| Thread Details Posted by cat power, this thread has received 8 replies and been viewed 347 times. |
#1 |
smokin duramax
upgrading
Alright i bought a 03 CR 6 speed . Now im goin with a smarty chip and a dual disc clutch for starters but now im wanting to hit 600hp with it so im wandering wat other mods im going to need. thought about the dual cp3s but not sure if i need them so just need some suggestions
#2 |
stock is boring
check out my sig I know im not quite to 600 but it's all usable power - max egts 1400 under load
'04 LB7 4DR LONG BED 4x4 '02 LB7 REG CAB Utility body 2wd |
#3 |
busting parts
let me drive your truck,1400 egt?????????????
03 f250 4x4 cc 6.0 61mm tn turbo dr performance sticks h/m fuel system arp studs egr delete o ringed heads south bend dd dana 80 rear sct/eric/tadd 05f350 4x4 dulley lots of mods 210000 mi 06f350 4x4 dulley a few mods 160000 mi 05gmc 3500 4x4 dulley a few mods 35000 mi 94 cummins pulling truck |
#4 |
stock is boring
wont happen you never left me drive your 6OH![]() ![]() ![]() ![]()
#5 | |
TDG Mafia #103
Tom 2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats 2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels |
#6 |
smokin duramax
thanks for the input , i guess if im going to spend the money i mite as well go ahead and go all out .. am i right? lol so i thought about dual cp3s , 14mm head studs ,dual turbos , smarty stacked mp8 ( still wondering witch chip to stack with the smarty) , and of course the dual disc clutch. now im not sure wat brand and how big of injectors i should get tho. i was also on the garret website and saw a gt6041 turbo with a 141mm compressor lol is that to big for a cummins
04 lb7 chevy 2500 Duramax Ext.CSB 4x4 6 speed Engine : PPE 425 hp chip, Head stud kit, studded mains, dual cp3s, FASS, ATS Aurora 3000 & 5000 , and 5 inch straight pipe. Transmission : zf6 , dual disc clutch , atlas II transfer case (daily driver) 88 s10 on a 1 ton frame , 350 .30 over 3/4 cam , afr 200cc heads , 800cfm thunder eldbrok , 14 bolt rear dana 60 front , np 205 with a munci m21 4speed tranny . 527 gears. dual radiaters sittin on 44s. ( TOY ) 1987 CASE 1455B track loader / crawler loader 1997 CASE 1845C skid steer / bobcat 1990 CASE 580K 4x4 , turbo Backhoe 1968 CAT D9G dozer NEW WIDE TRACKS 1985 CAT D4H dozer High track 1993 CASE 1288 Track hoe / Excavator 1984 CAT D6D dozer 1987 GMC General tri axle dump , 855 cummins pump turned up, 4.88s 9 spd. 1986 GMC BRIGADIER single axle , 6v92 detroit pump turned up, 5.57s 9spd. custom goose neck, tool/welding Bed 1988 chevy C70 CC single dump , 8.3 cummins , 100# fuel plate 9 speed , 6.57s 1990 PETE 375 Dump quad axle , 3406B cat (dumpin the fuel 2003 Chevy C5500 CC 4x4 duramax , 208wb. 6spd. 4.56s , long flatbed goose neck 300hp ppe chip , Fass, head studs , Aurora 3000, dual disc clutch , 5" straight pipe Last edited by cat power; 01-18-2009 at 06:16 AM. |
#7 |
TDG Mafia #103
For injectors, you could contact Floor It Diesel and let Don suggest what size to go with. The most common stacks with the Smarty are the MP-8 and the Edge EZ. And hey if you got the cash, go all out!!
#8 |
600 is not a hatd number to get. I hit 600 on a 99 degree day with a 100% humidity with a 2.5 charger, injectors, headstuds, exhaust, intake, dual disk clutch, and a smarty. Let me tell you that was a miserable day in that building watching it dyno it would have made more on a cooler day
#9 |
smokin duramax
alright i think ill go with the mp-8 for a stack , but wat about that turbo i found on my last post , the garret gt6041 with a 141mm compressor lol
04 lb7 chevy 2500 Duramax Ext.CSB 4x4 6 speed Engine : PPE 425 hp chip, Head stud kit, studded mains, dual cp3s, FASS, ATS Aurora 3000 & 5000 , and 5 inch straight pipe. Transmission : zf6 , dual disc clutch , atlas II transfer case (daily driver) 88 s10 on a 1 ton frame , 350 .30 over 3/4 cam , afr 200cc heads , 800cfm thunder eldbrok , 14 bolt rear dana 60 front , np 205 with a munci m21 4speed tranny . 527 gears. dual radiaters sittin on 44s. ( TOY ) 1987 CASE 1455B track loader / crawler loader 1997 CASE 1845C skid steer / bobcat 1990 CASE 580K 4x4 , turbo Backhoe 1968 CAT D9G dozer NEW WIDE TRACKS 1985 CAT D4H dozer High track 1993 CASE 1288 Track hoe / Excavator 1984 CAT D6D dozer 1987 GMC General tri axle dump , 855 cummins pump turned up, 4.88s 9 spd. 1986 GMC BRIGADIER single axle , 6v92 detroit pump turned up, 5.57s 9spd. custom goose neck, tool/welding Bed 1988 chevy C70 CC single dump , 8.3 cummins , 100# fuel plate 9 speed , 6.57s 1990 PETE 375 Dump quad axle , 3406B cat (dumpin the fuel 2003 Chevy C5500 CC 4x4 duramax , 208wb. 6spd. 4.56s , long flatbed goose neck 300hp ppe chip , Fass, head studs , Aurora 3000, dual disc clutch , 5" straight pipe |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Upgrading Brakes | imported_LovinPSDs | General Ford Truck and Excursion | 2 | 04-03-2008 10:24 AM |
| upgrading a 92 to a p-pump | 01duramax6spd | 12 Valve Performance | 20 | 03-21-2008 11:13 AM |
| 2000 7.3 upgrading | HIGH MILEAGE ELITE | 1994-2003 7.3L Power Stroke | 3 | 10-23-2007 03:52 AM |
| Need help upgrading my truck? | dp1982 | Duramax 2004.5-2005(LLY) | 8 | 07-30-2007 02:16 PM |
| New To Site? | Need Help? | TDG Specials |
