Help now I`m getting p1211 and p1209 code? - TheDieselGarage.com
Thread Details Posted by astro, this thread has received 17 replies and been viewed 8196 times.
Old 02-15-2009, 07:17 PM   #1
astro
astro's Avatar
Well I`m about to blow this truck up!!!!!!!!!!!! I`t was running really good friday after I replaced the icp sensor and added the hpop crossover hose and the map maximizer. today on my way to church the engine light came on with very little excelartion . got home and put the xcal2 on and read codes of p1209 and p1211. What would fix the p1211 code anything? so whats the p1209 code mean? I did check and I do have some oil leaking from the hpop crossover hose. Thanks for any and all input!!
FOR SALE 2002 F250 4X4 Crew Cab Short Bed Lariat Dark shadow Gray W/ Custom Flame Paint Job in Pearl Silver and Purple Tips Pinstriped in Burple. Icon 12.5" Lift with OneUpOffroad 5" Traction Bar Block system, OUO Drive Line Drop Bracket,Clocked Transfer Case, SS Brake Lines, Dual shocks UpFront,Mickey thompson 38X15.50R18 tires, Wels Racing Dune 8 18X10 wheels,Bushwacker Pocket Fender Flares, Reflexion steel hood, ARE Z Series Shell, chrome Tow Hook,Putco Flame Grille, Trenz billet rear Veiw Mirror & Flame Pedals, New Image Flame Gauges, AFE Stage 2 Cold Air Intake, MBRP, Cools Duals T-304SS w/Custom Flame T-304 SS Tips,Autometer Z Series Pyro,Boost,Tranny Gauges,Loud Kenwoo/Kicker 1600 + RMS Stereo System, Husky Floor Liners, More!
astro is offline   Reply With Quote
Old 02-15-2009, 07:28 PM   #2
camojeeper
MAFIA MEMBER 106
camojeeper's Avatar
Send a message via Skype™ to camojeeper
big oil is the only way to get rid of the 1211 most chips and tuners will set it 1209 i think is random its a icp delta test fault re set it and it probably wount come back email joey@terminatorengineering.com for your big oil needs
STEVE TDG MAFIA#106
99.5 psd SDSC 4x Diesel hot rod tug boat. TN BB turbo,230CC 0.0085"EH nozzles GTS HYBRIDS,Pat's tranny,5",Autometers/Scan gauge, ARP'S, DP tuner f-5 ,MAGIC SMOKE PERFORMANCE INTAKE ,AIH delete,Snows water/meth,map sens blowoff,trans lockup,ITP RR w/FB delete oh ya and a detroit locker now with a TWIN PUMP TERMINATOR OIL system
96 CC DRW south bend,DP,MAGIC SMOKE performance,4" exh,Autometer, TERMINATOR OIL
76 CJ-7 B/B FUEL INJECTED AMC 401cid V-8, T-18, D 20 transfer case with 5.38's in the D44's full family cage,ARB air locker rear, lock right front, 37"goodyears steve@magicsmokeperformance.com
MY PICS http://photobucket.com/magicsmokeperformanceJody of DP-Tuner has Driven my truck
camojeeper is offline   Reply With Quote
The Following User Says Thank You to camojeeper For this addition to TDG:
astro (02-15-2009)
Old 02-15-2009, 07:29 PM   #3
Kip
In the passing lane
Kip's Avatar
P1209 Injection Control System Pressure Peak Fault
Don't no for sure about this one but is could free the chip also
P1211 ICP Not Controllable - Pressure Abow/Below Desired
this one is from the chip mine throws it if I get on it I don't know about the sct but dptuner has no code tunes that won't throw them
How does the truck run?
2005 2500HD DIRTYMAX 6in lift, dual exhaust, afe airbox. Tuner soon to come
2001 PSD shortbed crewcab, ATS tranny edge juice w/attitude, Superchips programmer, Gauges, exhaust, 4inch lift w/35s, (SOLD)
Originally Posted by sledneck57
Your sweating like a queer holding a hot dog.lol.
Kip is offline   Reply With Quote
The Following User Says Thank You to Kip For this addition to TDG:
astro (02-15-2009)
Old 02-15-2009, 07:34 PM   #4
PaysonPSD
Payson, AZ
PaysonPSD's Avatar
Maybe the leak in the HPX is causing enough drop in ICP to set these codes under mild acceleration.
PaysonPSD is offline   Reply With Quote
The Following User Says Thank You to PaysonPSD For this addition to TDG:
astro (02-15-2009)
Old 02-15-2009, 07:35 PM   #5
astro
astro's Avatar
What funny is I`ve ran Tadd`s high power tune for over 2 yrs, and maybe every once in a while If I floored it would it throw code 1211 and the engine light come on. Now I can barely put my foot into it and it will bring the engine check light and through codes. Also the truck stays deregulated until I shut it off and then when I restart the engine no light and it runs like its got alot of power until the engine light comes back on. What do you think of this hpop http://www.dieselsite.com/index.asp?...ROD&ProdID=894 ? Thanks for the help!!
Old 02-15-2009, 07:41 PM   #6
Kip
In the passing lane
Kip's Avatar
so when the light comes on your are losing power?
Old 02-15-2009, 07:49 PM   #7
astro
astro's Avatar
YES!!! once I shut the truck down and then restart it then I have power again until the light comes back on. Today I was going up a small hill and was running like 50 mph and it jumped up to about 55 and the exhaust temps went to about 800 degrees and the boost jumped from aroung 4-5 psi to about 8-10 psi and then the light came on and the power went away.
Old 02-15-2009, 07:56 PM   #8
Kip
In the passing lane
Kip's Avatar
it has to be something with p1209 code mine will throw the p1211 and not lose power and if I drive it for about 5 to 10 minutes it goes off
Old 02-15-2009, 08:02 PM   #9
astro
astro's Avatar
This is the first time it has had the p1209 code, before it was only the p1211 and the p1280 codes.
Old 02-15-2009, 08:38 PM   #10
PaysonPSD
Payson, AZ
PaysonPSD's Avatar
Maybe the old ICP wasn't sensitive enough to detect a problem that would cause a 1209 code and the new one is. Just throwing that out there. That is the only new part that has anything to do with ICP codes. You could try putting the old ICP back in to see if you can get back to square one. Don't forget about the relationship the IPR has to ICP. See Attachment.
Also make sure the harness connector for the ICP is clean and that the ICP pins are clean. I would also get the HPX leak fixed before I went any further.
Just trying to throw some ideas out.
Click image for larger version
Name:	PCM-IPR-ICP Relationship.jpg
astro (02-15-2009)
P1209 & P1211 youfarted 1994-2003 7.3L Power Stroke 10 11-10-2014 02:54 AM
p1211 blackcloudCTD95 1994-2003 7.3L Power Stroke 7 02-12-2009 02:14 AM
P1211 code?? Big Bad Stroker 1994-2003 7.3L Power Stroke 4 09-08-2007 04:27 PM
P1211 Code and hard start 6_Myles 1994-2003 7.3L Power Stroke 1 12-28-2006 03:16 AM
