| Thread Details Posted by lilpooh, this thread has received 15 replies and been viewed 6582 times. |
#1 |
WATER PUMP REMOVAL INSTRUCTION w/PICS.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() STEP 1-Disconnect the negative battery connections STEP 2-Begin by draining the radiator by opening the valve at the bottom. Let this drain and move on to the next steps. STEP 3-Disconnect the upper radiator hose that comes from the thermostat,the small hose that leads to the degas bottle and the electric connection for the fan. STEP 4-Carefully detach the plastic covers that are snapped in on top of the fan shroud. STEP 5-Remove the two 8mm bolts that hold the front fan shroud to the radiator. STEP 6-Get underneath the truck and disconnect the lower radiator hose slowly to minimize getting the rest of the coolant all over the place. STEP 7-Dissconnect the two transmission cooloing lines that are attached to the bottom of the radiator. STEP 8-Back on top of the radiator the two mounting brackets are removed by loosening the four 8mm bolts. STEP 9-You can pull the radiator forward allowing room to slowly pull the front fan shroud upward and out of the truck. STEP 10-Follow this by slowly lifting up on the radiator and remove it from the trusk.I did this to allow more working room. STEP 11-At this point, the fan assembly needs to be removed to access the water pump. STEP 12-Unclip the fan wire harness from the rear fan shroud. STEP 13-The rear fan shroud is attached to the engine with four 15mm bolts. Two at the top and two at the bottom. Access was easy between the fan blades with ratchet extensions. STEP 14-Now pull the rear fan shroud forward to expose the fan clutch nut. STEP 15-I use a long screwdriver placed in the holes of the water pump pulley cover to keep it from moving. Instead of the expensive fan wrenches or removal tools, I used a 18" pipe wrench ($15 at tool store) on the nut,turning it counterclockwise.Found it easier to get this nut from underneath the truck,had to put extension pipe on wrench(nut was tight to get off). STEP 16-Upon loosening the nut the entire way,you can now carefully remove the fan and the rear shroud all at the same time up and out of the truck. STEP 17- The water pulley cover is attached by four 10mm bolts. Loosen the bolts and then release tension on the serpentine belt by using 1/2" drive ratchet clockwise on the tension pulley located to the left of the water pump. STEP 18-Pull the belt out of the way and finish removing the pulley cover and plate. STEP 19-The water pump is now exposed.Remove the four 10mm bolts that attach the pump to the front cover.A slight tap popped the water pump off of the engine. Removal and install should take 4 hours or less,The radiator was very dirty from bugs and oils from daily driving,sparyed with mild degreaser and hosed clean,used plastic bags and rubber bands to seal off trans cooler lines so i didn't get water in them. THANK YOU BISMIC FOR THE WRITE UP,I HOPE MY PICS HELPED OUT.
2004 F350 CC DRW King Ranch X-3 tunes by DJ,QT,GH,ID,Gyphon FICM tuner,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB Thanks to:JASONS REPAIR AND PERFORMANCE-TELFORD,PA. "Are diesel pickups hot rods? Yes,they are-perhaps the most versatile hot rods ever made"---Diesel Power Magazine |
| The Following 5 Users Say Thank You to lilpooh For this addition to TDG: | awhotrods (08-16-2009), Bcarriveau (07-17-2009), bismic (12-15-2009), bluovldeezl (07-16-2009), dayusex (07-16-2009) |
| Sponsored Links | |||
Advertisement | |||
#2 |
The pics are from top to bottom,
STEP 2 4 5 6 7 8 12 13 15 17a 17b 19a 19b and dirty radiator.
#3 |
Powerstroke Puller
good job on the writeup!
07 Classic LBZ 4x4 Efi leveled out Suncoast stage 4 w/ 1056 22" Fuel wheels 04 6.0 CC SRW (Sold) Some pullin goodies ![]() B & B Pulling Team ![]() Troyers Diesel Performance |
#4 |
I can count to Potatoe
thanks man!
#5 |
********* and Mafia #90
Right on. i will make some edits to it and try and change the picture sizes so they are always large. Then move it to the tech section.
Bill Carriveau OFFICIAL POO HAULER 2005 F250 FX4 Supercab Shortbed ARP studs, sct, Leveling kit,Airdog set at 62psi with no factory pump, leveling kit,5" stacks, under cab lights, Large in the way Fan shroud Removed, bed Lights being Re-did. Large Alternator(250amps)(130 amps was so 2003). On 3rd set of Hgs(soon to be 4th), 2nd set of heads, 2nd tubro, egr cooler, FICM and more. When i Turn the Key it does return a Favor, not always in MY Favor. Da Rules..Here ![]() Windows 7 Takes the WIN! Windows 8 might take that Win http://www.bcarriveau.com/ Dear Tequila: We had a deal. You were supposed to make me sexier, smarter and a better dancer. But I saw the video. And I think we need to talk.. How you name your Thread is Important. Read Here The TDG TOTQ |
#6 |
I need to get "computers for dumbies",it took me longer to figure out photobucket, than to fix the water pump.
#7 |
by PC.
#8 |
#9 |
what's up with the green anti-freeze? I can't believe I'm the only one who noticed.
#10 |
I use the motorcraft gold from the dealer, i've been told it turns green from use.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lift Pump Removal | BombDocDiesel | 5.9L Cummins (1998.5-2002) | 14 | 07-16-2009 01:56 AM |
| Water Pump | gssuperduty | 5.9L Cummins (2003-2007.5) | 1 | 07-04-2009 01:45 PM |
| LBZ Fuel Injection Pump Removal | ripmf666 | GM Spec Info | 0 | 12-28-2008 09:09 AM |
| oil leak?? and trans removal pics | WNYPA | 1994-2003 7.3L Power Stroke | 4 | 04-27-2006 05:45 PM |
| Water pump | dieseldummy | 1994-2003 7.3L Power Stroke | 10 | 09-15-2005 01:19 PM |
| New To Site? | Need Help? | TDG Specials |
