4WD conversion - TheDieselGarage.com
Thread Details Posted by TLadd, this thread has received 5 replies and been viewed 3733 times.
Old 03-17-2009, 02:51 PM   #1
TLadd
4WD conversion
I've got a 1997 Ford F-350 Crew Cab, Long Bed Dually and I was wondering if it would be possible to convert it from 2WD to 4WD. I'm wondering if it is possible if I used the front axle out of a 1993 Ford F-350 4x4 Dually; If so, could I attach it at the factory mounting points or are the 2WD front frame rails different from the 4WD? Also, What would I have to do to put a transfer case in the truck; can I convert the existing automatic E4OD or would I have to get the 4x4 model?
TLadd is offline   Reply With Quote
Old 03-18-2009, 04:18 AM   #2
sexytrkr
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
i think, that you can swap everything from one truck ot the other. Thats what most people do, just get a donor truck, park it in the driveway next to the truck being donated to, and make a weekend of it. Although, if i remember right, the front axle on OBS trucks isnt very desirable and i think most people swap them for solid front axles instead of that twin Ibeam setup. But it will get you 4x4 either way. If you do decide to make it a 4x4, make sure you take pictures for us. I think the OBS crew cab dually 4x4s looks SWEET! but they are rare for some reason.
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline   Reply With Quote
Old 03-18-2009, 04:26 AM   #3
JoeDirte
I'm just thinking that it may be easier and cheaper to sell yours and then find a 4x4 truck. That's just me. I'm a bit older and don't have that kind of time or energy. I got too many projects as it is.
JoeDirte is offline   Reply With Quote
Old 03-18-2009, 04:29 AM   #4
sexytrkr
truckn'
sexytrkr's Avatar
Old 03-18-2009, 04:45 PM   #5
CSIPSD
CSIPSD's Avatar
Sell the donor truck, buy the front axle assembly out of a 05 and up SD and go to town...
01 F-250 SC PSD,210k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, GTS Hybrid injectors, Studs, 910 Valve springs, Forged rods Water injection,Swamps tuned, MBRP 4" dual's, Aero, 6" tip's, 100 axl tank, 4" Revtek lift, 37-14.50-17 TOYO MT's 469hp and 1068tq...
ISSPRO PERFORMAX GAUGES
CSIPSD is offline   Reply With Quote
Old 03-19-2009, 12:32 AM   #6
Zaairman
Mod Friendly Title
Zaairman's Avatar
Send a message via AIM to Zaairman
Ford never made a dually 4x4 from 1992-1997, so if you found a 1993 dually it has been converted from one to another (either SRW to DRW or 4x2 to 4x4). Also, the F-350 will have the solid front axle that the F-250 owners always swap in place, so you're good there. I don't know about the frame rails, but if you've got the skills to swap in an axle then mounting the springs and such shouldn't be a problem for you. And unless you plan on running a divorced T case, you're going to need a 4x4 E4OD.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust (video clip), DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, X Code Springs, 33" BFGs (SUCK), Alpine W200, Pioneer "D" Series Kevlar 6x8"s, Sirius Satellite Radio, 12" Memphis Pro Audio Subwoofer.
20x10 Mickey Thompson Classic IIs, waiting on tires
SLAPS Member #153
Just because I kiss the prettiest girls and I drive my truck too fast, why does everybody want to kick my @ss?
Donut Video
Zaairman is offline   Reply With Quote
2wd to 4wd conversion DeanF250diesel 2003-2007 6.0L Power Stroke 10 01-19-2008 07:59 PM
conversion or buy used?? jmccall Diesel Conversion 12 10-08-2007 11:14 PM
Conversion to WVO scuby22 5.9L Cummins (1998.5-2002) 5 07-07-2007 01:37 AM
6.9L to 7.3L Conversion????? 86-97Conversion 1994-2003 7.3L Power Stroke 4 07-03-2007 03:40 AM
4bt conversion. Adair2k5 General Diesel 9 02-16-2006 03:55 PM
