy another engine instead of swapping your ve pump over to a p-pump. You will have to replace your pistons, your head due to the ve pump injectors being different at the threads and the head casting holes are different as well. You will have to replace the front cover, front gear housing, the injectors, lines, intake plate, upper intake, the parts list will add up real quick.
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
