MAP Sensor problem? - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (1998.5-2002)
Thread Details Posted by Aaronchev72, this thread has received 5 replies and been viewed 3298 times.
Old 10-22-2009, 09:39 PM   #1
Aaronchev72
Aaronchev72's Avatar
Send a message via AIM to Aaronchev72
MAP Sensor problem?
Hello all, I have a '99 3/4 ton that started acting up last night. The check engine light came on and it was sluggish for a minute, then it ran like normal. I ran it around this morning and had the computer checked, the code that came up said the MAP sensor had low voltage or something. After the computer was hooked up the check engine light went off and it ran great till this afternoon. Again it ran real sluggish, wouldn't tach up like normal, then it ran like normal again. Does this sound like something that the map sensor would cause?? Also, i noticed that there was a connection unplugged on the fuel filter housing this morning and i reconnected it. But it is still connected so i'm sure that it can't be part of the problem. Will a new MAP sensor fix the problem? The truck is all stock with the exception of a K&N air filter, straight pipe, and a fass lift pump. Any imput will be great appreciated!
Aaronchev72 is offline   Reply With Quote
Old 10-23-2009, 01:00 AM   #2
01quadcab
remove the map sensor and clean it. http://mopar.mopar1973man.com/tips/c...map-sensor.htm
01 quad cab 4x4, edge drag comp, 4" exhaust, fass 150, 250 ddps, Jefferson State compounds 683hp so vp 11.91. AMSOIL front to rear. now back to stock 95 fummins in the works
01quadcab is offline   Reply With Quote
The Following User Says Thank You to 01quadcab For this addition to TDG:
Aaronchev72 (10-23-2009)
Old 10-27-2009, 03:08 PM   #3
Mopar1973Man
2nd Gen Guru
Mopar1973Man's Avatar
Send a message via Yahoo to Mopar1973Man
You might want to catch up a bit and read my article...
Mopar1973Man Notes: This cleaning procedure will not correct any error codes that are being produced by the MAP sensor (P0237 or P0238). If you got a fueling enhancement box of any type hooked to the MAP sensor lines it could be a internal fault of the boost fooler circuit causing the MAP sensor error code. If the truck is stock then the MAP sensor requires replacement.
Then here is the diagnostics for MAP sensor codes...
http://mopar.mopar1973man.com/tips/c...nsor-codes.htm
Michael Nelson - 2002 Dodge Cummins & 1996 Dodge Ram 5.9L Gasser
116K Miles On My VP44 - 4 Years of 2 Cycle Oil Diet! - Mixed at 128:1 Ratio - 25.3 MPG maxed out!
Mopar1973Man is offline   Reply With Quote
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
Aaronchev72 (10-28-2009)
Old 10-28-2009, 11:25 PM   #4
Dinner
Dinner's Avatar
Could be something as simple as corrosion inside the plug as well.
2001 Dodge 2500 4X4: Goerend, TST, Smarty, MVP, BD Rad, Injectors, Two Turbo's, Snow Performance, Supporting Mods...
12.7 @ 108mph Aug 2011
Canadian Club Member #14
Dinner is offline   Reply With Quote
Old 10-30-2009, 02:28 AM   #5
Mopar1973Man
2nd Gen Guru
Any news to if you figured out you problem???
Old 10-30-2009, 12:09 PM   #6
Aaronchev72
Yeah, i ended up just replacing the sensor. Seems to have cured the problem. I read through the cleaning proceedure and gave it a try, but it didn't help so i just replaced it. No problems now! Thanks for all the advice guys!
vt 365 sensor problem kilalove21 Medium Duty 2 07-28-2009 12:22 PM
Problem with back-up sensor alarm Joepel43 General Ford Truck and Excursion 2 03-01-2009 05:39 PM
Cat 3116e: Fuel Temp Sensor & Boost Pressure Sensor probablecause Medium Duty 0 02-03-2009 01:54 AM
Reverse vehicle sensor problem MRBOHN23 2008-2010 6.4L Power Stroke 7 12-10-2007 02:35 AM
Problem!! Cam Positioin Sensor?? dotson90 1994-2003 7.3L Power Stroke 11 08-16-2007 06:36 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
