Case 580E brake help - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Utility & Farm Tractors
Thread Details Posted by johndear720, this thread has received 6 replies and been viewed 4529 times.
Old 04-30-2009, 04:47 AM   #1
johndear720
Just purchased a 86 Case 580E and the brakes leave a lot to be desired. Haven't dug into it yet. Anyone know what I might can expect?
'93 IH 4700, 250HP DT466, L10 Cummins intercooler, 6+1, air ride.
Case 580 Super E
Galion 503 A
Cat D8H
JD A, B, MT, 40T (x2), 80, 720
Oliver 60
IH A, H, M(V8), 354, 444
johndear720 is offline   Reply With Quote
Old 04-30-2009, 05:27 AM   #2
Jeffybuilt
TDG Mafia
Jeffybuilt's Avatar
I wish I could help...but we had a 1995 model, I think it was, and the brakes were terrible from the time we got till the time it left. Other than that and being a touchy bas*^@d, it was a great machine.
My truck wants to be a semi when it grows up...
Singles Club #247
TDG Mafia Member
Thanks To:
Certified Transmission, Mishawaka, IN
http://www.certifiedtransmissiononline.com/home-6.html
State Line Diesel, Edwardsburg, MI
(269) 663-8571
Jeffybuilt is offline   Reply With Quote
Old 04-30-2009, 05:35 AM   #3
Dodgefarmer
Dodgefarmer's Avatar
Don't know about the 580E but When I had a 580C the brakes were a piece of s**t. (actually the whole machine was) I have seen larger brakes on motorcycles. The C had a external band around a small drum. As you applied brakes the braking torque would cause some internal pads through a ball and ramp setup to press against the side of the drum sort of like a disc. Dont remember but the drum was maybe 6".
I know have a Cat 420D and it is a far superior machine.
Remember not to talk bad about farmers with your mouth full!
2013 6.7 CTD 2500, 800 ft-lbs torque, 4x4 crewcab Larmine Longhorn edition, 6 sp. auto, 2 tone white/gold
--07 6.7CTD 2500 4x4, Quad Cab, Big Horn Pkg. 3.73, airbags, 6sp auto, with Mag-Hytec deep pan.- sold but not forgotten.
--08 36' Jazz 5th wheel,triple slide, 12,000lbs
--28' 22,400# PJ goosneck beaver tail trailer
--95 & 96 5.9CTD 4x4 5sp. ext. cab. 33x12.50x16 front, 33x15.50x16 rear tires. R-1 tread, wheelbase shortened 30". Used as tugs on farm
--81 IH 1800, DT466 210hp, 10 speed,
--95 FL70, 8.3 cummins 275hp, 10speed
--79 GMC 7000, DD 6V53 210 hp, 6sp ally
-- A whole bunch farm equipment, all colors
singles club # 198
WALNUT MEMBER #11(workers aganist lazy non-producers united together)
Dodgefarmer is online now   Reply With Quote
Old 05-01-2009, 12:57 AM   #4
the blue beast
the blue beast's Avatar
i would get a pressure gauge and check pressure to start with. I would pull the filter and see if it is plugged with friction material. I do not know if they have a screen that can be pulled also. I am not familiar with case. Like if it has a master cylinder, or uses pressure from a transmission pump, or even has a brake pump.
The 416's and 20's were great to work on. The 420D's have a new holland rear axle. We had a lot of them at the dealer i did a lot of diffs, and brakes in them. To many townships trying to cut ditches with the buckets riding the brakes. The new E models went to a cat designed rear axle with final drives.
Darren
04 ex cab Long Bed 6spd blue, pocket fender flares, rollpan, smoked tail lights, harley head lights, recon smoked third brake light, and 16/10 classics
6.1 built by Me, with parts from Josh at rcd, bulls eye 66/74/12cm s300, 44mm tial wastegate, speraco intercooler, hellman sump with 5/8 hose feeding the fass to 1/2 to a y block the 3/8 to the heads, outhbend 3600 double disc
Tuned by sct of course...
custom trac bars, and weight bracket with 800#
singles club #36
the blue beast is offline   Reply With Quote
Old 05-03-2009, 04:55 AM   #5
johndear720
It appears the brakes are wet brakes. They are bolted to the side of the transmission. Certainly low enough to be full of oil if not sealed real well. See some oil on the outside of the right brake. If they are supposed to be dry that may be the problem then! Have to plunder eBay for a shop manual. This is actually a Super E machine. Looks like the master cylinders for the brakes are under the dash. 23 years old so it sure possible they are worn out. ...or, maybe they just were never very good to start with. Only ran older 580's like the CK model, which had no brakes. Can't find a parking brake on it anywhere! Hard to believe something was made with no provision to park! Maybe some little fairy stole it? More when I make time to tear into it.
Case 580 Super E
Galion 503 A
Cat D8H
Oliver 60
Old 05-05-2009, 09:31 PM   #6
Hardline
Parking brake is a small think disc on the output of the tranny. It has a squeeze type mechanical caliper.
Hardline is offline   Reply With Quote
Old 05-05-2009, 09:45 PM   #7
Hardline
Breakdown depending on if your SN is before or after 16270319
Case MRX 690 Sod_Buster83 Whats Been Sold 0 03-24-2009 01:53 AM
831 case ji help lilrebeljames Utility & Farm Tractors 11 01-15-2009 08:57 AM
Case 930 cbtumedic Utility & Farm Tractors 4 09-22-2007 02:52 AM
241 T-Case duke1n Whats Been Sold 4 02-14-2007 05:06 PM
271 t-case Summit6.6 General Ford Truck and Excursion 4 04-18-2006 01:54 AM
