wont start, need help with codes P0603 & P1660 - TheDieselGarage.com
Thread Details Posted by kamaleon, this thread has received 12 replies and been viewed 1823 times.
Old 03-08-2009, 03:43 AM   #1
kamaleon
Question wont start, need help with codes P0603 & P1660
Hey guys, my truck slowly died the other day went from normal to lack of power to no power what so ever and eventually dies on the side of the road, this happened over a 400mile trip.
The truck now wont start and has two codes;
(P0603) = CONTINUOUS DTC P0603 INDICATES PCM HAS EXPERIENCED A POWER INTERRUPT IN KAM CIRCUIT. [KAM == Keep Alive Memory]
(P1660 OR P1661) = INDICATES THAT OUTPUT CIRCUIT CHECK IS HIGH OR LOW.POSSIBLE CAUSES ARE:HIGH SYSTEM
VOLTAGE, VREF CIRCUIT FAULT;
I don't understand what they mean or what where to do next.
kamaleon is offline   Reply With Quote
Old 03-08-2009, 04:40 AM   #2
John_G
Super Moderator
John_G's Avatar
Did you check ALL the fuses? It's relatively common for the fuel heater element to short out which causes the PCM fuse to fail. But, you get codes so that's good.
Do the WTS and Check Engine lights come on with the key? If so, that's VERY good.
Next, when you crank it, does the tach indicate RPM? If not, you may have simply a bad cam sensor.
P1660/1 indicates a short in an output circuit from the PCM, IPR valve and EBP solenoid are the two main ones and if one is dead shorted, that would keep it from starting.
I vote for LIBERTY!
Old 03-08-2009, 04:09 PM   #3
Pocket
Sounds like a power/voltage issue, either external with the alternator or batteries, or internal with the PCM or wiring.
Pocket is offline   Reply With Quote
Old 03-09-2009, 04:25 AM   #4
LQHauler
My 97 is popping the same code. I just had a Sniper chip, new valve cover gaskets, wiring harnesses under the valve covers, and a glow plug relay. It drove fine and now I have codes P0603, P1391 & P1393. Now my truck for start. It turns over good but I don't get a "Wait to Start" light and the glow plug relay doesn't click. I have checked all the fuses (ohms test) all are okay. Could it be the new Sniper chip?
Thanks,
Matt
LQHauler is offline   Reply With Quote
Old 03-10-2009, 08:15 PM   #5
kamaleon
A friend is comoing over today with a better scanner.. The ses light is not on but there are codes stored, we are going to erase those codes and start new.
From the research i done, code P0306 is not very important, power loss from batteries, i did had bad batteries two months ago but never saw any ses light then now now.
The next code is somewhat tricky as it could be a number of things, once i get to run more test later today i'll be able to zoom in into the actual problem(s)
The wait to start light is working fine, as is the ses light. Tach does move when cranking. I dont think its got to do with wiring, the truck slowly died in the course of 400 miles.
Old 03-11-2009, 01:39 AM   #6
kamaleon
puzzled at a higher degree
I just ran a few test on it with a genesys system scanner with software v2.0
Injector Control pressure: peaked at 2600
Injector Press Reg duty Cycle %: when keywas at the on position it read 15% and raised to 39-44 when engine was cranking..
so, do i have a high oil pressure leak and also starving for fuel??
PS. i disconnected the batteries and removed the chip, the only code in the pcm was the 0306 related to power failure, once deleted from the pcm no code ever came up after cranking the truck for 5-6 times. So, i have no codes now?!? :
Old 03-11-2009, 02:41 AM   #7
Pocket
Fuel, not oil. Oil pressure will rise like that when you are cranking, especially if there's no fuel.
Check to see if you have fuel in the bowl.
Old 03-11-2009, 04:24 AM   #8
kamaleon
there is fuel in the bowl and i can see the bowl fill up when key is on.
Old 03-11-2009, 01:20 PM   #9
Pocket
Do you see smoke when cranking?
Old 03-11-2009, 01:29 PM   #10
kamaleon
nope, no smoke at all when cranking
Wont start??? ccoxva 5.9L Cummins (Pre 1994) 1 02-25-2008 03:45 PM
need help wont start clay 5.9L Cummins (1998.5-2002) 12 01-22-2008 03:39 PM
97 wont start Fireguy 5.9L Cummins 12 Valve (1994-1998.5) 5 10-25-2007 12:32 PM
97 F-250 wont start Strokin05 1994-2003 7.3L Power Stroke 18 10-11-2006 10:02 PM
05 wont start twin_turbocummins05 5.9L Cummins (2003-2007.5) 11 04-21-2006 09:27 PM
