Gear Splitter for NV4500 - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins 12 Valve (1994-1998.5)
Thread Details Posted by Jawbone, this thread has received 17 replies and been viewed 10259 times.
Old 03-13-2009, 10:39 PM   #1
Jawbone
Does any one know if it possible to put a gear splitter off of a medium duty truck on too the nv4500. Basically what I am looking for is an overdrive gear splitter but I'm not sure if it is even possible to do. I tried searching for some threads on it but it seems that know one has brought this topic up. If anyone has any alternate options that they like better than the gear splitter or if you have any idea about which one would be a good for the nv4500 please let me know.
thank you,
Grady
Jawbone is offline   Reply With Quote
Old 03-14-2009, 03:35 AM   #2
Farmboy's Diesel
Farmboy's Diesel's Avatar
Gear Vendor makes one thats an under and over.
1994 Dodge 2500 reg cab 4x4 5 speed, On board air, Grover air horns, riderite air bags and a 3" leveling kit.
Go Parts
P7100 built by Redline Diesel Power, 18* timing, #10 plate, 3k gsk, edm'd DV's, .093 injection lines, 370 marine injectors, head milled and o-ringed, AIS Water/Meth, HX-52 charger, Custom 5" downpipe to 5" Mitre Cuts, K&N Cold air intake, held back by a Valair 13" Ceramic/Kevlar clutch.
445hp and 1076ft-lbs on the stock turbo. 5-2-09
Farmboy's Diesel is offline   Reply With Quote
The Following User Says Thank You to Farmboy's Diesel For this addition to TDG:
NukleusX (03-14-2009)
Old 03-14-2009, 03:44 AM   #3
NukleusX
I like beer.
NukleusX's Avatar
Send a message via AIM to NukleusX Send a message via Yahoo to NukleusX
yeah, get in touch with them. probably your best bet.
Jeremy
94 Ram 2500 4x4 RCLB.
Power: BHAF, 4" exhaust, S300G, 15.5*, 100 plate, 90 hp sticks, 191 dvs, Mike L. trans. more when i remember.
Appearance: 1 pc headlights, HIDs, 4.5" lift, flippy mirrors (up), not so chrome 6" silverline exhaust tip, not so fancy aftermarket wheels
American Club #33
Singles Club #74
TDG Mafia #111
http://www.socaldieseltrucks.com
NukleusX is offline   Reply With Quote
Old 03-14-2009, 05:47 AM   #4
cummins power
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Gear Vendor makes a Underdrive to Direct set and a Direct to Overdrive set. I looked into them for a while, but then found out that they are rated to "only" 700 ft/lb of torque input. If you stay mostly stock you'll be ok, but I'm already far out of that range on the output.
Logan
1995 12 valve Cummins 6.0L, Air Dog 150, no fuel plate, AFC tuning, 024 DV's, 4K GSK, 18* timing, SDX 5x.014 injectors, Hamilton 181/210 cam and HD pushrods, Stage 2 Port job, 5 angle valve job, 60lb valve springs, ARP studs, O-ringed head, .020" over head gasket, coated pistons, balanced bottom end, Fluidampr, PDI exhaust manifold, homemade intake manifold, HE351cw Common Rail turbo and 50mm wastegate.
Drive Train: 13" Valair clutch rated@600hp, 5 speed, 4x4, 3.55 diffs, on 285/75 R16s
Do Or Die Garage Experiment
cummins power is offline   Reply With Quote
Old 03-14-2009, 01:28 PM   #5
bmoeller
bmoeller's Avatar
Most likely the ONLY way you could use a MD unit,would be to divorce mount the t-case. Have short shafts run between the trans and t-case. All it takes is money.
"Obama = Hoax and Chains"
Old 03-14-2009, 03:07 PM   #6
mudguppy
Tebow-in'...
mudguppy's Avatar
don't forget about US gear.
edit: and, i think you can downshift and utilize engine braking w/ the US gear unit. i have heard that you cannot on the gearvendor unit.
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline   Reply With Quote
Old 03-14-2009, 04:48 PM   #7
later
Retirement
I can see the need for a extra gear box if you are going to stay with a some what stock engine, but couldn't you just add a turbo, injectors and do a little pump work and end up with the same drivability, more power and easyer to drive? If you are set on this you could allways look into a 6 speed or a fuller 7, or 10.
later is offline   Reply With Quote
Old 03-14-2009, 06:07 PM   #8
cummins power
Hot Rod Farm Boy
I turned 21
I don't think he's going for more power. Besides even if he was, a overdrive wouldn't add any. I'm guessing he wants another gear for better mileage and a splitter for towing with less drop in RPM at shifts.
Logan
Old 03-14-2009, 06:18 PM   #9
Jawbone
Ya thats exactly what i was going for, I do a ton of highway driving because i commute for school everyday and im around 2100 rpm at 70 and if i could drop that down I'd be happy. Also i live in the city with a bunch of hills and sometimes my gears really get hindered by the hills. Ya it does seem like it's more trouble than its worth, my friend ran the idea by me and I wasnt sure if it was possible. Gear Vendor does seem like a good bet but my truck is rated for about 750 ft/lbs and I dont think i would want to risk that about of torque on it. I really appreciate yalls imput. I really thought the one manufactured by US gear would be the best bet. Have any of you hear of anyone pulling one from a medium duty truck in a junk yard?
Old 03-14-2009, 11:16 PM   #10
later
Retirement
More torque and RPM would solve the problem. If it is a stock truck and you want to stay as close to stock as possible, just add a 3K GSK or a 4K GSK that way it does not stop adding full fuel until 2700 or 3600. The 4K gsk will require 60 lbs springs on at least the exhaust. The Governor Spring Kit will make you fell the difference, and shift gears less. A GSK will not make you change a clutch or change the drive line.
To get more torque you will need a new clutch soon and to get it you can slide the fuel plate change the DV's and holder then get larger injectors, DV's and Holders are optional.
If it was me and I did not feel like getting more power I would add the RPM with a GSK if you install it yourself it will cost 150 dollars or less and take a afternoon, taking you time and reading the instructions. Also add a little timing say to 14.5 degrees it will help.
Tags
12v, gear splitter, nv4500
nv4500 stuck in 5th gear baker9713 5.9L Cummins 12 Valve (1994-1998.5) 4 08-28-2009 02:28 AM
Nv4500 TheNightmare 5.9L Cummins 12 Valve (1994-1998.5) 2 03-11-2008 01:28 AM
To re-gear or not to re-gear, that is the question Lonesome7.3 1994-2003 7.3L Power Stroke 99 02-28-2008 06:05 PM
zf5 vs. nv4500? danktank6.9 7.3L and 6.9 IDI (Pre 1994) 6 02-22-2008 11:27 PM
help need a nv4500 CGCUMMINS 5.9L Cummins 12 Valve (1994-1998.5) 3 11-26-2007 10:46 PM
