| Thread Details Posted by 4cstr, this thread has received 13 replies and been viewed 7871 times. |
#1 |
Advance timing on a DT360-530
This will cover DT360, DT408, DT466, DT530, as well as many other engines, but timing marks and access may be different.
The 93-97's with the Bosch P-pump: On the front of the pump (timing case)is a 3 bolt cover (8mm heads)that you remove. This is the picture below looking down on the engine & the alt belt looks red(funky camera). This cover has an o-ring and is usually good for reassembly without replacing. P-pump equipped: Inside is the 13mm headed bolts that set the timing, & there's 4 of those bolts. Before you loosen the bolts, mark the original timing setting for reference with a sharpie or such. Crank the engine over at the alternator(you may need to hold the belts tighter, plus it turns better one way than the other) until you can insert a 1/4" bolt or equal size phillips screwdriver to stop the engine from turning(by hand, not with starter!). The pilot hole is in the slots of the gear at 3 o' clock as you look at it from the front. The bolt will slip in as the timing comes into its spot. Now, break the gear bolts loose, but keep 1 of them tight. Slowly crank the engine over until it snugs up on the bolt. Loosen the last bolt, they dont need to come out, just backed off a few turns. Mark your starting timing on the balancer now before you move the engine. Then if you can read the balancer, go the desired number of degrees in the same direction the alt will let it turn(which will advance the timing), and that's CCW. Tighten the gear bolts up, remove the bolt that was pinned in, and put the cover back on. The older ones have about 8 or 10 bolts to remove the cover from the timing case. I think there's 2 sets of bolts that have nuts on the back side. You may need to re-gasket the cover before re-installation. Remove the plug on the side of the timing gear case, it has a 3/8" square drive. In there you will be lining up the timing marks. Very helpful to have a second person here. Bar the engine over from the alternator until the timing marks are lined up on the pointers, the will look like this: >< when it's lined up. When you have that, mark on the balancer or make note of your original setting. Now loosen up the bolts(don't remove) on the gear, after you pull off the front cover, but leave 1 tight. Bar the engine over from the alt. to advance slowly until desired amount of degrees. If no timing marks to go by, measure 1/8" per degree. Loosen the last bolt on the gear, and line the marks back up using the big nut on the front of the pump. Then, tighten the gear bolts back up, put on the front cover, and timing plug. I made a video if this down in post #14 below. The 4 bolts on the timing adjustment need to be pretty tight, but be careful not to go too tight & break one off(specs say 38 ft lbs). If yours is set at 17* timing from the factory, you may not even notice any benefit, this is more for the 10-15* timed engines. The goal is to be around 17-19* advanced timing and after you've upped the fuel rate some. Last edited by nevrenufhp; 01-16-2010 at 05:45 PM. Reason: totally revised and the video is on post #14 |
#2 |
Fleet Mechanic
Its stuff like this that make this site great
You're only given a little spark of madness. You mustn't lose it. Robin Williams :splat |
#3 |
Super Moderator
![]() Join Date: May 2005
Thanks!
If I had better access to these engines, I'd have better pictures, and be able to do more of a walk thru type of instruction.
daily driver:67 F100, 300 4V, 4 spd. swapping in a Ford 6.6 from 92 F600 work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing or, 06 IH 7400, DT466E, 300hp My Low Buck fuel rate site: www.freewebs.com/nevrenufhp |
#4 |
#5 |
dt466 Timing
I'm trying to find how to time a new pump out of the box. The person who removed the old pump set the crank at t.d.c. but did not mark the timing gear. He thought it had permanet marks on the gears. How do I set the pump to the desired 17-19* advanced position while on the bench? It's a '95.
#6 |
Super Moderator
![]() Join Date: Dec 2008
You set the PUMP at "TDC" and the CRANK at 17*-19* BTDC, just make SURE you are on the COMPRESSION stroke of #1 when you do this, or you'll have to try a second time with the crank rotated 360*! Don't ask how I know - LoL.
There are no marks on the pump gear to the idler gear, you align the timing mark on therear of the IP gear to the pointer under the plug in the driver's side of the front cover (3/8" female square drive plug), with the CRANK set at 17*-19* BTDC, you slip the pump on with the drive gear bolts LOOSE so the timing mark in the hole lines up with the pointer in the hole, THEN Tq the gear bolts down.
Support - Trailer brakes an every axle over the towing vehicle's GVW! |
#7 |
Thanks for the reply John
My problem is I can't seem to locate any plug in the cover or any 3/8" square drive plug anywhere. |
#8 | |
Super Moderator
You have a '95! DOH! You set the crank to the desired timing (BTDC) than remove the gear cover and there is a "5th hole" in the IP gear, from memory, you install a 1/4" bolt thru that hole in the gear and into the coorisponding hole in the rear half of the front cover - THEN tighten the four bolts on the IP drive gear. Sorry for the confusion.
#9 |
Found it. . Thanks. .
#10 |
Super Moderator
Hopefully this revised version will work for most of you a little better.
