Trans Problem! Anyone had P0766/P2703? - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > 2008-2010 6.4L Power Stroke
Thread Details Posted by smoxy, this thread has received 5 replies and been viewed 6302 times.
Old 07-29-2009, 01:53 AM   #1
smoxy
Just got this truck! Trans shifts like crap! Has a hesitation and shutter in reverse. Threw two codes. P0766=Direct Clutch or Solenoid failure in the OFF position resulting in HIGH pressure in the Hydrolic circuit and P2703=The PCM has detected a failure within the direct clutch system. Has anyone else had experience with this problem? Not sure without tearing into it if this would be a clutch disk worn out or a bad solenoid or both? I've heard the solenoids tend to go bad on these! I'm also not sure how hard the previous owner beat on this thing either!
smoxy is offline   Reply With Quote
Old 07-29-2009, 02:07 AM   #2
Super08Duty
Diesel Kid
Super08Duty's Avatar
Tuned or not?
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline   Reply With Quote
Old 07-29-2009, 02:32 AM   #3
smoxy
I don't know if the truck was previously tuned or not. This is one I will not tune until I fix! If I had to guess, I'd say the truck was previously tuned as it only has 32,000 miles and all four tires are severely worn down and previous owner had installed an AFE filter and DPF/CAT-back duel exhaust!
Old 07-29-2009, 04:19 AM   #4
Super08Duty
Diesel Kid
hmm. anyway of contacting the previous owner? I would take it to ford if you dont have a tuner. Could be a bad solenoid.
Colton
Old 07-31-2009, 04:27 PM   #5
SAK
Truck Toyz
SAK's Avatar
Same codes on my truck when my tranny went out. Had the tranny replaced.
2011 Sterling Gray Lariat
5.5" ICON/OUO Lift
20x10 BMF S.O.T.A.'s
37x13.50R20 Toyo MT's
OUO 7" Traction Blocks
OUO Track Bar Ball Joint
Amp Steps
Mag-Hytec F&R Diff Covers
Built by: TRUCK TOYZ
SAK is offline   Reply With Quote
Old 08-01-2009, 02:03 AM   #6
smoxy
Crappy! Sounds like the disks are worn down then. I was hoping for a quick fix like the solenoid. Looks like I'll be upgrading my tranny sooner than I expected for this truck! Time to place an order with Sun Coast!
99 trans. problem Piney boy 1994-2003 7.3L Power Stroke 4 12-19-2007 04:09 AM
Trans... Problem loppfarms 5.9L Cummins 12 Valve (1994-1998.5) 1 12-11-2007 02:45 AM
trans problem smoke rollin stroke 1994-2003 7.3L Power Stroke 7 02-04-2007 06:29 PM
Trans problem crfracer 1994-2003 7.3L Power Stroke 4 05-15-2006 04:28 AM
Trans problem?? RBake 2003-2007 6.0L Power Stroke 14 12-10-2005 01:49 PM
