1993 DT466 injector removal - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by dieselman59, this thread has received 4 replies and been viewed 4017 times.
Old 06-05-2009, 02:29 PM   #1
dieselman59
Do you usually have to have a puller to remove injectors on a mechanical DT466? My handle is dieselman but I am not a diesel mechanic just a laid off aircraft mechanic, a 40 ft. school bus that will soon be our rv. home,
I am proud of taking a 6.9 from a f250, taking the engine down to nothing , having it bored .030 over & having the heads done, crank polished , putting it back together with a little help from the little lady, putting it into a 1980 international scout, & it started on the first turn after bleeding the fuel system, I know that is nothing to what you guys accomplish! So that's why I'll have questions. Sorry for the long post wanted to share, my story.
dieselman59 is offline   Reply With Quote
Old 06-05-2009, 05:49 PM   #2
ynot
The other guy
An OEM puller helps but you can make one from an old fuel line nut (either bent slide hammer or T-top threaded puller), or crow foot the fuel line that's on it (to break loose), but clean around them well and a little panther pee can't hurt
ynot is offline   Reply With Quote
Old 06-06-2009, 05:00 PM   #3
bmoeller
bmoeller's Avatar
At least on my 12v, I used a GM lug nut where the fuel line hooks up, and 2 pry bars. One was a rolling head style that I used the front 4, and regular pry bar for the last 2. Worked like a charm. Just pried against a head bolt. Might be abe to do the same on yours.
"Obama = Hoax and Chains"
Old 06-06-2009, 07:13 PM   #4
french277
Euro Sparky/ Wrencher
french277's Avatar
Ils ne sont pas trop mal pour enlever l'injecteur de la culasse j'utilise faisant glisser le marteau ou forcez la barre un des deux que cela.
they are not too bad to remove the injector out of the cylinder head I use either sliding hammer or prybar one of the two that it.
Merci,Marc
french277 is offline   Reply With Quote
Old 06-08-2009, 02:33 PM   #5
dieselman59
Thank you for your help guys, wish I could buy you a beer but this is the best I can do.
Injector removal on 03 bigtrxs 2003-2007 6.0L Power Stroke 8 01-25-2008 07:47 PM
injector removal 7.3stroker 5.9L Cummins (1998.5-2002) 9 01-24-2008 01:08 AM
1993 IdIturbo-who makes the best replacement injector mccool 7.3L and 6.9 IDI (Pre 1994) 1 04-10-2007 12:58 AM
Injector removal sstockton 1994-2003 7.3L Power Stroke 9 03-29-2007 03:42 AM
Newbee with question on 1993 injector oring mccool 7.3L and 6.9 IDI (Pre 1994) 1 03-07-2007 06:06 PM
