Jiuce up the pump on an 8.3 cummins ? - TheDieselGarage.com
Thread Details Posted by acesneights1, this thread has received 12 replies and been viewed 16137 times.
Old 02-02-2009, 12:22 AM   #1
acesneights1
acesneights1's Avatar
I just bought a 1993 Ford L8000 Oil truck with a 8.3 cummins. The truck is a total dog especially on hills. Not putting any black smoke out at all when under load. I have had L8000s before with 8.3 and they pulled better than this one. Truck runs and starts fine. Very smooth actually, just a slug. How hard is it to turn the pump up a little ? Engine is supposedly rated at 210 HP.
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline   Reply With Quote
Old 02-02-2009, 01:25 AM   #2
french277
Euro Sparky/ Wrencher
french277's Avatar
Si vous avez l'injecteur intégré P7100 le pompent assez facile de le faire et un de notre membre dans a ici l'assez bon détail comment le remonter.
If you have P7100 inline injector pump it pretty easy to do it and one of our member in here have pretty good detail how to turn it up.
Merci,Marc
french277 is offline   Reply With Quote
Old 02-02-2009, 01:33 AM   #3
acesneights1
Merci,Marc
En anglias si vous plais...
Je Parle le francias tres mal...
(I had to break out my 7th grade text book for that... )
Old 02-02-2009, 01:35 AM   #4
acesneights1
I believe it's a bosch pump. Not sure the model.
Old 02-02-2009, 01:55 AM   #5
french277
french277's Avatar
Here read this link http://www.thedieselgarage.com/forum...ead.php?t=7297
It have clear detail how to crank it up.
Merci,Marc
Old 03-07-2009, 02:46 AM   #6
KevinW
Have you tried turning it up yet? I have the same fuel truck and I am looking to do the same thing. The truck is great but very slow. I am just wondering if you folllowed the directions above and how you made out?
KevinW is offline   Reply With Quote
Old 03-07-2009, 10:12 PM   #7
acesneights1
Kevin have someone check the AFC. It's in another thread i did here. I never turned the pump up because after the guy replaced the o ring it was like someone shot the truck full of nitrous. No need to do it now it's pulls excellent.
Read this, it may be your problem it's common.
http://www.thedieselgarage.com/forum...ad.php?t=70403
Old 03-08-2009, 05:11 PM   #8
cummins power
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Check the number on the pump. It will be Bosch, but it might be either the P7100 or the MW pump. The P7100 you can slide the fuel plate etc like on the 12 valve pickups. If it's the MW pump, there will be a large screw on the back with a jam nut. You can turn that in a couple times for some more power with those. Our Case 8920 has a 8.3 with the MW pump.
Logan
1995 12 valve Cummins 6.0L, Air Dog 150, no fuel plate, AFC tuning, 024 DV's, 4K GSK, 18* timing, SDX 5x.014 injectors, Hamilton 181/210 cam and HD pushrods, Stage 2 Port job, 5 angle valve job, 60lb valve springs, ARP studs, O-ringed head, .020" over head gasket, coated pistons, balanced bottom end, Fluidampr, PDI exhaust manifold, homemade intake manifold, HE351cw Common Rail turbo and 50mm wastegate.
Drive Train: 13" Valair clutch rated@600hp, 5 speed, 4x4, 3.55 diffs, on 285/75 R16s
Do Or Die Garage Experiment
cummins power is offline   Reply With Quote
Old 04-09-2009, 08:26 PM   #9
gon2sea
i have a 1996 8.3 with a 3060 allison, installed 3000 rpm governor springs, 0 plate, 7psi more boost adjustment. tons more power and " peppyness " compared to the stock 250 hp i had, feels like a sports car now... BUT, beware of exhaust temps, i installed a pyro and it only takes a few seconds to get the temps over 1250 if you keep your foot into it, i get slight smoke under hard accelleration, but even though i have to back off on grades i still have gained plenty... i wished i found a good part number for a stock bosch 8.3 high hp (375-450 ) marine fuel plate, i think it would maintain the power but bring my temps down by matching fuel better.....
Click image for larger version
gon2sea is offline   Reply With Quote
Old 11-08-2009, 12:27 PM   #10
acesneights1
I still want to do this since trhe truck is still a dog compared to it's brother(my other L8000) with the Big Cat in it. How can I tell if it's a p1700 or an MW ? I can't find any plate. Is there an obviuos way to tell ? Also can the pre boost be turned up like the 3208^T or is this different ? The 3208T I was able to turn up fuel and pre boost separatly.
P7100 pump on a VE cummins XXXcumminsXXX 5.9L Cummins (Pre 1994) 16 03-25-2008 06:11 AM
'95 12v Cummins p-pump Fordpowrstroke7 Whats Been Sold 6 09-26-2007 07:38 PM
cummins lift pump W-900 STUDIO Introductions 8 01-16-2007 02:31 AM
Help with Cummins PT pump. chris142 Medium and Heavy Duty 5 01-13-2007 12:34 AM
I got some Cummins Fuel pump Q's chris142 Medium and Heavy Duty 43 12-07-2006 12:42 PM
