DT 466 E stalls when it reaches operating temp - TheDieselGarage.com
Thread Details Posted by catwrench, this thread has received 6 replies and been viewed 3073 times.
Old 08-21-2009, 11:43 PM   #1
catwrench
here is my problem , Year 1999 Model 4700 Internationl Engine DT 466 E .
when the engine reaches operating temp.( dash reads 197-198 degrees ) the engine will start to stall out slowly white smoke out stack.Leave truck stand and cool for 2-5 min. truck starts right up.Here is what i have checked new cam sensor,injectors sent in and checked ,new seal washers injector tips copper verses stainless,checked fuel pressure of supply pump fuel 65 psi cold 45 psi warm,run truck on remote fuel bottle check for air very very small bubbles on return fuel ,possible pressure return int to bottle the cause. With no luck ,run codes ,none preset, I can set my watch with the it happens.Standing still run engine to temp. 195-198 degrees . wait 3-5 minute truck will shut right down. Sent truck to shop ,they said cam moving back and fourth 50 thousands , shimmed it out and its fixed, ya right, they can't seam to find problem . ANY HELP !!! catwrench
catwrench is offline   Reply With Quote
Old 08-22-2009, 12:08 AM   #2
Lowboy
Ol Dirt Contractor
Lowboy's Avatar
Might still be the cam sensor?? I had to put a second one in our DT466E before I could get it to run after warming up..
I was Anti-Obama before it was cool!
Leno: ‘Remember the Old Days When Obama’s Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage III’s, H2 for now, Wide Open Performance long block. Spearco Intercooler 4” downpipe Suncoast Tranny, Terminator Oil
Newest--09 Black VW Jetta SportWagen TDI DSG Nav Roof 17" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L 3406E Pittsburgh Power to 900 HP Michigan Stage III OR6051 Turbo & P5 Nathan Horns
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline   Reply With Quote
Old 08-22-2009, 04:17 AM   #3
Dutch
There's your problem.
Send a message via AIM to Dutch
hmm, i would run a snapshot when it stalls and see what happens to icp when it stalls
Dutch is offline   Reply With Quote
Old 08-22-2009, 10:57 AM   #4
catwrench
Yes have tried new cam sensor ,same thing. ICP snapshot i don't have tooling ,but deal told me to diconnect ICP when it stalls and see if it runs ok then, no different . Thanks catwrench
Old 08-22-2009, 12:49 PM   #5
bmoeller
bmoeller's Avatar
I'm not familiar with the 466E at all, but if it has a shutdown solenoid, check that.
"Obama = Hoax and Chains"
Old 08-23-2009, 02:58 AM   #6
ynot
The other guy
Verify the temp with a heat gun. Make sure it's still not climbing in your three to five minutes. If the fan kicks on, the gauge is wrong, hence you may have a heat shut-down, and the lack of logged codes could point to a head gasket and sendor reading air instead of coolant. Heat gun it at the sendor and compaire it to the gauge, bottle test it at the overflow hose, if both show negative try to swap ECM's with another truck to duplicate condition, then check back
ynot is offline   Reply With Quote
Old 08-23-2009, 07:53 PM   #7
catwrench
Thanks for info we will try monday and post what results are.
Catwrench
Operating temp? dieslpower97 1994-2003 7.3L Power Stroke 3 10-04-2007 05:50 PM
Normal operating numbers... jennamax 2003-2007 6.0L Power Stroke 8 03-25-2007 01:22 AM
Water Operating temps Rcannon 2003-2007 6.0L Power Stroke 4 10-11-2006 03:15 AM
NFL Headlines Packers' pick Rodgers reaches plea agreement RSS Feeder The Parking Lot 0 07-10-2006 08:00 AM
Normal Operating costs !!! Morpheus cycles 2003-2007 6.0L Power Stroke 11 03-10-2006 01:13 PM
