Why Was the Cummins 555 Not Popular? - TheDieselGarage.com
Thread Details Posted by Gillig8V71, this thread has received 13 replies and been viewed 25687 times.
Old 05-17-2009, 06:47 AM   #1
Gillig8V71
Hi,
Why was the Cummins V-555 line not so popular?
My theories are that these engines, which include the VTF-555, were an outgrowth of the V-470 (VINE) and the V-504 diesel engines, all of which are undersquare (with a 4-5/8" bore, the V-470 having a 3-1/2" stroke, the V-504 a 3-3/4" stroke and the V-555 a 4-1/8" stroke).
Here is a video of a VTF-555 in action as a retrofit engine in a 1952 American LaFrance fire engine:
~Ben
Gillig8V71 is offline   Reply With Quote
Old 05-18-2009, 01:18 PM   #2
navistar45
i have a few theroy's. first it wasnt that good an engine. cummins [i read this in a cummins qouted article] did little to push it's smaller v engines, and really did not believe the v was a good design for a diesel platform. they believed in the inline design, and did indeed have issues with their v engines. also the 505 555 and other v engines came into a market [medium trucks] that was dominated by gas engines. gas engine's were easier to maintain,replace,and were proven. now the tabels have turned, and the diesels dominate, but the inline is the configuration of choice. personally i like the v engine's, the 3208 was one of my favorites. it was also the best of the medium v8's back in the day. now the only v8 is the 444e[7.3] or the 365[6.0]. personally i'am a big fan of the 7.3, but in the end, i prefer my trucks to be 466 powered. my old man had a triple nickle[555] back in the late 70's. it was in a tandem international dump, ran it a few years and had no issues.
navistar45 is offline   Reply With Quote
The Following User Says Thank You to navistar45 For this addition to TDG:
Gillig8V71 (05-18-2009)
Old 05-18-2009, 05:13 PM   #3
6V-92TTA
It was the worst of all of Cummins' V8s, we called them 'cripple fives' here. You name it, if failed. The V-903, VT-903 & VT-300/320/350 enjoyed a good following in Australia even though they weren't that great either. As a general rule, V8 diesels are limited by their lack of main bearings compared to straight 6 diesels. Even the mightiest Mack V8 topped out at 610HP before it reached it's limit & the Cat 3408 didn't even get that far.
6V-92TTA is offline   Reply With Quote
The Following User Says Thank You to 6V-92TTA For this addition to TDG:
Old 05-18-2009, 06:22 PM   #4
mudguppy
Tebow-in'...
mudguppy's Avatar
the VTA-903T's in the M2/M3 Bradley's are running at 600 hp...
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline   Reply With Quote
The Following User Says Thank You to mudguppy For this addition to TDG:
Duke (05-19-2009)
Old 05-18-2009, 10:07 PM   #5
french277
Euro Sparky/ Wrencher
french277's Avatar
L'autre raison pourquoi le nickel triple triple c'est-à-dire cinq moteur ils exécute vraiment l'assez haut tr-min et ils avaient vraiment une certaine question avec le comportement ce que j'ai entendu.
Le cinq moteur triple est ok à moi rien ne s'imagine(a envie de) à côté de peu de bizarreries avec cela.
The other reason why the triple nickel aka triple five motor they do run pretty high rpm and they did have some issue with bearing what I heard.
The triple five motor is ok to me nothing fancy beside few quirks with it.
Merci,Marc
french277 is offline   Reply With Quote
Old 05-19-2009, 03:00 AM   #6
navistar45
you got a point, but. remember the v8 engines back in the day ruled the road, as compared to what 6cyl engines that were available. as time went by,the inlines were being built to turn out more power, and with a cheaper cost to produce, and repair, it just made sense to go that route on otr trucks. as for main bearing numbers, thats a good point as well. again consider this, the inline has to have the extra bearing's due to the torsinal stress on the crank[ because it's much longer.] the most important thing to remember about mains,and other bearings is not so much as the number of them, but the size of them also. wider bearings carry loads with less stress. not directing this at anyone inparticular, but it makes me chuckle everytime i hear someone say a inline will last a lot longer then a v design engine. spend some time in the mineing industry as well as the gas well industry, and one can plainly see that the v's hold up very well for lot's of hrs.
The Following 2 Users Say Thank You to navistar45 For this addition to TDG:
Binderpower (05-20-2009), Gillig8V71 (05-19-2009)
Old 05-19-2009, 09:35 AM   #7
SmokinCAT
SmokinCAT's Avatar
We have one in our versatile, and have yet to have any trouble out of it, it actually runs pretty good.
Cody.
79 KW W900A 3406B, Holset HC5 turbo, RTO12513,
4.11 SQHP rockwells
79 KW K100C 400BC1, Holset HT4B hybrid, custom
injectors, RTO12513, 4.33 eaton DS380s
87 KW W900B 400BC3 with ATA, RTO15613P, 3.70 eaton DS402s
00 Freightliner Classic XL C15
SmokinCAT is offline   Reply With Quote
The Following User Says Thank You to SmokinCAT For this addition to TDG:
Gillig8V71 (06-08-2009)
Old 05-19-2009, 12:28 PM   #8
gwhammy
I worked a linkbelt crane back in the 80's with a 555 and 13 speed. It grossed 58,000 lbs. down the road. Top end was 65 mph. If you hit a hill you tried to grab at least 2 gears to maintain some speed. It did do good for the stationary work it usually did on the job sights. It spent a lot of time maxed out on rpm's pouring concrete or slinging iron. I think we overhualed it once.
01,qcsb,fwd,he351-3b twins,125 horse injectors,adrenaline pulse,5 inch ex. to 5 in. stacks,on board air,5 disk convertor
02 qcsb,fwd,35-40,edge juice,mach 2.5 injectors,4 inch exhaust,billet trans, 4 disk convertor
gwhammy is offline   Reply With Quote
The Following User Says Thank You to gwhammy For this addition to TDG:
Old 06-08-2009, 01:00 AM   #9
bmoeller
bmoeller's Avatar
A fair number of them were used in ag applications. Big A floaters and farm tractors as 2.
My uncle had 2 555 Series 3 Versatile 4wd tractors with the 555 Cummins. Still owns the first one he bought. Other went up in a VERY nasty oil fire when a hyd line blew oil on the exhaust manifold. His Big A also had a 555 Cummins, backed by an Allison MT540, IIRC.
"Obama = Hoax and Chains"
The Following User Says Thank You to bmoeller For this addition to TDG:
Old 06-09-2009, 01:26 AM   #10
trucker_dad
iv heard they were not a well balanced engine,hence wouldnt stay together long
trucker_dad is offline   Reply With Quote
Tags
cummins, v555, vtf555
most popular diesels of o8 SHEPPERD The Polling Place 10 03-20-2009 12:41 AM
I know I'm popular,,,,,,, madmatt The Parking Lot 3 12-18-2007 03:05 AM
popular Gen 1 (Cummins) threads? RIDGE Introductions 4 09-20-2007 09:04 PM
new to site a ? that seems to be popular djbigblcstrkr 1994-2003 7.3L Power Stroke 5 10-25-2006 11:43 PM
popular tuner Deezle1 1994-2003 7.3L Power Stroke 18 09-27-2005 12:36 AM
