Stuck injector.. - TheDieselGarage.com
Thread Details Posted by blackcloudCTD95, this thread has received 34 replies and been viewed 6266 times.
Old 02-17-2009, 12:49 AM   #1
blackcloudCTD95
Diesel Mafia #67
blackcloudCTD95's Avatar
Stuck injector..
long story short I had 3 injectors to do on one truck today, 1,3,4..... 3 and 4 were good... 1 is stuck..... I pulled both rocker arms off/ head bolts, tried pry bars, slide hammers, hammers, chizzles, every an anything to make it move and its not budging.!
the truck was at ford before for heads, half of the oil log bolts were llose, same as the valve covers and ficm bolts, You cantdrill into the injectros I dont know what kind of steel it is but its some tough chit.! Notto mention the injector was "under" torqued I dont knowif the carbon and soot is whats holding it or if the injector welded its self..
Is there any way to get this mother ^&%&%$& out of the head so I can carry on, with out having to pull the head..?
Click image for larger version
Jordan
95-dodge 2500 built to the hill... - sold to litle brother
03- stroker 6.0 studs and basic BS
blackcloudCTD95 is offline   Reply With Quote
Old 02-17-2009, 01:03 AM   #2
redneck6.0l
powerstrokes rule
you still have the hold down bolt in, when you remove the hold down bolt, it'll slightly push up on the injector
2003 F-350 crew cab 4X4 6 leaker
a few mods
10.56@133
redneck6.0l is offline   Reply With Quote
Old 02-17-2009, 01:21 AM   #3
strokin6L
strokin6L's Avatar
Yeah, shawn is right. In that pic the injector holder bolt is still tightened down. Not sure what year it is but it's either a T-40 or T-45 torx bit.
2004 F-350 XLT SC 4x4: SCT, AFE stage II, autometer gauges(pyro, boost, tranny, fuel), edge insight, CFM large mouth intake elbow, spearco, snow performance water injection, 5" stacks, ARP's, fluidampr, hypermax fire rings, LIPD regulated return, FASS, fuelab, casserly 190's, 64/71/70 turbo(polished compressor housing)modded FICM(ID), Hellmann's sump, electirc fans
strokin6L is offline   Reply With Quote
Old 02-17-2009, 01:23 AM   #4
diesel71
diesel71's Avatar
You said the hold down bolt was loose so chances are carbon has got up into the seat cup. the injector is ruined so here is what i do on those.
stick a 4 x 3/4 bolt into the top of the injector and weld around it. after it cool"s off, use a long ratchet or cheater pipe and work it back and forth to loosen it. then use a long pry-bar on the bolt head to lift it up. you might find the injector tip out of shape and part of the issue. check the seat cup real good and make sure it"s not scored.
diesel71 is offline   Reply With Quote
The Following User Says Thank You to diesel71 For this addition to TDG:
blackcloudCTD95 (02-17-2009)
Old 02-17-2009, 02:09 AM   #5
brentos
I Wanna Go Fast!
brentos's Avatar
um replace the cup once you do get it out
Just another 6leaker Thanks to RCD
http://www.youtube.com/watch?v=tzVhcfZN3jw
brentos is offline   Reply With Quote
Old 02-17-2009, 02:21 AM   #6
blackcloudCTD95
Diesel Mafia #67
I dont have apic on my lap top but.... on the newer model motors there is a clip on the botom of the hold down bolt that eeps in inplace ( so it wont fall out....) Trust me... that bolt is back out all the way....... I cant get a pry bar under the hold down As you loosen up that bolt is NORMALY pulls up te injector.. It backed out but didnt pull up the injector at all......
No doubt for sure if its stuck like that...that cup is probaly warped......
Jordan
Old 02-17-2009, 02:24 AM   #7
blackcloudCTD95
Diesel Mafia #67
SOme years when you removethe hold down the bolt comes out........ they made them collared at the bottom so the bolt doesnt come out of the hold down..... If that was the case dont you think I would have pulled out the T-40 and pried up on the hold down?> Il try that weld thing.. Thanks..!! I do have apic of the diffrent hold downs
Jordan
Old 02-17-2009, 02:52 AM   #8
blackcloudCTD95
Diesel Mafia #67
my cummins did the samething to me... I had to pull the head and DESTROY it to get it out... I WISH there was enough wiggle room to get the hold down out... but theres not... If thats the case I could get my make shift slide hammer in there better to bite on the lip.
How many of you had this problem, I really dont want to pull the cab.....
Jordan
Old 02-17-2009, 03:06 AM   #9
brentos
I Wanna Go Fast!
brentos's Avatar
ive seen/helped put in several sets and never seen it but i bet Josh has
Old 02-17-2009, 04:46 AM   #10
blackcloudCTD95
Diesel Mafia #67
MY boss has never seen this either..... that tech who worked on it should be HUNG.. nev er alod to pick up a wrench again..! I've done my share of injectors, but nothing like this... ill never look at another injector the same
Jordan
Stuck injector copper washer in head jap901 7.3L and 6.9 IDI (Pre 1994) 7 05-02-2008 02:45 PM
injector stuck open doob51 5.9L Cummins (2003-2007.5) 4 04-07-2008 01:50 AM
Stuck Dual K20s The Parking Lot 7 07-31-2007 02:41 AM
Got stuck! ACC inc. 2003-2007 6.0L Power Stroke 18 07-19-2006 08:55 PM
Injector stuck open and flooded engine... Gt-358 2003-2007 6.0L Power Stroke 11 11-06-2005 02:41 AM
