how to check for a bad injector? - TheDieselGarage.com
Thread Details Posted by 1995nicholas, this thread has received 5 replies and been viewed 6158 times.
Old 03-07-2009, 04:23 PM   #1
1995nicholas
is there any way to check for a bad injector with it still in the engine? when i scan the truck for codes the scanner locks up. the truck has stage 2s in it but the thing just doesn't idle right or run all that good! thanks for the help!
1995nicholas is offline   Reply With Quote
Old 03-07-2009, 05:00 PM   #2
John_G
Super Moderator
John_G's Avatar
There is the KOEO injector (buzz) test and the KOER cylinder contribution test, of those, neither identify WHAT is wrong specifically but give you information about the wiring from the PCM to the injectors (buzz test) and the relative contribution of each cylinder relative to all the others (cylinder contribution). Low cylinder performance can come from any number of causes, just like every other engine.
I vote for LIBERTY!
Old 03-07-2009, 08:22 PM   #3
plainredtruck
plainredtruck's Avatar
Images: 11
Yep, but you have to have the correct scanner. Or you can unhook each one of them and start the truck to see if there's a change. If you find that it idles the same when you have an injector unplugged, then you have an idea that one's the culprit.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline   Reply With Quote
Old 03-07-2009, 10:48 PM   #4
John_G
Super Moderator
John_G's Avatar
You only know which CYLINDER is underperforming, you know nothing at all about the injector, wiring, ICP, fuel pressure, compression etc.
I vote for LIBERTY!
Old 03-08-2009, 01:58 PM   #5
1995nicholas
OK i will try unplugging the injectors to see what happens. i just replaced the valve cover gaskets,wiring harness. i have a fass pump so i wouldn't think its fuel press. hay thanks for the info!
Old 03-08-2009, 10:03 PM   #6
Stroker99
I have a laser thermomiter picked it up at the home depot 30 buck start your truck and point it at you exauhst manifold on each cylinder and it will tell you what one is not contri9buting running bad ect..
99 psd 123000mi supechips programmer 4" magnaflow exausht.
Stroker99 is offline   Reply With Quote
Injector/injector tip specs? Moulder 1994-2003 7.3L Power Stroke 2 01-21-2009 04:35 AM
01 7.3l diy injector kit 86 1 tonhauler Supporting Vendors Forum 1 03-06-2008 04:10 PM
Injector Help Please trick76cj5 1994-2003 7.3L Power Stroke 17 07-11-2007 12:30 AM
bad injector?? help stillcrazyinlaw 7.3L and 6.9 IDI (Pre 1994) 5 04-10-2007 02:10 AM
bad injector? baersmokers 5.9L Cummins (2003-2007.5) 0 01-21-2007 09:12 PM
