How long should the 6.0L last - TheDieselGarage.com
Thread Details Posted by 04lariatfx4crewcab, this thread has received 19 replies and been viewed 15522 times.
Old 05-12-2009, 04:26 AM   #1
04lariatfx4crewcab
04lariatfx4crewcab's Avatar
I want to know what the life span is on a 6.0. I hear the 7.3 with 200K still has lots of life left on it. How many miles do you have on your sled? I am wondering because I bought mine with lots o miles on it but the mechanic said it looks and drives like a truck with under 100K on it.
Thanks
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline   Reply With Quote
Old 05-12-2009, 04:34 AM   #2
redneck6.0l
powerstrokes rule
ask josh and brentos, they know best
2003 F-350 crew cab 4X4 6 leaker
a few mods
10.56@133
redneck6.0l is offline   Reply With Quote
Old 05-12-2009, 04:39 AM   #3
jdydiesel
Dually Club #3
jdydiesel's Avatar
If taken care of I would bet you can get 300K plus out of it.
Jason
02 Excursion 4x4 Limited 7.3l. Banks Stinger Plus system
06 F-350 4x4 CC LB Tow Boss Lariat 6.0l auto. Banks PowerPDA, Banks SpeedBrake, FICM Atlas 40 Tune, ARP Studs, PowerMax GT3788VA turbo, Homemade coolant filter, EGR valve delete spool, Monster Exhaust, K&N Cold air intake, Husky mudflaps, Line-X bed liner, Recon lights, TUNED BY DFUSER.
72 F-250 Gasser.Looking for an 05-07 6.0l, 5R100 and Dana 80 to install
jdydiesel is offline   Reply With Quote
Old 05-12-2009, 05:36 AM   #4
stacks
Till you are able to get it out of the dealership parking lot or the warranty is over...Whatever comes first.
05 F-250 FX44"superlift, 35" pirelli scorpion ATR"S, sirius satellite radio, 1 sony 10" with 1k watts. sct with spartan and Doug's tunes, bullydog outlook, coolant temp, Egrcooler delete, coolant filter, 4" exhaust to 5" stacks, B&W gooseneck hitch, limo tint, ARP studs. AFE stageII intake with PG7, VIPER 5900SST
RIDIN' DIRTY member #23
Bomb Squad member #49
Running motor and trany with all wires, computers, ic, programmer and outlook will be forsale! PM with offer.
stacks is offline   Reply With Quote
Old 05-12-2009, 05:49 PM   #5
Steel
Steel's Avatar
2006 F350 CR/4R100 Fummins with Twins- 731HP 8-14-10--- Now with BIGGER TWINS
2009 Polaris Dragon 800 Race Gas Turbo- Winter Toy
"GOS Performance- Your Cummins Conversion Specialists"
800-620-4467
Check out our website here
GOS Performance Facebook
Steel is offline   Reply With Quote
Old 05-12-2009, 06:13 PM   #6
444turbodiesel
I've seen a few around here over 300K, the RV business is way down so the number of trucks has diminished quite a bit. I know of two 1M mile 7.3s (both had top end work done, but the block hadn't been out of the truck, and both were bone stock)
I don't see any reason a 6.0 wouldn't last as long as a 7.3 as long as it was maintained properly.
Power-adders always reduce lifespan.
07-6.0 4X4 CC Lariat Tow Boss w/36,000 trouble free miles.
CCV-Zoodad-Harpooned, cat delete, otherwise
BONE STOCK
444turbodiesel is offline   Reply With Quote
Old 05-12-2009, 07:21 PM   #7
04lariatfx4crewcab
Thanks,
I bought the truck with 200K on it and I am hoping to get another 100K or 5 years out of it. only using the truck on weekends and pulling a 7800lbs travel trailer once a month. it is stock from what I can tell and the only mods I am thinking of doing is the zodad and egr delete, and I have added the 18" dbacks to replace the '05 18" wheels that rubbed the leafs.
Jakob
Old 05-12-2009, 09:42 PM   #8
8yourv8
8yourv8's Avatar
my 6.0lt has 290xxx KM and one tranny two sets of injectors and one head gasket set and one EGR cooler
Driving 2007 Chevy LTZ CCSB LMM so far just EGR delete, Straight Pipe, ported fuel fitting, trans-go and PPE HOT RACE
SOLD SADLY 2004 F-350 CC SB 4Inch lift 35in tires on 20s 6.0lt EGR delete ported intake AFE stage 2 SCT Tuner ARP stud's back to stock injectors CFM Large mouth and 5" Magnaflow with 4"Down pipe 6" tip
8yourv8 is offline   Reply With Quote
Old 05-12-2009, 09:44 PM   #9
SparkyLV
Indecisive
Send a message via AIM to SparkyLV
Motor only lasts how well it is taken care.
Regular oil changes, fuel additive here and there to keep things clean.
As said above power adders shorten life span.
But an exhaust and intake will never shorten the life span nor would deleting the egr.
And not beating the dog **** out of it will make them last.
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline   Reply With Quote
Old 05-12-2009, 09:47 PM   #10
ralphinnj
Got Torque?
ralphinnj's Avatar
Images: 80
It really depends a lot on how well you maintain it and whether you mod it. Also, the area of the country you live in. In the southwest, where it is drier, less stuff rusts and the body and other exposed parts will last a LOT longer. If you live in a humid area, it will have more problems. Another thing to keep in mind is that different components wear out at different times. If you just mean the engine, and you really stay on top of maintenance and you don't mod it, even 500K miles is possible. But by then, a lot of drive train parts will be replaced, etc.
Black 2003 F350 Dually, Nothing Stock
Other Rides:
Black 2006 300C SRT8
Black 2012 CTS-V (630HP)
Black 2008 Mercedes E550
ralphinnj is offline   Reply With Quote
How Long Can You Last Bouncer The Parking Lot 16 01-14-2009 03:30 AM
HOW long? Superstroker 2003-2007 6.0L Power Stroke 12 01-13-2009 11:03 PM
How Long? stanleycr1 5.9L Cummins (2003-2007.5) 8 04-08-2008 01:34 AM
dp f5 on OBS... How Long? 97UTPSD 1994-2003 7.3L Chips & Tuners Forum 8 03-25-2008 12:08 AM
Been There To Long??? Bouncer The Parking Lot 1 03-29-2007 06:59 PM
