low brake pressure light on - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Medium Duty
Thread Details Posted by squishy, this thread has received 3 replies and been viewed 10102 times.
Old 07-16-2009, 07:26 PM   #1
squishy
I have a 05 International 4300 and the low brake pressure light has come on and the electric brake boost motor is running all the time. I know this system runs off the power steering pump and we have had no problems with the power steering whatsoever. We unplugged the sensor for the brake pressure and it seems to brake fine we just dont have the electric motor running when you apply the brakes when and if the truck stalls. Could the sensor but the problem?
squishy is offline   Reply With Quote
Old 07-25-2009, 06:19 AM   #2
squishy
No one has any ideas or suggestions..............wow
Old 07-26-2009, 02:59 AM   #3
sdan27
have you tried replacing the sensor? i'm not sure what the spec is but you might test the pressure and flow rate that the p/s pump is producing to see if it's doing its job. if you called your local IH dealership they should be able to look it up for you.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline   Reply With Quote
The Following User Says Thank You to sdan27 For this addition to TDG:
squishy (07-29-2009)
Old 02-20-2014, 10:49 PM   #4
farmboy7
got the one on the mater cylinder and the relay ordered the one on the booster
farmboy7 is offline   Reply With Quote
1998 4700 Brake pressure light ? imported_curbguy Heavy Duty 8 02-11-2007 07:29 PM
Brake and ABS light on 4rcFed 1994-2003 7.3L Power Stroke 4 12-06-2006 01:46 AM
LED 3rd brake light BADASS03SVT General Ford Truck and Excursion 2 11-20-2006 02:09 AM
Brake light help worktruck General Ford Truck and Excursion 1 10-14-2006 01:43 PM
Brake Light fuzzys69 General Ford Truck and Excursion 3 04-02-2006 03:02 AM
