kenworth fuel issues - TheDieselGarage.com
Thread Details Posted by bigswede, this thread has received 6 replies and been viewed 3991 times.
Old 06-15-2009, 01:47 AM   #1
bigswede
on a kenworth t600 05 does anybody know on a doulble suck,double return,is there any valves in the lines or is it pure flow from pickup tubes to filter and from return to tank,fighting restriction and have repkaced fuel lines,was wandering if iam overlooking something?
bigswede is offline   Reply With Quote
Old 06-15-2009, 03:03 AM   #2
ktw900
ktw900's Avatar
On my 05 there are no valves anywhere on the suction. There is a valve on the return line underneath the bunk, that levels out the fuel going to each tank. This probably wouldn't have anything to do with restriction. But what I have done is take that valve off, take the cover off, pull the spring out and the flapper thingy....very technical...and drill out everthing you see in that valve. This Valve has caused me to freeze up numerous times on every Kenworth I've owned. It might help. Just an idea.
ktw900 is offline   Reply With Quote
Old 06-15-2009, 04:06 AM   #3
bmoeller
bmoeller's Avatar
If you have a C15, there are updated fuel filter bases you can get from Cat to reduce the restriction on the secondary engine mounted filter. It is a known problem. Getting longer fuel filters help as well. More area to pull fuel through. Best to stay with Cat, Fleetguard or Baldwin filters. Others like Carquest filters, I've usually had HIGHER restriction with NEW filters, vs the ones that had 20k on them. That is BS!
Another thing on a Cat, is to replace the fuel bypass valve. Spring gets weak, and you lose fuel pressure. Dirty fuel filters make it even worse. Only costs ~$25 to replace.
"Obama = Hoax and Chains"
Old 06-16-2009, 03:58 AM   #4
ynot
The other guy
I'd leave our the Baldwin thing. If you buy the cheapest filter made, you are installing the cheapest filter made. Their flow specs are just pitiful (according to the latest data)
ynot is offline   Reply With Quote
Old 06-17-2009, 02:33 AM   #5
bmoeller
bmoeller's Avatar
We've had good luck with the Baldwins on our Macks and ISX. Don't recall using them on our Cats, though. Never been any on my W9.
Boss has gotten to be a tight @$$ with the filters. All he has gotten are the damn Carquest filters. Suspect I've got an injector taking dump on me now. Slight loss in power, and an across the board .5mpg loss, OTR or short haul. Rough idle and a bit rough cruising or under load. Showed up even worse with the fuel temp harness, so I removed it. Been trying to get his friends laptop to put on it and run some tests, but so far all I'm doing is
Overhead may need to be run as well. Not sure if it has even been done or not. Bought it used. ~470k miles on it right now.
Old 06-17-2009, 03:09 AM   #6
ynot
The other guy
With 470 may as well wait a couple oil changes and do bearings too. And yes, you puked and injector, so may get two valve sets anyway
The Following User Says Thank You to ynot For this addition to TDG:
bmoeller (06-17-2009)
Old 06-17-2009, 04:25 AM   #7
bmoeller
bmoeller's Avatar
Pretty much what I figured. Been wanting to post a vid for you to listen to, but that other computer with the card reader bit the big one.
Now,........... to get the boss to listen to me FOR ONCE.
fuel issues camojeeper 1994-2003 7.3L Power Stroke 11 04-21-2009 11:51 PM
More fuel issues machine 2003-2007 6.0L Power Stroke 13 04-16-2009 03:29 PM
'88 7.3L Fuel Issues? MrDanB 7.3L and 6.9 IDI (Pre 1994) 2 03-22-2009 04:11 PM
Fuel Filter issues 4cstr 2003-2007 6.0L Power Stroke 20 04-18-2008 05:14 PM
Fuel Mileage Issues oilfieldtrsh81 1994-2003 7.3L Power Stroke 22 01-20-2008 04:01 AM
