please help with dtc p003A - TheDieselGarage.com
Go Back   TheDieselGarage.com > GM Diesel & Truck Discussion > Duramax 2006-2007(LBZ & LLY)
Thread Details Posted by jrdragdad, this thread has received 8 replies and been viewed 8925 times.
Old 04-20-2008, 04:11 PM   #1
jrdragdad
cant find any info, code set while towing to racetrack i can clear it but it coes right back. any ideas
thanks
phil
jrdragdad is offline   Reply With Quote
Old 04-20-2008, 07:30 PM   #2
ripmf666
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
Code: P003A
Modules: ECM
Description: Turbocharger Boost Control Position Not Learned
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/08@5:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline   Reply With Quote
Old 04-20-2008, 11:25 PM   #3
jrdragdad
thanks is it a major problem, what can i do to fix it?
phil
Old 04-21-2008, 02:01 AM   #4
ripmf666
Mafia member #105
ripmf666's Avatar
Most of the time its the sensor they swap it or replrogram your ecm for you
She's Alive again
Old 04-21-2008, 02:05 AM   #5
jrdragdad
i guess i will have to add it to the list and get it in, i was hoping it was something simple and could fix it myself
Old 04-22-2008, 10:58 AM   #6
TheBac
Heres a TSB about it:
Subject: LBZ LLY Engine with Rough Idle, Poor Performance, Black/White Exhaust Smoke, MIL/SES Light On, DTCs P003A, P060B, P0230, P0403, P0401, P0606, P2146, P2149, P2152, P2155 (Reprogram ECM) #06-06-04-066A - (03/09/2007)
Models: 2006-2007 Chevrolet Express, Kodiak C4500/C5500 Series, Silverado Classic
2006-2007 GMC Savana, Sierra Classic, TopKick C4500/C5500 Series
with 6.6L Duramax ™ Diesel Engine (VINs D, 2 -- RPOs LBZ, LLY)
This bulletin is being revised to add additional warranty information on the EGR learn procedure. Please discard Corporate Bulletin Number 06-06-04-066 (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on an illumination of the MIL/SES with one or more of the following symptoms:
• Rough Idle
• Poor Performance
• Black/White Exhaust Smoke
Upon further investigation, the technician may find one or more of the following DTCs stored in the ECM:
• P003A: Turbocharger Boost Control Position Not Learned
• P060B: Control Module Analog To Digital Performance
• P0230: Fuel Pump Relay Control Circuit
• P0403: EGR Solenoid Control Circuit
• P0401: Exhaust Gas Recirculation Flow Is Insufficient
• P0606: Control Module Internal Performance
• P2146, P2149, P2152, P2155: Injector Positive Voltage Control Circuit Group 1-4
Cause
This condition may be caused by a calibration issue.
Correction
Important: If the calibration update was for DTC P0403, then follow the service procedure in this bulletin to ensure that the P0403 code has been eliminated.
If routine diagnosis using SI does not reveal any obvious cause for the DTCs setting, then reprogram the ECM.
Reprogram the ECM with the latest calibrations if the above concern is encountered. An updated ECM calibration is now available to address this concern. This calibration, or any that follow, is designed to address this concern.
The new ECM calibration is available to dealerships in TIS2WEB (website version of TIS) version. If you cannot access the calibration, please call the Techline Customer Support Center at 1-800-828-6860 (English) or 1-800-503-3222 (French) and it will be provided. As always, make sure your Tech 2 is updated with the latest software version.
P0403 EGR SOLENOID CONTROL CIRCUIT LEARN PROCEDURE
After the new calibration is installed for a DTC P0403, the EGR valve learn procedure should be performed four times before returning the vehicle to the customer. The EGR learning cycle occurs on engine shutdown. Technicians should perform the following service procedure to ensure that the DTC P0403 has been eliminated:
Start the engine. Let the engine idle until the engine coolant temperature is greater than 75C (167F). Then shut the engine off for one minute.
Once the engine coolant temperature is greater than 75C (167F), repeat this procedure four separate times, letting the vehicle idle for 30 seconds.
Evaluate the vehicle performance and EGR operation after the learning cycle has been completed.
TheBac is offline   Reply With Quote
Old 04-22-2008, 01:33 PM   #7
jrdragdad
thanks, my question is this, if i have a egr blocker and mbrp exhaust no cat has does this effect the above? when i take it in will i have to reverse changes?
would blocking the egr have caused this?
thanks
phil
Old 04-23-2008, 03:22 AM   #8
ripmf666
Mafia member #105
ripmf666's Avatar
Do you just have the blocker plate in and no finger
She's Alive again
Old 04-24-2008, 12:45 AM   #9
jrdragdad
i have both installed now. was wondering if the plate and blocker are what is causing the trouble.
pk
