Quiet cab. - TheDieselGarage.com
Thread Details Posted by Taco XL, this thread has received 14 replies and been viewed 3017 times.
Old 04-30-2008, 07:09 PM   #1
Taco XL
Quiet cab.
Anyone have any tricks to quiet the cab down? I get a lot of engine and trany noise from the floor, shift boot, fire wall area. I think I am going to remove the seats and carpet and put down a few layers of Dynomat. Any one try this?
1997 f-350 crew cab 4x4. Intake and straight piped. Thats about it.
http://www.jordanswebpage.com
Taco XL is offline   Reply With Quote
Old 04-30-2008, 07:38 PM   #2
joebob3093
joebob3093's Avatar
Send a message via Yahoo to joebob3093
i have heard of a couple people doing that, i think it would work its the only idea i have to quite things down.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline   Reply With Quote
Old 04-30-2008, 08:38 PM   #3
BJS
Dynamat the inside and coat the underside of the cab and lower portion of firewall (away from exhaust) with a spray on rubberized bedliner material.
I know some people who have had the inside of their cabs sprayed with rhino or line-x and put the carpet over that for sound deadening.
95 F350 Centurion Conversion Bronco (Crew Cab SRW) 4X4 4.10, Isspro Performax Boost, Pyro, & trans temp on the A-pillar, BDP Stage 1 injectors, Open air intake, Dpp Downpipe, Self built E4OD with parts from Racer-X, Tony Wildman Chip, Early '99 Intercooler.
Destin FL Vacation Houses 1 block from the beach
BJS is offline   Reply With Quote
Old 04-30-2008, 08:42 PM   #4
CrowsSynthetics
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
Post
Originally Posted by Taco XL
Anyone have any tricks to quite the cab down? I get a lot of engine and trany noise from the floor, shift boot, fire wall area. I think I am going to remove the seats and carpet and put down a few layers of Dynomat. Any one try this?
I have also heard of some one doing that. There is a thing to do with the door seals also using a rubber or something inside the door seal.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline   Reply With Quote
Old 05-01-2008, 01:29 AM   #5
rwhite
Also make sure your downpipe isn't rubbing the firewall and your inner shift boot, the white one, isn't cracked or anything.
'99 2500 4X4 5spd 104K miles Ext Cab, longbed, Banks exhaust, Exhaust Brake, BHAF, comp, Raptor 150, gauges, 100 hp sticks.
#23 B.O.M.B. Squad[/b]
rwhite is offline   Reply With Quote
Old 05-01-2008, 02:16 AM   #6
Orangepstroke
strokin now cummin later!
Orangepstroke's Avatar
i would dynomate under the carpets. and also go buy some 3/8" rubber hose. and run it threw your weather striping in your doors. there is a tube like seal in the weather striping. and 3/8" hose fits great in there. it seals up the doors better and keeps road noise down.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline   Reply With Quote
Old 05-01-2008, 04:12 AM   #7
StrokerDude
StrokerDude's Avatar
there are some pretty sweet deals on Dynamat type materials on Ebay.
Alex C.
R.I.P. 2006 F-250 CC SB Fx4. w/ 500 RWHP *stolen 7/15/2010*
1990 F350 CCLB 4x4 -- 24V Cummins, 200hp DDP's, SuperB over S475-sx3, Cam and valvesprings, Spe-rite Convertor, Billet input.
www.JeffersonStateDiesel.com --- http://en.wikipedia.org/wiki/State_of_Jefferson
Singles Club # 182 - B.O.M.B Squad # 14 - American Club #23
StrokerDude is offline   Reply With Quote
Old 05-01-2008, 08:59 AM   #8
jmbstudios
Member in Learning!
Here is a product from Elemental Designs.
Just found it and I read some reviews on it and seems to be pretty good. As good as dynamat, but less $$$.
I'm looking at quieting down my cab too.
You can buy the amount you need. One sq ft, or 300 sq ft.... whatever you need.
http://www.edesignaudio.com/product_...products_id=51
'99 F350 XLT, 7.3 PSD Crew Cab, LB, 4x2, Auto. DIY Intake.
Just learnin as I go!
jmbstudios is offline   Reply With Quote
Old 05-02-2008, 09:07 AM   #9
Taco XL
good ideas! Ill post some pics when im working on it.
Old 05-02-2008, 03:03 PM   #10
SDEric
Banned
Alright so what is the square footage of a crew cab? Just so I can get what I need the first time
E
SDEric is offline   Reply With Quote
