HELP!!! Oil coming out of the breather tube - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (1998.5-2002)
Thread Details Posted by TGentry, this thread has received 11 replies and been viewed 14877 times.
Old 04-04-2008, 04:50 PM   #1
TGentry
My Dad has a 1999 model 2500 with the Cummins 24 valve under the hood. He is a big fan of the truck and the engine (transmission is another story) but the other night he noticed quite a bit of oil around the blow by tube and all over the steering box and everything else. At first we thought it was something else but then I noticed how wet is was inside the breather tube. He is starting to worry about this and wants to know if there is anything that we can do to fix this. He does not take it offroad or anything so I cant see where that could be an issue. The only thing he has done to it is put a K&N air filter in it and he put a Superchips programmer in it as well. It stays on performance tow all the time. Like I said the truck has always been taken care of so I just dont understand it. He cant stand a leaker and if something is about to go south on it or in it it would be nice to have a heads up!!If anyone can give me any info on this matter it would be great. I am a huge fan of this site and everyone is always helpful. Thanks again to everyone.
TGentry is offline   Reply With Quote
Old 04-04-2008, 06:26 PM   #2
sstockton
sstockton's Avatar
They all kind of blow oil out that breather tube. but usually its not enough to cover the steering box and everything. I would check on the back side of the timing case where the vacuum pump and power steering pump attach. there is a through shaft that runs through the vacuum pump and into the PS pump. The seals on this shaft tend to start leaking and can leak a lot of oil. When this happened to me, I thought the same thing, breather tube, but a little more looking lead me to the source. Hope this helps.
2000 2500 reg. cab 4x4 auto 577hp
09 6.7L QC LB stick, 4x4.
TOTAL PERFORMANCE DIESEL 707-545-FUEL (3835)
www.totalperformancediesel.com
sstockton is offline   Reply With Quote
Old 04-05-2008, 07:39 PM   #3
jarhead
TDG Mafia Member #45
jarhead's Avatar
:iagree
it will leak a lot from the the vac pump a lot!
Randy
05 Dodge str8 pipe, smarty jr, afe, airbags, and pacbrake.
jarhead is offline   Reply With Quote
Old 04-08-2008, 07:32 PM   #4
lukemc
It's probably the seal between the vac and ps pumps.
Try this guy Fixinrams.com. He sells a better seal than what you will get with a new pump. and it's hundreds of dollars cheaper.
lukemc is offline   Reply With Quote
Old 04-08-2008, 09:25 PM   #5
sstockton
sstockton's Avatar
Yup, thats where I got mine.
Old 04-09-2008, 01:33 AM   #6
Mopar1973Man
2nd Gen Guru
Mopar1973Man's Avatar
Send a message via Yahoo to Mopar1973Man
Just for information purpose... I've got a redesigned vent pipe for the 2nd Gen that rid s the oil mess forever! :
Here is my write up...
http://mopar.mopar1973man.com/2002%2...kcase_vent.htm
Michael Nelson - 2002 Dodge Cummins & 1996 Dodge Ram 5.9L Gasser
116K Miles On My VP44 - 4 Years of 2 Cycle Oil Diet! - Mixed at 128:1 Ratio - 25.3 MPG maxed out!
Mopar1973Man is offline   Reply With Quote
Old 04-09-2008, 04:42 PM   #7
lukemc
I got a redesigned one too. It's called a hose that let's it run out on the ground so it doesn't get all over the engine.
2001 Ram HO 4x4, edge hot juice, smarty, hot rod VP44,100hp injectors, custom twins stock hx35 over hx55 w/ external wastegate on hx35, straight piped, 650 hp clutch.
Old 04-09-2008, 05:19 PM   #8
Mopar1973Man
2nd Gen Guru
If you do any kind of serious offroading your be running all you oil out on the ground too...
TSB 09-002-02 Crankcase Breather Overflow
http://dodgeram.info/tsb/2002/09-002-02.htm
Owners of 1998 - 2002 (BR) Ram Trucks equipped with the 24-valve Cummins diesel engine may experience engine oil overflow from the front crankcase breather when the vehicle is operated off-road on an extreme downhill grade (37.5% or 22 slope/grade). Operation of this type for extended periods of time can cause enough engine oil depletion to damage the engine.
At least my fix corrects this problem for me...:
Old 04-09-2008, 11:04 PM   #9
lukemc
no it's orginally just a cup thing that catches oil. when it fills up it makes a huge mess. I've never had any issues with oil running over, and I bounce around pretty good.
However I suppose yours is better. I always seem to be doing fix jobs on the spot, in the dirt, or at night. Most of my work isn't textbook, but it does the job for me.
Old 04-09-2008, 11:53 PM   #10
robfrass
robfrass's Avatar
I had the same problem, but mine was bad piston rings. pop the oil cap off, hold your hand over the hole w/ the truck running, and make sure there is no air pressure pushing against your hand. good luck, I hope the above posts are where the problem is and not rings
2003, 2wd, quad cab, long bed, automatic, AEM intake, Striker II, Isspro guages, 203k miles
robfrass is offline   Reply With Quote
