2004 International 4300 dt466 - TheDieselGarage.com
Thread Details Posted by Frankiep02, this thread has received 3 replies and been viewed 16796 times.
Old 12-26-2008, 01:20 PM   #1
Frankiep02
Exclamation 2004 International 4300 dt466
Hi everyone,
I just found the site the other day and thought I might be able to find an answer here.
My problem : 2004 International 4300 with 235k+ on the motor, Oil is dissapearing. No visible leaks or anything . Someone suggested it could be the compressor?
Problem 2: " Check A/C " light is on. I have no clue how to get it to turn off.
I think theres a way to check the trouble codes with the steering wheel buttons.
If anyone can help me out , let me know
Thanks,
Frank
Frankiep02 is offline   Reply With Quote
Old 12-26-2008, 03:34 PM   #2
John_G
Super Moderator
John_G's Avatar
Frank,
Does your 2004 4300 have a 2004 emissions (EGR) engine, or the pre-EGR DT? That's very important to the solution.
My guess from afar is that you have a pre-04 DT (non-EGR) engine and that one of the injector o-rings has failed allowing oil to leak into the fuel system.
EASY check, open the tank and see what color the fuel is. If it's greenish/amberish it's OK, but if it's brownish/blackish, well you have an injector o-ring leaking.
The "check A/C light" has many causes. Common ones include: Loss of charge, corroded terminals at the refrigerant temp sensors (two small sensors in the A/C piping on the RH side of the cowl under the hood right near the hood bumper), or a programming problem in the body controller that tripped the system off from high head pressure (common with a viscous fan drive and hot, humid days - this is fixable with a quick reflash).
By far the most common are the temp sensor terminals corroding and low charge.
I vote for LIBERTY!
Old 12-26-2008, 07:07 PM   #3
Frankiep02
Thanks for the input I will look into the things you suggested.
As far as the reflash, how can it be done if you know the steps ill give it a try.
Thanks,
Frank
Old 01-01-2009, 02:31 PM   #4
Horsehaulin
TDG Mafia # 81
Horsehaulin's Avatar
Does your truck have air ride or brakes?
2001 GMC 2500HD EC/LB, 4X4. A few go fast goodies. 540hp/1107tq Danville Dyno 11/09, Kennedy 40% injectors.
05 IH 9400i with Cummins ISX pulling a lumber bunk trailer, stuck in a swamp somewhere in Indiana.
Proud Veteran Served 6yrs Active Army From Germany, Kuwait and Bosnia to Ft. Hood and Ft. Knox
Horsehaulin is offline   Reply With Quote
Old or New DT466 better? Todd Frampton Medium and Heavy Duty 8 06-25-2011 02:34 PM
Help! 87 IH dt466 haulinhazmat Medium and Heavy Duty 13 01-03-2009 02:35 AM
04 Freightliner M2 Vs. 03 Int. 4300 Curbguy Medium and Heavy Duty 10 12-30-2008 08:53 PM
Need a service manual for a 95 DT466 richarr9 Medium and Heavy Duty 8 12-27-2008 10:09 PM
1999-2004 to 2005-2006 Headlight Swap weareweird69 1994-2003 7.3L Power Stroke 6 12-24-2008 04:59 PM
