3406b fuel in oil - TheDieselGarage.com
Thread Details Posted by Billy359, this thread has received 30 replies and been viewed 10418 times.
Old 03-26-2009, 05:28 PM   #1
Billy359
3406b fuel in oil
Hi, I have a 3406b 400 cat 7fb serial. The engine is pushing major fuel into oil, i'm talking 4-5 gallons in 100 miles. No smoking,rattling, or missing. Took valve covers off for about an hour watched lines, adapters, and nozzle retainers for leaks. Nothing. I was expecting to see fuel spraying everywhere. So could the problem be a nozzle under the retainer, transfer pump, or injection pump? Is there a simple way to test without disassembling everything? P.S. I had an o-ring under a bonnet on top of injection pump go bad, Caterpillar replaced o-ring.
Billy359 is offline   Reply With Quote
Old 03-26-2009, 10:14 PM   #2
John_G
Super Moderator
John_G's Avatar
The transfer pump would be my first guess since the MAJOR leak was not obvious with the VCs off.
But, you can take a syringe and needle (from the Farm-Fleet store etc) and pull some "oil" from around each injector and look to see if any one has an obviously different color indicating fuel. If that is inconclusive, take a CLEAN WHITE rag (towel) and place a drop or two of "oil" from the syringe on it and wait a couple minutes. If you see a ring of golden fluid around the black oil spot, you have fuel.
Obviously with that much fuel in the oil you would be looking for one "spot" to have a much more pronounced golden ring than the others.
Good luck!
I vote for LIBERTY!
Old 03-27-2009, 02:38 AM   #3
chriscap6688
chriscap6688's Avatar
Good luck!
thats my first guess but if its not then look at an injector stuck open you can use a test light to see the light sould fash when running on each injector if it stays lite then injector is open
chriscap6688 is offline   Reply With Quote
Old 03-27-2009, 04:15 AM   #4
SmokinCAT
SmokinCAT's Avatar
B model injectors arent electronic.
Cody.
79 KW W900A 3406B, Holset HC5 turbo, RTO12513,
4.11 SQHP rockwells
79 KW K100C 400BC1, Holset HT4B hybrid, custom
injectors, RTO12513, 4.33 eaton DS380s
00 Freightliner Classic XL C15
SmokinCAT is offline   Reply With Quote
Old 03-27-2009, 06:46 PM   #5
ynot
The other guy
Good job John!! Very “Cattish” of you!!
Question. Does it miss? Was someone in the pump VERY recently? There are three places to look. The most common is what John said, tho you should see fuel just running out the spanner wrench holes for the nozzle adapters. It’s obvious what it is when you see it. If that is the case, replace the screws for the bleeds along with the washers. The screws crack at the head. $65 with nozzle dam seals for re-installation.
Second is the seat between the spacer and the barrel and plunger in the injection pump. Won’t happen unless someone was just in there and FUBAR’d.
Third is a broken tappet in the transfer pump. Just drop it down and wiggle the tappet plunger (steel thing stickin out the top).
If it’s a nozzle and it’s runnin down a liner wall, you wouldn’t be driven it. Good luck!!
ynot is offline   Reply With Quote
Old 03-27-2009, 09:27 PM   #6
ynot
The other guy
Not to mention Lucas type (big truck) injectors are 120vlt +/- A/C, so better be one hell of a test light!!!!!
Old 03-28-2009, 06:06 AM   #7
french277
Euro Sparky/ Wrencher
french277's Avatar
Yeah Tony it is true and due I am electrician by trade and diesel mechanic second part however let me warn all readers anytime you open up the valve cover on any I say any electronic diesel engine expect pretty high voltage system in there I know I did work on one industrail engine that do run on about 315 volts or so AC and it have warning label near the electronic control panel.
I useally don't like to tell too many peoples a secrect how I do the testing on the Lucas electronic injector all I just used a common neon test light* and watch the flashing light when it blink on you know it working if steady on you have a bad controller or if not lit up either you have open connection or shorted connection somewhere in the system if you did get a short it will affect the next firing order.
Now get back to the OP situation my first guess will be injector transfer pump I know some of the them have O-ring in there and go bad over the time.
To troble shooting that unit follow Ynot's details he have right answer there.
Merci,Marc
* for test light make sure you get one it can read high as 240 volts and the other thing that if you getting DC instead of AC one side of neon light will be lit not both side of electrode.
french277 is offline   Reply With Quote
Old 03-28-2009, 06:33 AM   #8
ynot
The other guy
Merci,Marc
This is a cool thread, and gettin better
BTW Marc, all the motors here have the same warning sticker on em that shows the little stick guy gettin fried and falling. Kinda funny. And here they're all purdy set at 120vlts, but it's A/C, so you don't have the ground thing to save you if you get shocked. You just get blasted!! Cummins are the only ones sealed... Good job up there too man ^^
Old 03-28-2009, 06:04 PM   #9
french277
french277's Avatar
Merci, Ynot.,
However ., let me pass a detail or two more along the way here.
Most of the electronic injector are " floating " power system which it mean that the system is not grounded at all not like the spark ingited engines the power source go to the electronic injector and go back to the controller aka ECM or Injector driver module one of the two.
Just want to remind all readers anytime you get near the wiring harness for electronic injector be extra carefull if you have to wiggle or check the connection make sure the engine is off and key is off postion { most ECM or injector driver do have some storta of setting that you need X of RPM to order to get them on }
Ynot let me chime in a trick here if you did verified that you get voltage to one of the electronic injector but the injector not firing properly a trick is get the clamp on anlog ampmeter and watch the neddle on the scale jump if not jumping then you have open coil in the injector if jump way too high then you got shorted coil.
( you should able get the factory spec for current drawage )
Merci,Marc
Old 03-28-2009, 07:20 PM   #10
ynot
The other guy
Merci, Ynot.,
Merci,Marc
Thanx bro, and again, good job!! Actaully, I'm still stuck on the "neon" test light. Thought I had everything, but maybe not. Could it be a "diode" test light?
3406B cat I need help nova76kt Medium and Heavy Duty 8 01-27-2008 09:45 PM
3406b Cat Help Farmboy12 Medium and Heavy Duty 3 01-18-2008 04:22 AM
Help-cat 3406b Fuel Inj-pump Removal From Engine Front Drve Cover omarcano5 Medium and Heavy Duty 4 03-04-2007 01:47 AM
3406B turning up the fuel SmokingIDI_7.3L Medium and Heavy Duty 35 10-29-2006 02:37 AM
3406b jimmyjack Medium and Heavy Duty 12 09-08-2006 12:13 AM
