TBC Fault???? - TheDieselGarage.com
Thread Details Posted by Eazydeezy, this thread has received 10 replies and been viewed 25076 times.
Old 05-13-2009, 01:47 PM   #1
Eazydeezy
Let it all Ride
Eazydeezy's Avatar
TBC Fault????
Alright guys, I'm getting a TBC Fault on the message center every third time startin gthe truck. What the hell does it mean?
Dominic
'12 PSD F-350 SRW Lariat Ultimate and chrome package, FX4, moonroof and nav.
Eazydeezy is offline   Reply With Quote
Old 05-13-2009, 02:18 PM   #2
TANK'S 250
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Trailer Brake Controller
____________________________
2005 F-250, CC,SB,PSD, MANUAL TRANNY
Icon 4.5" lift, 41" IROKS, and some other stuff
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TIRES AND WHEELS- 41" IROK Super Swampers, 20 x 10 AR Mojave Teflon-STEERING UPGRADE- Donahoe Racing Dual Stabilizers -FRONT SUSPENSION- Donahoe Racing 4.5" lift -REAR SUSPENSION- 6" Procomp Springs, Farmboy Fabrications Custom Traction Bars-FRONT AXLE UPGRADES- ARB Air locker/ 4.56 Precision Gears -REAR AXLE UPGRADES- ARB Air Locker/ 4.56 Precision Gears -ENGINE UPGRADES -SCT XCAL II w/ Extreme track file- ARP Headstuds - TRUSTED PERFORMANCE Stage II fuel and Oil system - ACCUFAB Intake Elbow - AFE Stage II Intake - MBRP Turbo back Stainless Steel Exhaust - MERLIN controls SPEED WIZARD-TRANSMISSION UPGRADES- Southbend 550+ HP Clutch -INTERIOR MODS-Gauge Works Quad A-pillar pod - Autometer Cobalt Series Gauges Pyro, Boost, Tranny - Cobra Inverter Remote Switch - Cobra Limited Edition Harley Davidson CB - Python Custom alarm system, wired into train horns - Hi-Lift Extreme jack w/ off road base -10,000 watt inverter - 15 gallons of air - Porter Cable 115 volt, 2.5hp Air Compressor - Rhino....Bed liner - EXTERIOR MODS- Harley Heads & Smoked tails- Crown SS braided Brake Lines -Custom Fabricated Front Bumper/ Brushguard w/ Custom Herculiner - (2) 8" Procomp Spotlights -(2) 5" Procomp Spotlights - (2) 5"Procomp Fluted lights - (2) 12 ton Recovery Shackles - Custom Fabricated Safari Rack w/ Custom Herculiner - (8 ) 3" x 5" Procomp Fluted lights - Grover...Triple Train Horns - Wilson 4' Fiberglass CB antenna - Stealth Bulbs Chrome signal bulbs - Dominator...Cowl Hood - Custom Herculined Rocker panels - AMP Research Powersteps - Bushwacker Cut-out Fender Flares - Ventshades - LEER Bed cap - Recon Line of Fire, rear light bar,...and a couple other things
TANK'S 250 is offline   Reply With Quote
Old 05-13-2009, 02:20 PM   #3
Eazydeezy
Let it all Ride
Eazydeezy's Avatar
Thanks....I wonder why the heck it would have a problem with out a trailer hooked up??
Dominic
Old 05-13-2009, 09:22 PM   #4
vrsc
vrsc's Avatar
Images: 47
mines been doing that ever since I bought it brand new? No answer has been given and ford hasn't been able to fix?
vrsc is offline   Reply With Quote
Old 05-13-2009, 09:35 PM   #5
Eazydeezy
Let it all Ride
Eazydeezy's Avatar
Does yours have the built in trailer brake?
Dominic
Old 05-16-2009, 06:10 AM   #6
vrsc
vrsc's Avatar
Images: 47
yes
Old 05-17-2009, 10:26 PM   #7
PiRiPi
PiRiPi's Avatar
Send a message via AIM to PiRiPi
Exclamation
yes yes yes tbc i went thur it.easy fix it with a 2amp fuse , the fuse box inside ur hood open it now look at the 2 amp fuse( white). if not blown get a nail file and clean the treminals if not blown.... trust me ur problem will be fixed
PiRiPi is offline   Reply With Quote
The Following User Says Thank You to PiRiPi For this addition to TDG:
vrsc (05-20-2009)
Old 05-17-2009, 11:27 PM   #8
zachespo
zachespo's Avatar
Send a message via AIM to zachespo
I've gotten this message before as well however i was using the little key trick to pass the speed limiter. After i let off it went away but i'm a little scarred of doing the trick anymore.
2007 F350 CCLB- Stock for now
2004 F150- Edge Evo- Banks Monster Exhaust- AEM Intake
zachespo is offline   Reply With Quote
Old 05-18-2009, 01:01 AM   #9
firefighter33
OK guys i have a problem i just bought a SCT SF3 tuner i plug it in to the OBDII port and the tuner starts up i press program vehicle turn key on turn key off as it tells me to do comes up 6.0l diesel i press that it says begin programing i press that it says turn key on i do thats when my problem starts the message center im my trucks says TBC FAULT and nothing happens the tuner says uploading ECU please wait. i let it sit for 1/2 hour and nothing tuner still says uploading ECU please wait.I called SCT and they said its a communication problem on my end.PLEASE HELP
2006 F250 6.0L
firefighter33 is offline   Reply With Quote
Old 05-18-2009, 01:11 AM   #10
zachespo
zachespo's Avatar
2006 F250 6.0L
Can't really help you out but I'd try starting your own thread over in the tuner section. You will probably get more help there.
TBC fault mbdriver 2003-2007 6.0L Power Stroke 11 11-10-2007 12:25 AM
TBC Fault? SICKS-O 2003-2007 6.0L Power Stroke 8 03-19-2007 05:45 PM
tbc fault Strokin391 2003-2007 6.0L Power Stroke 6 02-09-2007 11:11 AM
TDC Fault? tdmr1195 2003-2007 6.0L Power Stroke 3 01-03-2007 08:09 PM
TBC Fault imported_Saftman 2003-2007 6.0L Power Stroke 10 12-12-2006 04:23 PM
