Need to change injectors in an N-14 Cummins - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by strawboss, this thread has received 9 replies and been viewed 7008 times.
Old 07-20-2009, 10:52 PM   #1
strawboss
strawboss's Avatar
I'm trying to save a little money by changing an injector in my 98 Freightshaker. Anyone got some links or something.
Thanks ahead of time.
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline   Reply With Quote
Old 07-21-2009, 04:37 AM   #2
ynot
The other guy
Diagnostics or replacement??
ynot is offline   Reply With Quote
Old 07-24-2009, 02:07 AM   #3
strawboss
strawboss's Avatar
I pretty much figured out it is #1 injector. I just need to know what i'm getting into before i tear into it. so Replacement is in order.
Old 07-24-2009, 02:43 AM   #4
ynot
The other guy
Easy. Pop the valve cover, pop the Jake head, 7/16" deep 12p (make one), 9/16" 12p on the rocker shaft, 3/8" with 6" extension on the injector hold down. Pull the front up first (on the hold down), then up and out. Pop the injector with a heal bar.
Re-assemble: Lube o-rings with Lucas, pop the injector down with a plastic hammer handle, install hold down kit, torq to 40psi, install rockers, torq to 110psi, run overhead, install Jakes, torq to 65ftlbs, valve cover and done
The Following User Says Thank You to ynot For this addition to TDG:
strawboss (07-24-2009)
Old 07-24-2009, 02:48 AM   #5
sexytrkr
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
dang, youd think he's done it before.
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline   Reply With Quote
Old 07-24-2009, 02:51 AM   #6
ynot
The other guy
Nope, just read the book real fast
Old 07-24-2009, 11:39 PM   #7
strawboss
strawboss's Avatar
Aight, Now time to get it in the shop and tackle this thing............waiting on the injector though....
Old 07-25-2009, 04:13 AM   #8
ynot
The other guy
Keep us posted (and damn, what a load on that avatar!!!!)
Old 07-25-2009, 10:16 AM   #9
french277
Euro Sparky/ Wrencher
french277's Avatar
Il ne devrait pas prendre plus de 1 heure le plus pour remplacer un injecteur si vous fait cela d'abord le temps mais si fait avant que ce ne soit beaucoup plus rapide environ 15 minute le plus que ce que j'ai fait celui soutenez un jour ou l'autre et il m'a seulement pris 20 minute avec la pièce limitée au-dessus de la baie de moteur {c'était l'autobus arrière de moteur}
It should not take more than 1 hour the most to replace one injector if you done it first time but if done before it will be much quicker about 15 min the most that what I did one sometime back and it only took me 20 min with limited room above the engine bay { it was rear engine bus }
Merci,Marc
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
french277 is offline   Reply With Quote
Old 07-28-2009, 02:41 AM   #10
strawboss
strawboss's Avatar
ok I'll try........Long days make short nights fellas
Recommended Oil Change 8.3 Cummins acesneights1 Heavy Duty 6 03-06-2009 02:36 AM
Cummins Injectors Roughneck Supporting Vendors Forum 3 01-20-2009 03:44 AM
Change Injectors on 6.5 F.B.I 6.5L Diesel Engine 6 08-01-2007 11:47 PM
how hard to change injectors 03fatness 2003-2007 6.0L Power Stroke 16 08-25-2006 01:23 AM
Wanted: Stock Cummins 24v injectors Jetpilot Whats Been Sold 2 11-25-2005 02:55 AM
