fuel coolant reservoir question - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > 2008-2010 6.4L Power Stroke
Thread Details Posted by deebarjay, this thread has received 6 replies and been viewed 7845 times.
Old 04-19-2009, 03:01 PM   #1
deebarjay
deebarjay's Avatar
bought my truck last friday april 17th....an 08 f 250....started the learning process of whats under the hood..on the fuel cooler,is the system under pressure? i couldn't tell by looking into the peep hole if the quantity was there so unscrewed the cap and had coolant run out of the overflow..so was just curious about this...maybe just overfull ?? or is there pressure in there ???
deebarjay is offline   Reply With Quote
Old 04-19-2009, 04:12 PM   #2
DINOONE
Diesel Addict
DINOONE's Avatar
Fuel or Engine Coolant?
2008 Harley Davidson F250 16" Custom Lift, Modded to Hell and beyond! "CEREAL KILLA"
Truck FOR SALE:
http://cgi.ebay.com/ebaymotors/ws/eB...category=39415
DINOONE is offline   Reply With Quote
Old 04-19-2009, 04:29 PM   #3
forcefed6.4ford
I Eat Rice
forcefed6.4ford's Avatar
the fuel cooler uses coolant to cool the fuel before it goes back to the tank. It should be pressureised by the cooling system... I think.
Lets just say not quite stock.
Slower than some. Faster than most.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
"There is no try. Only do... That is why you fail" Yoda. The wisest green piece of rubber ever created.
2008 King Ranch/Harley mix. Spartan tuned. Elite studs, Cobbs EGR delete plates. FabTech 6" 4 link with dual 2.25" remote shocks. 18" 778 Monsters 35-12.5-18 Toyo MT's DDM 35w HID's 6000K hi/lo and fogs.
forcefed6.4ford is offline   Reply With Quote
Old 04-19-2009, 06:36 PM   #4
deebarjay
deebarjay's Avatar
well....if you look at the capacities in the book it shows the engine coolant at 30 quarts and fuel cooler at 2 quarts....2 different systems...not inter connected....the fuel cooler his its own fill cap.
Old 04-19-2009, 09:44 PM   #5
KJR0360
KJR0360's Avatar
I was also looking over mine today (got mine a little over a week ago). The cap on the fuel cooler says it's 20 psi, higher than the 16 psi for the coolant system. I didn't have time to follow the lines but you are correct about the 2 qt. capacity. Seems like there seperate but can't figure out why or how. Need to do more investigation. This new engine is way different from the old 6.0. I thought the 6.0 was tough to work on, Ford didn't leave any room in this one.
08 F-250 SC Lariat 4x4 6.4l, Spartan tuned, DOC/DPF delete, S & B CAI, Amsoil oil by-pass, coolant filter
R.I.P. 03 F-250 SC XLT 6.0
KJR0360 is offline   Reply With Quote
Old 04-19-2009, 10:39 PM   #6
fordboyyfm
yea separate and it has a small electric pump, so it will get under pressure. 6.4 uses high pressure fuel not oil like the 7.3 and 6.0s and when it gets up to real high pressure it gets real hot.
Ford certified diesel tech.
96 F350 reg cab, black. stage Is, exhaust intake TS 6pos chip and a few small tricks. tranny built up a little and a billet converter. 4in lift 35 bfg muds.
3" cowl hood, billet grille, bumper with billet grille and fog lights, 10in drop rear bumper with lights and a dropped hitch.
90 mustang lx 347 afr 185s, vic jr efi, aeromotive fuel system, c4 , 4.10 31 spline, tube k member and control arms coil overs and control arms in the rear, 10pt cage.
05 f250 red ext cab grey int, 4x4 6.0 suncoast tranny, ats 275cc injectors, studs, aeromotive fuel system, turbonetics 70mm ceramic coated turbo, dual 5 inch stacks turnned out. ALL PARTS FOR SALE
fordboyyfm is offline   Reply With Quote
Old 06-10-2009, 04:13 AM   #7
rod.10853
rod.10853's Avatar
Yep, it's a separate system. I recently had a whining noise coming from
the pump a few days after having Ford do a bed plate seal oil leak
repair job. I took the truck back to Ford for the whine, and the
mechanic said that it was due to air cavitation in the system that had
formed in the pump. Supposedly there was air working it's way through
the system after the engine had been pulled and flipped and all from
earlier bed plate seal work. Anyway, the mechanic took the truck back
and said he bled out the air and topped off the coolant and the whine
went away.
The whine stayed gone for about three weeks. It came back yesterday.
I took the truck back to Ford and questioned the mechanic more about
the system, and that's when he told me it's completely separate from
the engine cooling system. Also, he said that the fuel coolant reservoir
was low again and there was air in the pump. He said that now he thinks
that the system is loosing coolant from somewhere and sucking air in.
Also, he said the pump was loose and he went ahead and ordered a
new pump to be installed when it gets in stock.
I didn't get a chance to ask him any more questions, but I wish I
could have asked him exactly what he meant by "the pump is loose".
Also, where is the pump exactly? Is it down in front at the bottom
by the radiator? Because that is where it sounds like the whine is coming
from. Would this pump be removed and reinstalled during the bed plate
oil seal leak repair work? Finally, I had to drive the truck for about 100
miles with it whining. Does this mean hot fuel was being sent back to my
tank?
Rodney
08 F250 CC LWB 4x4 PSD, 6 SPD-Manual, 3.73 LS
2.5" Leveling Kit / 2" Superlift Add-a-Leaf
18" MT Classic II Wheels / 35" Toyo MT Tires
Go Industries Rancher Grille Guard
SnugTop Truck Cap/Shell
Xtreme Liner
rod.10853 is offline   Reply With Quote
Fuel in coolant??? my97stroker 1994-2003 7.3L Power Stroke 6 04-10-2009 04:43 AM
New coolant reservoir mschwing82 2008-2010 6.4L Power Stroke 17 03-16-2009 03:38 PM
coolant question stacks 2003-2007 6.0L Power Stroke 7 01-20-2009 05:01 AM
Question about coolant? LJ73 5.9L Cummins (1998.5-2002) 13 12-23-2007 05:13 PM
Coolant Question flip418 2003-2007 6.0L Power Stroke 5 06-27-2006 11:41 PM
