Mack EM6 Engines 300 and 350 - TheDieselGarage.com
Thread Details Posted by cumminsdude2001, this thread has received 25 replies and been viewed 17023 times.
Old 03-30-2009, 11:54 PM   #1
cumminsdude2001
How to you turn the fuel up on thease injection pumps? They are set different, not the p-pump like in the EM7 engines. Thease mack trucks with thease injection pumps are in the 1980's. The only thing I know how to do is shim the puff limiter. Anyone know how to turn the fuel rate up on thease pumps?
cumminsdude2001 is offline   Reply With Quote
Old 04-04-2009, 12:05 AM   #2
nevrenufhp
Super Moderator
nevrenufhp's Avatar
Wish I knew. Maybe if you had a pic of it, it may jog someone's memory.
Dale
my daily driver:67 F100, 300 4V, cammed, 4 spd.
or, 08 VW R32.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
Old 04-04-2009, 02:36 AM   #3
fjh
Yup remove the six bolt cover at the top back of the pump!
You'll find a stop with two jam nuts 1/2 inch wrench size!Loosen the the back one three or four flats of the nut and tighten the front one reinstall the lid and try it!giver a little more if ya need a little more!don't exceed 1150 0n the pyro if you don't got no pyro, get one!Ya want to end up making about 22 - 25 psi boost!Don't got no boost gauge? Get one!
If ya need More info on this post over here http://www.bigmacktrucks.com and Lmackatack has a write up with pics that should straighten ya right out!
fjh is offline   Reply With Quote
The Following User Says Thank You to fjh For this addition to TDG:
Sean Minor (07-01-2013)
Old 04-04-2009, 05:49 AM   #4
Lmackattack
Highway to Hell
Lmackattack's Avatar
check this thread out... I made a write up after FJH walked me thru it
http://www.thedieselgarage.com/forum...417#post442417
1978 MACK RS700L
285 HP @2100 RPM 1080 TORQUE. @1200 RPM
2 STICK 6 SPEED, 4.17 REARS ON 34K CAMELBACK SPRINGS,206"WB, 4" STRAIGHT STACKS BLOWING BLACK,
OH...AND A FEW TWISTS OF THE FUEL SCREWS ....THANKS AGAIN... FJH!
Lmackattack is offline   Reply With Quote
Old 04-04-2009, 11:48 PM   #5
fjh
thanx bro!
Lmackattack (04-05-2009)
Old 04-08-2009, 08:20 PM   #6
acesneights1
acesneights1's Avatar
Man, where was this forum 10 yrs ago when I was driving a one stack Mack with a window in the back...
Mine was a dog. It would howl at night....
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP.
1998 GMC 2500 Burb 6.5td 4inch ex Autometer fullsweeps.
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline   Reply With Quote
Old 04-09-2009, 01:33 AM   #7
theakerstwo
fjh not what to change the subject but can you tell me what the O/D is on a T2090? And also the flywheel teeth count on a E6 would it be 118? thanks glenn
theakerstwo is offline   Reply With Quote
Old 04-09-2009, 03:02 AM   #8
Lmackattack
Highway to Hell
0.71 in top gear for the 2090 and 2090B
the 2050 2060 2070 had 0.60 in top gear...some of the "fastest" class 8 transmissons built but put in the slowest trucks made !
1978 MACK RS700L
Old 04-09-2009, 06:42 PM   #9
Freightrain
Gear jammin fool
Freightrain's Avatar
Had something to due with the 7.50 gears out back? !
United Manual Transmission Racers
2006 UMTR Points Champion
2009 UMTR Points Champion
Built like a MACK truck
1959 B61 Mack
Freightrain is offline   Reply With Quote
Old 04-10-2009, 12:24 AM   #10
fjh
My goosh Glenn you ask complicated questions! I have never sat down and counted the teeth on a flywheel on anything Ever! The OD thing I try not to clutter my mind with them kind of facts,There is to much Rubish coming down the pipe to store info like that for me!This EGR trash has amoust taken the place of all the old info ,Kinda like pushing marbles in a tube, sooner or later one goes in one comes out! Dam I had to pass off turning up a fuel Pump to one of my students Trent.Thats how bad its getting!
1981 Engines Gillig8V71 General Diesel 2 03-16-2008 07:45 PM
6.0 and 7.3 Engines JMS8800 Whats Been Sold 5 04-28-2007 04:47 PM
12v engines fordfreak84 5.9L Cummins 12 Valve (1994-1998.5) 2 06-15-2006 05:31 AM
Ford 370 4V M/D gas engines Duke Medium and Heavy Duty 11 04-21-2006 05:50 PM
