Cat 3406 overhead - TheDieselGarage.com
Thread Details Posted by flips, this thread has received 14 replies and been viewed 12530 times.
Old 10-30-2009, 12:28 AM   #1
flips
flips's Avatar
Cat 3406 overhead
When doing an overhead, do you adjust the bridges first then the valves
or does it not matter. I know TDC intake 1 2 4 @.015 exhaust 1 3 5 @ .030
then rotate and do the others. 346D jake @ .067
When checking mine today, the bridges are loose, I can move them by hand on both the intake and exhaust. The exhaust valves are close to spec as are the jakes. But the intake valve lash is very tight ( I cant squeeze .005 under it ) all intakes are this tight.
I only adjusted # 6 intake today. I first tightened the bridge up (went to contact plus 30 deg) Then I backed the intake valve to .015 when I was done you could move the bridge by hand again.
I assume this is being done right
3406C 8PN mechanical
Old School Cats Rule
flips is offline   Reply With Quote
Old 10-30-2009, 12:42 AM   #2
CumminsISXpower
CumminsISXpower's Avatar
Your doing fine.bridges then rockers
CumminsISXpower is offline   Reply With Quote
Old 11-10-2009, 12:10 AM   #3
NoWake200
Loves Jet Noise
NoWake200's Avatar
Send a message via Yahoo to NoWake200
What exactly is involved in an overhead, when does it need to be done and is it the same process for the C-15's (Bridge Motors)?
TWA
2011 F-350 Lariat, 6.7 PowerStroke, Crew Cab, Short Bed, White with 20" Wheels.
NoWake200 is offline   Reply With Quote
Old 11-10-2009, 01:26 AM   #4
SledMan
SledMan's Avatar
The 3406E and C15 up to the ACERT do not have adjustable bridges. You set the valve lash in the same sequence as any other 3406....although you have to have a Cat gauge to set the injector height.
SledMan is offline   Reply With Quote
Old 11-10-2009, 01:42 AM   #5
SledMan
SledMan's Avatar
Also, a good rule of thumb is every year or 100K miles on the overhead. As far as how to do it, you find TDC for #1 or #6. You have to pin the flywheel, and both rockers will be loose on either #1 or #6. I like to start with #1 TDC and do intake 1,2,4.... and exhaust 1,3,5.... injector 3,5,6 and Jake 1,3,5. Mark the balancer and rotate one time. Then do intake 3,5,6....exhaust 2,4,6....injector 1,2,4....and Jake 2,4,6. Jake lash varies according to engine model and horsepower from .027 to .037. A good rule of thumb I use is .035 Jake lash for all applications. I have owned all series of E and C-15's and it always worked good for me.
The Following 2 Users Say Thank You to SledMan For this addition to TDG:
keydl (11-10-2009), NoWake200 (11-10-2009)
Old 11-10-2009, 03:16 AM   #6
NoWake200
Loves Jet Noise
NoWake200's Avatar
Sledman... thank you for the reply and great information.
TWA
Old 11-11-2009, 06:31 AM   #7
legend10
legend10's Avatar
Is there a special order when you run the overhead? Like Valves then jake then injector?
legend10 is offline   Reply With Quote
Old 11-11-2009, 11:44 AM   #8
dondiesel444
dondiesel444's Avatar
does everyone agree 100K is a good interval to get an overhead?
1997 Western Star 4964FX double frame tri-axle dump truck, 3406C Cat Power, 8LL, 46K rears on Chalmers, lots of lights, Sirius radio
2001 F-250 PSD CC 4X4 Lariet, 97k miles, DP Tuner PCM, 3" lift, 305/70R16's on 16x10 wheels, 6637 air filter, straight piped, more to come.
dondiesel444 is offline   Reply With Quote
Old 11-12-2009, 12:53 AM   #9
SledMan
SledMan's Avatar
Always do valves, injectors, then Jakes. 100K interval is Cat's recommendation
Old 11-15-2009, 03:04 PM   #10
domniman2002
PB SHOP FOREMAN
domniman2002's Avatar
give me your email address and i can go into cat web and email you the steps and the settings.......
domniman2002 is offline   Reply With Quote
3406 b cajunguy359 Medium and Heavy Duty 15 06-30-2010 12:09 AM
3406 B 700 hp HiPer Express Medium and Heavy Duty 36 01-26-2010 11:10 PM
3406 550 fixed it self? leep Medium and Heavy Duty 1 10-06-2009 03:15 AM
3406 c to e convert???? bseals Medium and Heavy Duty 6 06-13-2009 07:45 AM
cat 3406 peec need help root577 Medium and Heavy Duty 8 08-10-2007 01:36 AM
