International V800 class 8 tuck engine?? - TheDieselGarage.com
Thread Details Posted by michael b, this thread has received 13 replies and been viewed 11420 times.
Old 09-07-2009, 04:42 AM   #1
michael b
I was talking to an old International mechanic about the new maxfoce engines and he mentioned that International tried to enter the class 8 engine market before with an engine known as the V800 Now I thought I had a fairly good knowledge of class 8 truck engine history but this one snuck by me I guess. This guy reminisced about this engines like a sentimental person might reminisce about their fist love. I searched the internet for information and was able to come up with a few old brochures. Anybody ever see and or drive one of these things? One thing that caught my eye in the specs that it is over square, kind of unusual for a truck engine.
michael b is offline   Reply With Quote
Old 09-07-2009, 03:27 PM   #2
bmoeller
bmoeller's Avatar
Not really surprised it might be over square. Many V8 engines are. Gas or diesel.
Never seen or head of it being used in a truck before. Only seen one 550 in a truck. The rest I saw were in 14 and 1568 IH tractors.
"Obama = Hoax and Chains"
Old 09-07-2009, 04:27 PM   #3
bojoe
bojoe's Avatar
This was the same engine that was in the 4586 and 4786 IH 4 wheel drive tractors. It was called a DV-800 300 HP and 725 lb. torque in a 4786. The 4786 was made from 78-81. It was also in the 4568 as a DVT-800 made in 75 and 76.
*1985 KW K100, 3406B, 13, 3.73
*2010 Mac Dump.
*1986 IH 9670 400 Cummins, 13, 3.91
*2004.5 Dodge 2500, 5.9, auto, 4x4
*A shed full of old John Deeres and more junk than I care to list.
bojoe is offline   Reply With Quote
Old 09-07-2009, 08:34 PM   #4
michael b
What other large diesels (10+ liter) were over square?
Old 09-07-2009, 09:53 PM   #5
bojoe
bojoe's Avatar
John Deere 619 (10.1 L) 5.125 x 5
*2010 Mac Dump.
Old 09-08-2009, 12:41 AM   #6
m37charlie
m37charlie's Avatar
Do you know or remember anything about a D-301 6 cyl small diesel for Travelalls and 12-1300 series pickups? This was BEFORE the Nissan SD33T in the Souts. I remember seeing one in the late 60s or early 70s.
Charlie
05 Unimog U500/Unicat camper
m37charlie is offline   Reply With Quote
Old 09-08-2009, 01:54 AM   #7
bojoe
bojoe's Avatar
Charlie
That's a new one on me. Never knew they put a 301 outside of ag and industrial applications. I have seen some guys take old D-301s and put in old IH trucks.
*2010 Mac Dump.
Old 09-08-2009, 04:20 AM   #8
fest777
over squared diesels, 903 cummins 4 3/4 stroke 5 1/2 dia piston a real dog just like the v8 350 int. toro flow was to i believe the 785 v8 cummins looks alot like a 903 but a little less stroke same piston,there may have been more thats all i remember .all were pigs gutless except the vt 903 it ran like a 318 detroit on a good day maybe
fest777 is offline   Reply With Quote
Old 09-09-2009, 02:53 AM   #9
bpogue
bpogue's Avatar
Stupid question?
What does it mean when you say an engine is over square?
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline   Reply With Quote
The Following User Says Thank You to bpogue For this addition to TDG:
Lmackattack (09-09-2009)
Old 09-09-2009, 04:07 AM   #10
Lmackattack
Highway to Hell
Lmackattack's Avatar
Not stupid its a good question...
It means that the Bore of the cyl is larger than the length of the stroke. most often over square engines can spins faster due to the short stroke and will make high hp but lacks some in the torque dept..
From wiki so take it with a grain of salt..
Oversquare, or short-stroke engine
An engine is described as oversquare or short-stroke if its cylinders have a greater bore diameter than its stroke length - giving a ratio value of greater than 1:1.
For example an engine which has 100 millimetres (3.94 in) bore, and 80 millimetres (3.15 in) stroke has a bore/stroke value of:
100 mm / 80 mm = 1.25:1This is generally considered to be a positive trait, since (all things equal), a shorter stroke results in less friction on the cylinder wall, and less stress on the crankshaft.[citation needed] An oversquare engine is generally more reliable,[citation needed] wears less,[citation needed] and can be run at a higher speed. In oversquare engines, low-speed torque tends to be lower, since torque is relative to crank throw - the distance from the crankshaft main bearing centre to the crankpin (big end) centre, as well as the lowering pressure of the combustion gases as the piston descends.
Engines can be modified by being "de-stroked", shortening the stroke to increase maximum rpms and top-end power, at the expense of low-end torque.
Oversquare engines tend to be lighter[citation needed] and shorter[citation needed] than undersquare engines of similar engine displacement along the direction of piston travel, but they are wider in directions perpendicular to piston travel. As the length is not a large problem, these engine types are highly favored by many manufacturers because of their power and compact size.
Some Formula One engines have a bore to stroke ratio of approximately 2.5:1, and are capable of revving to 19,000 rpm.
1978 MACK RS700L
285 HP @2100 RPM 1080 TORQUE. @1200 RPM
2 STICK 6 SPEED, 4.17 REARS ON 34K CAMELBACK SPRINGS,206"WB, 4" STRAIGHT STACKS BLOWING BLACK,
OH...AND A FEW TWISTS OF THE FUEL SCREWS ....THANKS AGAIN... FJH!
Lmackattack is offline   Reply With Quote
The Following 3 Users Say Thank You to Lmackattack For this addition to TDG:
bpogue (09-09-2009), dickeypjeep (09-09-2009), M123KT-450 (09-14-2009)
1984 6.9 L International Harvester V8 IDI Diesel Engine (F250 Pull) do_lai Ford Parts 1 08-23-2009 07:36 AM
2001 International 4700 Bucket T444 engine ignition problem Braelecorp Medium and Heavy Duty 1 05-23-2009 04:34 AM
Bio and performance tuck? imported_BillM2004 5.9L Cummins (2003-2007.5) 14 04-22-2008 04:32 PM
International 454 engine(Help) International T Medium and Heavy Duty 8 06-23-2006 04:25 PM
This tuck is wild MXT I10HaulR Medium and Heavy Duty 16 01-07-2006 02:05 AM
