How to turn up fuel on 6.9/7.3 IDI - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > Ford - Modification instructions, Product installs and Tech Articles
Thread Details Posted by 4cstr, this thread has received 22 replies and been viewed 63926 times.
Old 12-17-2005, 10:24 AM   #1
4cstr
Posts: n/a
Points: 0 [Check]
taken from http://www.members.shaw.ca/k2pilot/
Lots of guys have at one time or another wanted to know how to adjust their Stanadyne DB2 fuel injection pump on an idi 6.9 or 7.3 diesel engine. It isn't really difficult to do, but I recommend not messing with the stock setting unless you have a pyrometer. It doesn't take much to overfuel a stock naturally aspirated engine, often with disastrous results.
Safety as always is important. On that note, probably the first thing one should do would be to disconnect the batteries, to ensure there is no power to the pump, or at least remove the wires so that if/when you rotate the engine, it will not start. The adjustment screw lives within the pump, but can be accessed through a little door on the passenger side of the pump. It is triangular in shape, and is held in place with 2 small bolts, and a gasket underneath to seal it. It looks like this.You will want to have either a shallow dish or a bunch of rags under the pump when you remove the plate, as about a pint of diesel fuel will spill when the plate comes off. The next thing to do is to turn the engine to align the adjustment screw internally. This can be done one of two ways that I know of. 1. You must put a large socket (15/16'ths) on the bolt on the front of the crank pulley. Rotate the engine till the timing mark on the vibration damper is at about the 1 o'clock position as seen from the front of the engine. This should line up the insides of the pump so that the adjustment screw will appear in the opening behind where the cover plate was on the pump. Since the crank turns twice for each one rotation of the injection pump however, you may get the timing mark to the 1 o'clock position and still not be able to see the adjustment screw inside the pump. It would look like this. (A small dental type mirror may help to see inside the pump here because of the angles etc)... If you look in and cannot see the adjustment allen screw, you must rotate the engine 360 deg. or one full rotation clockwise, till the mark again lines up at about the 1 o'clock position, and then you should be able to see the screw, and it should look like this. The other way to align the pump, is to take the cover off of the front of the injection pump cover housing. Inside this is the bolts that hold the injection pump timing gear onto the pump. There is also an alignment dowel. If you rotate the engine till this alignment dowel is at exactly the 12 o'clock position, then the adjustment screw will be visible through the opening behind the cover plate. Here's a pic of the opening and the dowel, but with the gear-to-pump bolts removed, and the dowel is at the 4 o'clock position instead of the 12 o'clock. Ok, now, all that is required is to get a good quality allen wrench which fits the adjustment screw(5/32) in size. The adjustment screw has locking threads, so make sure you have a good wrench, 'cause you don't want to damage this one or drop little bits of metal shavings inside your pump. To increase the fuel setting, it is generally recommended to go in small increments. Usually 60 deg. rotation, which is about the same as turning the wrench one flat, or 1/6'th of a turn. Clockwise will increase the fuel setting, counterclockwise will decrease the fuel setting. Put the cover plate back on, being careful not to overtighten the little bolts, replace the wires on the pump, and go for a run to see how it goes. Don't forget to watch that pyrometer!! Good luck with it.
Old 03-15-2006, 06:20 AM   #2
bccanuk
'94IDI Ol' Fhiiiit
Who evertook the time :shrug: -Debogo?4cstr?-all us idi-ers:Thumbup: thank you from the bottom of our mud flaps:bow: for the how to do it: to our fuel pumps:thanks: bccanuk
bccanuk is offline   Reply With Quote
Old 09-22-2006, 04:27 AM   #3
Poppy41348
Send a message via ICQ to Poppy41348 Send a message via Yahoo to Poppy41348
Turning up injection pump
Has anyone tried this and did they notice much of a difference in the performance I would like to try it in my 03 7.3 TURBO JUST WONDERING IF IT IS WORTH THE EFFORT ??
