Exhaust back pressure sensor - TheDieselGarage.com
Thread Details Posted by King, this thread has received 6 replies and been viewed 6706 times.
Old 02-23-2009, 03:44 PM   #1
King
My 6.0 is throwing a exhast back pressure code, I have heard there are ways around this sensor. Any ideas?
King is offline   Reply With Quote
Old 02-23-2009, 04:52 PM   #2
cartmanea
What year? All the new computer flashes ignore the EBP sensor and estimate it from other inputs. It may be as simple as spending $100 on a computer update. Some say the older programs have better power and mileage, so if you are concerned about that you might still want to replace the sensor or fix a wiring issue (can be just a harness problem).
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline   Reply With Quote
Old 02-24-2009, 12:56 AM   #3
King
its a 2006
Old 02-24-2009, 12:57 AM   #4
fordboyyfm
catman thats only on the 03s, its called infered ebp, all the rest use it big time. is it doing anything beside throwing the code, runs fine? check a few inches back from the electrical connector for any wire rubs, they will rub on the coolant hose clamp right above it, see if the wires on the electrical connector are purple, if not theres a recall open to replace the connector.
Ford certified diesel tech.
96 F350 reg cab, black. stage Is, exhaust intake TS 6pos chip and a few small tricks. tranny built up a little and a billet converter. 4in lift 35 bfg muds.
3" cowl hood, billet grille, bumper with billet grille and fog lights, 10in drop rear bumper with lights and a dropped hitch.
90 mustang lx 347 afr 185s, vic jr efi, aeromotive fuel system, c4 , 4.10 31 spline, tube k member and control arms coil overs and control arms in the rear, 10pt cage.
05 f250 red ext cab grey int, 4x4 6.0 suncoast tranny, ats 275cc injectors, studs, aeromotive fuel system, turbonetics 70mm ceramic coated turbo, dual 5 inch stacks turnned out. ALL PARTS FOR SALE
fordboyyfm is offline   Reply With Quote
The Following User Says Thank You to fordboyyfm For this addition to TDG:
King (02-24-2009)
Old 02-24-2009, 01:13 AM   #5
cartmanea
I thought they eliminated the EBP sensor on all the 6.0L when that inferred sensor strategy came out.
Old 02-24-2009, 02:11 AM   #6
fordsuperduty01
fordsuperduty01's Avatar
Nope, just on the 03's like mentioned...
2005 F-250 6.0L King Ranch FX4. 125k miles, Edge Platinum, EGR delete, MBRP turbo back exhaust without cat, an 03 turbo, and 4.30 gears.
A.S.E. Master certified automotive and light duty diesel technician.
fordsuperduty01 is offline   Reply With Quote
Old 02-24-2009, 02:45 AM   #7
cartmanea
What was the reason for eliminating it then? I can't see the '03s being the only ones with EBP sensor problems, unless they changed the sensor type after '03.
Exhaust Back Pressure Valve bigdraft 1994-2003 7.3L Power Stroke 32 04-18-2012 04:41 AM
Exhaust Back Pressure Sensor 4cstr 1994-2003 7.3L Power Stroke 27 04-07-2009 05:03 AM
Exaust Back Pressure Sensor bus driver Medium and Heavy Duty 4 02-24-2007 11:58 PM
Exhaust back pressure valve? des6120 1994-2003 7.3L Power Stroke 13 02-20-2007 05:06 AM
Exhuaust Back Pressure Sensor lukesdiesel 2003-2007 6.0L Power Stroke 9 09-22-2005 12:46 AM
