how to turn up injector pump - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins 12 Valve (1994-1998.5)
Thread Details Posted by johndeere51, this thread has received 4 replies and been viewed 4481 times.
Old 08-25-2009, 10:18 PM   #1
johndeere51
I own a 95 cummins 12v and the injector pump is already turned up a little i was wondering how to turn it up a little bit more.
johndeere51 is offline   Reply With Quote
Old 08-25-2009, 11:04 PM   #2
hccumminssmoke
Official TDG Doctor
hccumminssmoke's Avatar
These guys can take care of you we've got some good 12v tweakers on here
Nate
Kickin' It At The Passing Lane
hccumminssmoke is offline   Reply With Quote
Old 08-25-2009, 11:46 PM   #3
SSpeeDEMONSS
SSpeeDEMONSS's Avatar
Send a message via Yahoo to SSpeeDEMONSS
what is done to it now? lets see, you can grind the fuel plate and slide it forward. you can slide the AFC housing forward. you can adjust the starwheel screw. you can adjust the "smoke screw". you can adjust the timing on it. you can crank up the governor springs a little. what all do you want out of it?
BRING BACK THE OLD TDG!
oh well, i have a map to the darkside
SSpeeDEMONSS is offline   Reply With Quote
Old 08-26-2009, 12:08 AM   #4
arcticdiesel
arcticdiesel's Avatar
Turning up the pump
A great outline. Also there is a ton of detailed information in the top sticky threads. Definitely a good crash course.
arcticdiesel is offline   Reply With Quote
Old 08-29-2009, 05:13 AM   #5
sstockton
sstockton's Avatar
A good start would be determining what has been done to the pump, and what you want out of this truck. "Turned up a little" is subject to interpretation as well. A good start seems to be, a modified plate, AFC mods, and a set of 3k gov. springs. The smoke screw, just adjusts pre boost fuel, and won't give you any added power per say, The star wheel just adjusts the pre load on the spring in the AFC. Read up on the stickies in the top of this section, and you will gather a fair amount of information that can be used for deciding what you want out of your pump and how you want it to act. Some guys love smoke, and some guys like myself strive to limit it as much as possible.
2000 2500 reg. cab 4x4 auto 577hp
09 6.7L QC LB stick, 4x4.
TOTAL PERFORMANCE DIESEL 707-545-FUEL (3835)
www.totalperformancediesel.com
sstockton is offline   Reply With Quote
turn up standyne pump? 6.2smoke'r 6.2L Diesel Engine 6 08-07-2010 02:41 AM
How to turn up the injector pump?? bp m1009 6.2L Diesel Engine 5 07-25-2010 08:50 PM
how to turn pump up. southtexasidi 7.3L and 6.9 IDI (Pre 1994) 4 01-25-2009 09:56 PM
How To Turn Up Fuel Pump! fordboy324 Duramax 2001-2004 (LB7) 18 01-03-2008 01:49 AM
How can i turn up my pump? rrkyle 7.3L and 6.9 IDI (Pre 1994) 3 12-01-2006 03:12 AM
