| Thread Details Posted by Mopar1973Man, this thread has received 6 replies and been viewed 5600 times. |
#1 | |
2nd Gen Guru
P1689 ERROR CODE - Cause of code Found!
Well gang...
Mopar1973Man is back out in his shop and found the cause of P1689 error codes. Quote:
![]() Lower left side labeled fuel pump... When this relay is missing the VP44 doesn't energize nor pump fuel. It allows you to do the cranking test. But it also sets a P1689 and CEL light. So for all of you that have a P1689 error code present check your fuel pump relay first by trading with another relay!
Michael Nelson - 2002 Dodge Cummins & 1996 Dodge Ram 5.9L Gasser 116K Miles On My VP44 - 4 Years of 2 Cycle Oil Diet! - Mixed at 128:1 Ratio - 25.3 MPG maxed out!
| Sponsored Links | |||
Advertisement | |||
#2 |
2nd Gen Guru
Addon to this post I did a short video of the fuel pressure test that causes the code...
#3 |
2nd Gen Guru
That's odd 52 people look at the thread and no comment...
#4 |
Heavy Equip. Is My Life
I am in awe... still trying to process!
So you weren't trying to diagnose the 1689 by doing the pressure test, the code set after/because of the test, correct? It's amazing the amount of good info you collect/generate and post.
Russ Late '99 F-350 7.3l 6sp 2wd Aftermarket dually kit 186,000mi STOCK![]() '99 Dodge 3500 24v 47re QCLB 4x4 DRW 131,000mi Straight-piped '97 Chev 3500 6.5TD Auto-OD ECLB 4x4 DRW 199,000mi 4" exh. turbo to bumper |
#5 |
2nd Gen Guru
I can't seem to find the proceedure but it request that you pull the fuel pump relay from the PDC to do the cranking fuel pressure test.
When I was completeled the code was tripped... So it was a learning curve for me...
#6 |
i didn't look it up, but i believe thats what my truck threw when the suspect was the Throttle Positions Sensor (APPS) the truck would just cut out but stay running at an idle..... i'm not 100% sure....
are there any symptoms beside just having the code? |
#7 | |
2nd Gen Guru
P1689 No Comm between VP44 and ECM. The engine won't even start...
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Error Codes Dump and Code Listing | Mopar1973Man | General Dodge Discussion | 7 | 01-03-2010 02:13 AM |
| OBD Error Code Dumping and Reading | Mopar1973Man | 5.9L Cummins (1998.5-2002) | 1 | 04-26-2009 12:54 AM |
| Error Code: PO 308 | JoeDirte | 1994-2003 7.3L Power Stroke | 9 | 03-08-2008 11:55 PM |
| code problem, CONTROL MOD KAM ERROR?? | brietwyk | 1994-2003 7.3L Power Stroke | 7 | 07-19-2007 02:08 PM |
| code p0603 internal kar error | bunsorrou | 1994-2003 7.3L Power Stroke | 15 | 08-28-2006 11:40 PM |
| New To Site? | Need Help? | TDG Specials |
