No start, unless wiggle gear selector lever.. - TheDieselGarage.com
Thread Details Posted by 99fordtruckguy, this thread has received 3 replies and been viewed 2057 times.
Old 10-10-2009, 05:22 AM   #1
99fordtruckguy
A lot more often lately, when I go to start up my truck, it doesn't turnover. If I wiggle the gear selector lever (auto tranny, in PARK position) it allows the ignition to work and the truck fires right up. Is this a problem with the park shift solenoid/interlock? Or maybe the digital transmission range sensor? It seems to be getting worse by the day. It's like the truck is not quite in PARK all the way, and so it wont let the truck start until I adjust the selector a bit. Can anyone point me in the right direction for a repair? Thanks
1999 Ford (Early, 4/98) F250, 7.3 PSD, Supercab, 4x4, XLT, 4R100, 6637 DIY intake, 4" T.B. exhaust, '06 headlights w/Dfuser harness, '06 tow mirrors, '06 fender/door badges, '06 complete front facelift, '02 40/20/40 seats, '02 upgraded battery cables, 16x12 DC1's with 305/70/16's (soon to be bye bye), RCD hanger/shackle leveling kit, white face instrument cluster.
99fordtruckguy is offline   Reply With Quote
Old 10-10-2009, 12:23 PM   #2
myf350
myf350's Avatar
Look under the dash at the base of the steering column. While you are looking under there wiggle the gear shifter or have someone do it for you. I will bet you see a piece with a couple torx head screws that loosened up. Tighten the screws and you will be good as new.
SOLD...early 99 F350 CC 4WD SRW, Tymar intake, 4 in. turbo back straight pipe w/ 5 in. tip, DP tuner, 203 t-stat, Timbrens in the rear, front leveled, King Ranch wheels, ISSPro gauges, Weston brush guard, rebuilt my trans using a Torqueshift converter
08 CC LB DRW MT 4WD Ranch Hand bumpers...stock for now
myf350 is offline   Reply With Quote
Old 10-10-2009, 03:27 PM   #3
John_G
Super Moderator
John_G's Avatar
Either that or the Neutral Safety Switch on the trans (DTR it's called) is out of adjustment.
I agree with the above poster, normally it's one of the screws on the top side of the column above the brake pedal that holds the shift quadrant to the shift tube in the column. I have seen the column tube bushings wear out and cause the same symptoms, $12 in parts (2 bushings) and it's fixed.
I vote for LIBERTY!
Old 10-10-2009, 11:41 PM   #4
double-s-diesel
rock removal technition
seen it happen a bunch of times
1996 psd 5speed 4x4 cc 8' bed, 3" body lift, 35's swamped, dp-tuner, intercooled, custom fuel system, no fan, and a few other goodies, 263k. 349.2hp sold
2003 7.3 4r100 4wd sc 8', xlt 20th anniversary edition
stock cept for duals. 260k sarted out as a 2wd xl work tk
Early 99 CC dually 4x4 4r100 dark lights, dark windows, stainless simulators
99 v-10 4x4 sc sb auto 275hp gas guzzler
double-s-diesel is offline   Reply With Quote
end peice on gear selector 7.3rambaler Ford Parts wanted 1 07-08-2009 03:41 PM
Shift lever help 4cstr General Ford Truck and Excursion 11 04-24-2009 09:39 PM
Sloppy gear lever jethrow General Ford Truck and Excursion 3 02-25-2008 06:11 PM
noisy gear shift lever dondiesel444 Heavy Duty 11 02-11-2007 01:38 AM
The 05 Ex has a new HFCM drain LEVER !!! JohnBoyToo General Ford Truck and Excursion 5 01-23-2006 04:06 PM
