| Thread Details Posted by vmantunes, this thread has received 12 replies and been viewed 6436 times. |
#1 |
Diesel Fuel in Coolant
Why is there fuel in my coolant resevoir??
2005 FORD F-350 6.0 Power Stroke vmantunes Last edited by vmantunes; 09-10-2009 at 02:51 PM. |
| Sponsored Links | |||
Advertisement | |||
#2 |
cracked head!
2004 F350 CC DRW King Ranch X-3 tunes by DJ,QT,GH,ID,Gyphon FICM tuner,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB Thanks to:JASONS REPAIR AND PERFORMANCE-TELFORD,PA. "Are diesel pickups hot rods? Yes,they are-perhaps the most versatile hot rods ever made"---Diesel Power Magazine |
#3 |
What else might be causing it???
cracked head... or??? |
#4 |
as far as I know only a cracked head will cause this. maybe other members will chime in with any other info.
#5 |
Got Torque?
Images: 80
Maybe a bad injector and a blown HG? How does it run? Smoky? Low power? Any other symptoms other than you can see fuel floating on the water in your coolant reservoir?
Black 2003 F350 Dually, Nothing Stock Other Rides: Black 2006 300C SRT8 Black 2012 CTS-V (630HP) Black 2008 Mercedes E550 |
#6 |
No problems... no smoke, no loss of power... just the fuel in the coolant resevoir which spews out when the engine is hot
what is an HG?? |
#7 |
Got Torque?
Images: 80
head gasket. Sometimes, when an injector goes, it dribbles fuel out into the cylinder. If you have a bad head gasket, it could leak in there. But a cracked head is more likely. I guess, before we go nuts on this diagnosis, how much fuel is in there? And you are positive it is fuel?
#8 |
I am positive it is fuel...
at first i thought a fuel line was punctured (only because i was never able to open the coolant resevoir because the engine was always hot). the trucks been stopped for a few days so i finally got around to opening the cap. I am positive it is fuel... how much fuel?? i don't know... probably more than a 50/50 mix in the resevoir itself, but its hard to say. |
#9 |
A faulty injector cup could cause this.
2004 F-350 XLT SC 4x4: SCT, AFE stage II, autometer gauges(pyro, boost, tranny, fuel), edge insight, CFM large mouth intake elbow, spearco, snow performance water injection, 5" stacks, ARP's, fluidampr, hypermax fire rings, LIPD regulated return, FASS, fuelab, casserly 190's, 64/71/70 turbo(polished compressor housing)modded FICM(ID), Hellmann's sump, electirc fans |
#10 |
Yup, I wouldn't just jump to a crack headed, thats pretty expensive to fix, O-ring ain't nothing to fix, its like a 1-3 dollar part.
Real Trucks Burn Diesel! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fuel in coolant??? | my97stroker | 1994-2003 7.3L Power Stroke | 6 | 04-10-2009 03:43 AM |
| DIESEL in COOLANT any suggestions | kirk1742 | 2003-2007 6.0L Power Stroke | 11 | 02-24-2009 01:01 AM |
| Coolant, Oil and Fuel Leak! | My66coupe | 1994-2003 7.3L Power Stroke | 8 | 11-29-2007 01:07 AM |
| Oil/Diesel in Coolant reserve tank? | Jakkle5 | 2003-2007 6.0L Power Stroke | 7 | 07-29-2007 04:44 AM |
| Gauges; Coolant And Fuel | thompsd | 2003-2007 6.0L Power Stroke | 4 | 03-14-2007 09:30 PM |
| New To Site? | Need Help? | TDG Specials |
