Cummins ISX vs CAT C-15 - TheDieselGarage.com
Thread Details Posted by sdhDIESEL, this thread has received 26 replies and been viewed 21531 times.
Old 12-27-2008, 12:23 AM   #1
sdhDIESEL
seeing what you guys think?, since Cats getting out of the truck Market, And the introduction of Selective Catalyst Restriction (SCR) and Urea Injection, Diesel Exhaust Fluid (DEF),
sdhDIESEL is offline   Reply With Quote
Old 12-27-2008, 01:25 AM   #2
Dualie
26 tires rolling
Dualie's Avatar
I have an 06 Cat C-15 Acert 550 and its been very reliable for me so far. with that said you couldn't GIVE me a 2008+ cat. no way no how.
Cummins has just been road proven a more reliable answer to the new emissions regs.
Dualie is offline   Reply With Quote
Old 12-27-2008, 02:28 AM   #3
sdhDIESEL
and in 2010 they are totally changing there engines once again, its ganna be tough to keep up, with the 2007 engine only ganna be made a few years, from what i have heard 2010 emission is going to be the last step.
Old 12-27-2008, 02:37 AM   #4
theakerstwo
What have you hear? glenn
theakerstwo is online now   Reply With Quote
Old 12-27-2008, 03:45 AM   #5
DieselPower
2-Stroke God
DieselPower's Avatar
You mean the last step before what? No more engines??? End of the world? I'm sure there's a lot more to come. I say CAT, Cummins Detroit Etc should shove it up the EPA's @$$es and tell them to instantly design a reliable power plant and produce it, put their name a warranty behind it, andmake it affordable and efficient.. Betcha the rules would change real quick.
Fact of life is that diesels put out almost no greenhouse gases, and PM settles out of the air rather quickly, and it's hard to push global warming when the planet is cooling down. AND, a volcano puts orders of magnitude more pollutants in the air than human activities do, and they are responsible for most of the acid rain.
"Not everything that can be counted counts, and not everything that counts can be counted."
- Albert Einstein
How come you guys engines miss every other powerstroke? Your truck, 0 to 180 in 1-2-3-4stroke, My Truck, 0 to 180 in 1-2stroke!
I belive truck boxes are infinitely cooler than 30" rims -You can't store squat in a hubcap.
Cummins Powered Club #3
Dually Club #65
DieselPower is offline   Reply With Quote
Old 12-27-2008, 06:03 AM   #6
Dualie
26 tires rolling
Dualie's Avatar
I think he means its the last planned emissions tier in the EPA's master plan to drive prices for new trucks up 20 grand, reduce engine life by 25%, kill 2 mpg's, and drive maintenance costs up.
2010 will bring SCA with the Tier 4 standards
Trucks by Ford & IH and Kenworth & Cat
Trailers by Murray, Fetherlite and Walton.
Booms by Manitowoc Cranes, National & Grove
Welders by Lincoln powered by Deutz
Old 12-27-2008, 12:05 PM   #7
pullingtrucker
Wanna be door swinger
pullingtrucker's Avatar
Send a message via Yahoo to pullingtrucker
If you could buy now, I would go with the ISX (especially the ISX without SCR and DEF). The ISX has the best fuel mileage and you at least know that Cummins is gonna be in the truck engine market longer than CAT. The C-15 is a decent motor but the power isn't there like the other CAT motors. My C-15 has been a pain in the ###. I think I have finally got the problems worked out, even though the mpg still isn't increasing much.
'06 379 Peterbilt with a C-15 MXS 550hp, 200gph FASS, high flow mufflers, fuel harness, shimmed fuel pump, crankshaft balancer, Bully Dog Big Rig downloader, Bully Dog exhuast manifold, Spinner II bypass filter , a big Detroit Radiator, custom built Lipe clutch, Schaeffer's synthetics in all boxes, and a 18 speed tranny.
'06 53' Utility 3000R with a Carrier unit hanging on the nose. Just a plain trailer with little frills.
Ridin Dirty Club #12
pullingtrucker is offline   Reply With Quote
Old 12-27-2008, 04:23 PM   #8
sdhDIESEL
yes, 2010 is the last step, well that Cummins has told us, ISX in 2010 is going ot be a single overhead cam, with High Pressure Common Rail, EGR Valve will be back on the passenger side, there a pain in the ***** to change on the driver side, and from what we have been told performace will go up with the HPCR set up.
Old 12-27-2008, 04:37 PM   #9
John_G
Super Moderator
John_G's Avatar
I have done extensive research on the emissions regs and from what I can tell, aside from the HDOBD requirements for 2010/2012 emissions regs won't change much after 2010.
They will be expanded to ALL engines, gas, diesel, off road, marine etc., but that's a 2020 goal I think.
I vote for LIBERTY!
Old 12-28-2008, 01:28 PM   #10
sdhDIESEL
so how smart is this..
just a scenario,
say a farmer buys a new truck with the DPF, goes in a corn field to fill, like farmers do, during harvest, it starts to regen in the field, anyone thought of this, its ganna be worse if the try pushing the DPF's on Ag equipment there in worse enviroments.
1969 Ford Cummins Crew Cab Conversion... HRDROKN Cummins in Fords 613 01-11-2012 03:22 PM
'96 Ford Cummins conversion ncovey Diesel Conversion 31 02-06-2009 03:02 AM
any vendors have a tranny rebuild kit for a 1994 cummins automatic? blksmk Supporting Vendors Forum 3 01-04-2009 09:55 PM
2002 24valve Cummins Engine and Transfer Case ruffmanatv Whats Been Sold 7 12-26-2008 11:32 PM
Cat 3126 vs Cummins 8.3 timark80 Medium and Heavy Duty 6 12-24-2008 12:32 AM
