Oil Pressure Sensor Location - TheDieselGarage.com
Thread Details Posted by 04lariatfx4crewcab, this thread has received 8 replies and been viewed 13376 times.
Old 07-07-2009, 06:03 PM   #1
04lariatfx4crewcab
04lariatfx4crewcab's Avatar
Ok, I give up. I can not find where the oil pressure sensor is located on my truck. I am still trying to figure this diesel thing out. Does anyone have a picture of where this sensor is located?
Thank you
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline   Reply With Quote
Old 07-07-2009, 06:46 PM   #2
hpprose
hpprose's Avatar
Images: 2
The sensor for the low pressure is right next to the oil filter housing.
The sensor for the high pressure oil is on the passengers side valve cover right next to the glow plug controller (on 04's and newer)
My life is like my license plate.
Everything is right side up, but feels upside down.
hpprose is offline   Reply With Quote
Old 07-07-2009, 08:35 PM   #3
04lariatfx4crewcab
Thanks hpprose.
There are two?
wich one is for the oil pressure guage on the dash?
Also are they the same part number because I can only find one part number for an oil sensor it is F81Z-9278-AA.
Thanks for the reply.
Jakob
Old 07-07-2009, 10:23 PM   #4
hpprose
hpprose's Avatar
Images: 2
The oil pressure gauge on your dash uses the sensor by the oil filter housing.
The sensor on the passengers side valve cover is the ICP which reads injection control pressure.
The Following User Says Thank You to hpprose For this addition to TDG:
04lariatfx4crewcab (07-08-2009)
Old 07-08-2009, 02:15 AM   #5
cb44473
the oil pressure switch is the one with the single wire. the other with two wires is the oil temperature sensor. they are both located by the oil filter housing and screw into the oil cooler. the connector for the switch is black and the connector for the temp is grey. if you want the switch the part number you listed is correct. why are you wanting to change the switch.
Ford Diesel Engine Master Certified
Ford Senior Master Certified
Dodge Cummins Level 4 Certified
Cummins Certified
cb44473 is offline   Reply With Quote
The Following User Says Thank You to cb44473 For this addition to TDG:
Old 07-08-2009, 03:35 AM   #6
04lariatfx4crewcab
cb44473,
I just want to check the sensor see if it is working correctly or if the wire might be shorting or loose I keep getting a check guage light and the oil pressure guage dies some times it dies for a few seconds sometimes only a split second. the truck does not die no matter how long the guage is dead. it only ever happens when I slow for a stop. if I press the vertical pedal it will come back to life. I just want to make sure it is not the sensors or something easy before I tear into it looking for an HPOP problem.
Jakob
Old 07-08-2009, 06:02 AM   #7
hpprose
hpprose's Avatar
Images: 2
When mine started doing that, my sensor had a small hole and it was filling the wiring up with oil.
Old 07-08-2009, 07:04 AM   #8
4play
4play's Avatar
Originally Posted by 04lariatfx4crewcab View Post
cb44473,
your on the right track going after the sender, remember though its just a single wire switch with a brown/orange stripe wire. these senders are notorius for what you explained. this sender only indicates "low" pressure and not actual oil pressure. its basically and idiot light but with a guage. with normal oil pressure the sender grounds the wire to indicate good oil pressure and turn the light off. If you have a wiring concern you need to look for an open circuit. but i bet you will be fixed with a new sender/switch.
4play is offline   Reply With Quote
The Following User Says Thank You to 4play For this addition to TDG:
Old 07-08-2009, 02:07 PM   #9
04lariatfx4crewcab
Thanks 4play. I will be checking the sender/switch. I hope that solves my problem.
Jakob
Cat 3116e: Fuel Temp Sensor & Boost Pressure Sensor probablecause Medium and Heavy Duty 0 02-03-2009 02:54 AM
EGT sensor location......... bwanajim 7.3L and 6.9 IDI (Pre 1994) 4 01-21-2008 07:03 AM
EGT sensor location........ bwanajim 7.3L and 6.9 IDI (Pre 1994) 0 01-20-2008 09:35 PM
Baro Sensor location? Pat M 2003-2007 6.0L Power Stroke 5 12-22-2007 03:44 PM
Boost sensor location killerbee Duramax 2004.5-2005(LLY) 8 10-19-2006 05:35 PM