Poppy41348 is offline   Reply With Quote
Old 11-14-2006, 12:38 AM   #4
sexytrkr
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
i had a 7.3 with a turbo. i made an intake and fabed up a DP. I noticed a couple more pounds of boost from that alone. maybe to like 10 as aposed to the stock 7ish. This was a few years ago, so if my #s arnt totally correct, im sorry. after i turned the pump up i was getting something like 14ibs and it would hit 1400 pretty fast. so you need a pyro. and i dunno how a old school 7.3 will do with a constant 14ibs of boost, i didnt hit it but once or twice before i took my foot out of it, so it might have gone further. In short, i noticed a big defferance. but i wouldnt of wanted to tow anything. got really hot really fast.
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline   Reply With Quote
Old 12-15-2006, 07:39 PM   #5
dirkadir35
turn up my 1986 6.9 idi diesel engine
I turned up my 1986 6.9 idi diesel engine by turning the adjustment screw 1/6 turn and I did not notice much increase in power of my old ford. should I turn it another 1/6 inch.
dirkadir35 is offline   Reply With Quote
Old 03-01-2007, 12:50 PM   #6
smokinIH30
smokinIH30's Avatar
I got a 96 7.3 with no gauges. will it be healthy to crank it a 1/6 of a turn?
http://www.hotroddiesels.com/hrdimag...troke_logo.gif 96' F-250 powerstroke 4 inch exhaust to 5" tip, T.S. performance 6 pos chip, stage 1 beans diesel performance injectors , AFE intake, isspro guages,315 Toyo open countrys. Not Cummin' Still Strokin'
smokinIH30 is offline   Reply With Quote
Old 03-01-2007, 04:08 PM   #7
Docluv2577
Send a message via AIM to Docluv2577 Send a message via Yahoo to Docluv2577
your 96 should have a psd not an idi they quit idi production in late 94 and the psd doesnt have this pump
84 f 250 ex cab 4x4 w/92 7.3 ATS turbo 3 in exhaust no muffler K&N filter pumped tweaked 25%
Navistar Diesel electronics specialist( mechanic..lol) 19 years at local dealer
Photos of The Beast
DOC
Docluv2577 is offline   Reply With Quote
Old 06-20-2007, 12:13 AM   #8
montesdiesel354
i have a 6.9 ford 1986 iturned it up 1 flat of the allen wrench i got a little more get up a go but i went back and turned it up another flat and got alot of black smoke and more power :smoke but you need watch you pyrometer to keep from fring your motor
montesdiesel354 is offline   Reply With Quote
Old 06-20-2007, 12:28 AM   #9
86 1 tonhauler
TDG MAFIA MEMBER #72
86 1 tonhauler's Avatar
Send a message via Yahoo to 86 1 tonhauler
i maxed out my screw on my 6.9l and i can cloud out three lanes of traffic
1986 f-350 6.9 dually str8 piped ,maxed out injection pump ,bucket seats, diamond plate flat bed,propane injection, on board aircompressor, train horns,goose neck plate, future mod , custom built turbo kit with intercooler and dual 4" miter cut stacks TDG DUALLY CLUB #5
RIDIN DIRTY #44
01 chevy 2500 HD 4x4 duramax
anybody got any used 4" miter cut stack laying around? pm me if ya do
quote: BARRY1ME: BTW I love your sig about engineers....but it should be changed to, if the engineers believe it isnt broke it doesnt have enough content removed from it. And thats the truth! (FYI I am engineer and work for Ford lol) At Ford the goal is to make the part barely good enough to passing DV (developmental validation) testing....If it passes way beyond the test then the part was overengineered, and content needs to be removed to reduce cost.
I CANT KEEP UP!!! HELP!!!
86 1 tonhauler is offline   Reply With Quote
Old 07-14-2007, 04:01 AM   #10
Sethro
Will this work on a 7.3L IDI that has an agtermarket turbo. Will we see a better resomse that the nonturbo trucks.
Sethro is offline   Reply With Quote
