3406E Caterpillar Injector Setting - TheDieselGarage.com
Thread Details Posted by bojoe, this thread has received 12 replies and been viewed 17639 times.
Old 07-24-2009, 07:50 PM   #1
bojoe
bojoe's Avatar
I know one of you guys out here knows this. Is there anyway to set the injectors on a 3406E without the wonderful "Special Tool" from Caterpillar. I had to replace the cam and rockers in mine and need to set them.
bojoe is offline   Reply With Quote
Old 07-24-2009, 09:52 PM   #2
ynot
The other guy
Nope. Sorry, but hit Monaco Tools if you need one
ynot is offline   Reply With Quote
Old 07-25-2009, 01:48 AM   #3
bojoe
bojoe's Avatar
Good Ole' Caterpillar
Thanks Tony. I broke down and went to Caterpillar and $100.63 later I know am the proud owner of one.
I put this camshaft and rollers in and the thing sure sounds different. Its hitting on all 6 but it has a different cackle to it out the stacks. I put in a new injector had the 4 digit code entered in the ECM. I then took the new injector out when I realized I had a blown head gasket. Fixed the head gasket and when I went back together I put the old injector back in. It still has the 4 digit code of the new injector in the ECM with the old injector in. With this make a big difference.
Old 07-25-2009, 04:12 AM   #4
ynot
The other guy
Nope, not one, but setting them all with test codes would be the ticket
1) 5232's
2) 1100's
whichever makes it idle best, but you'll get more power either way!!
The Following User Says Thank You to ynot For this addition to TDG:
bojoe (07-25-2009)
Old 07-25-2009, 02:36 PM   #5
bojoe
bojoe's Avatar
Forgive me I am E model dumb. Is this what is called the flash files? I know every injector had a different number on it. The Cat book said to have the code entered to max out performance of the new injector. What exactly does the number do?
Old 07-25-2009, 07:52 PM   #6
ynot
The other guy
They are called balance codes. They do not max the injector, they make them idle smoother. The afore-mentioned codes are the "max" codes. There are a few others, but you start getting into ECM writing to balance idle...
bojoe (07-25-2009)
Old 07-25-2009, 08:12 PM   #7
bojoe
bojoe's Avatar
Thanks Tony. This thing idles smooth it just sounds different going through the gears. I think it may be the camshaft with half the miles mine had on it may have something to do with the sound.
Old 07-25-2009, 09:41 PM   #8
bmoeller
bmoeller's Avatar
Running the overhead changed the sound of my C15. Most noticeable with the Jake on. Changed the tone a bit.
"Obama = Hoax and Chains"
Old 07-30-2009, 05:24 PM   #9
nhill2090
Are we talking about a code other than the trim file?
Early 99 7.3 BTS tunes and trans
nhill2090 is offline   Reply With Quote
Old 07-30-2009, 05:27 PM   #10
CaterpillarWrench
CaterpillarWrench's Avatar
Acerts have trim files.Earlier motors have 4 digit trim codes.
CaterpillarWrench is offline   Reply With Quote
3406E injector cups Lowboy Medium and Heavy Duty 15 05-11-2011 02:43 AM
C-12 ecm on a 3406E swaan Medium and Heavy Duty 6 01-12-2011 11:02 PM
Cat 3116 injector setting ESJDIESEL Medium and Heavy Duty 1 07-24-2009 09:14 PM
3406E Injector mod Tyrod Medium and Heavy Duty 65 07-07-2009 05:41 PM
3406E exhaust CAT379 Medium and Heavy Duty 25 05-25-2009 02:20 AM
