Ficm injector buzz test - TheDieselGarage.com
Thread Details Posted by bigblue777, this thread has received 19 replies and been viewed 24862 times.
Old 11-01-2009, 03:16 AM   #1
bigblue777
Heh guys,
Can anybody give me some advice on how to perform an injector 'buzz' test. I just completed replacing head gaskets, ARP Head studs, complete cylinder head overhaul, updated HPOP STC fitting, etc, and cannot get the engine to fire. Engine builds plenty of ICP: up to 2500psi cranking. I checked all injector connectors/pins, as well as ground wire connection at FICM...all seems well? Fuel pressure from FASS builds 62-64psi..no problem there...?
I have popped the little cover on the top of the FICM and tested the voltage at the far right screw: about 8.5 volts... I dont think that is right...shouldnt it be around 45Volts? I turn the key on and I get no initial buzz at all from the injectors without even cranking the engine.... When I do crank the engine the tach goes up to about 400rpm. The batteries are fully charged and the starter is brand new.
Unfortunately, I do not own a scanner, as the SCT2 programmer I have doesnt read squat!
I have checked the power fuses at the fuse box on the fenderwell and none appear to be blown...? The three wire harness plugs to the FICM are spotless (I never disconnected them until now to figure out if there was an issue there...everything looks perfect.)
I have to say, I precisely remember before I tore the top of the engine down to replace the head gaskets while trying to diagnose why the engine died, I recall the injectors buzzing as I cranked the engine over checking ICP pressure. Now, I did at some point disconnect the ground to the FICM/harness at the back and continued cranking the engine over...would this have caused damage to the FICM?
So, to recap, originally, while testing my truck with my replacement tranny a month and a half ago the engine just flat out died and would only crank... I thought I diagnosed the problem as being the HPOP STC fitting, as it definitely was bad (leaking-ruptured internal o-ring) ...so even though I thought that was why it wouldnt restart...I decided to take care of the puking issue and all is done, but engine still wont run! lol
Any help MUCH appreciated!
Lenny
2006 F350 King Ranch, CC Dually, 6.0L, auto/torqshift,4X4, all options except moon roof. 4:30's replaced with 3:73's (yes, thats correct), Gear Vendors auxilary overdrive unit, ID's SCT2 Xtreme Race with full TC lockup, MSD Digital propane injection with 23.9gal propane tank, DPPI 304 stainless dual exhaust & AFE Proguard filter & custom intake elbow. :Thumbup:
bigblue777 is offline   Reply With Quote
Old 11-01-2009, 03:56 PM   #2
outlaw6oh
outlaw6oh's Avatar
I'd say check your wiring, an injector going out won't cause your truck to not run but loose or chaffed wires will. A bad injector will cause rough idle and running conditions. The fact that your truck did this before being an intermittent issue wiggle those wires around and double check your connections.
2004 F350 Built by Ford fixed by PDR Diesel, Xtreme tuned by InnovativeDiesel, gauges by ISSPRO
outlaw6oh is offline   Reply With Quote
Old 11-01-2009, 06:40 PM   #3
teamroper60
SLAPS President
teamroper60's Avatar
Images: 9
It takes a good bit of cranking to get one to fire off after work like that due to air in the system. In fact, most shops will put a charger on them while they crank, simply because it will run the batteries dead before it has cranked enough to fire...
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; Silverline turbo-back dual exhaust; 155's from Full Force Diesel (Casserly); Di-Pricol gauges; ARP studs; Dfuser regulated return; AFE PG7;Tunes by Tony Wildman & IDP; B&W hitch; DIESELSITE Coolant filter; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT radio; JL Audio 275w amp w/ 12" sub; Alpine door and rear seat speakers. pics
#43
Dually club member #76
SLAPS President and Webmaster
If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen. - quote by Samuel Adams
Political correctness is a doctrine fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end
teamroper60 is offline   Reply With Quote
Old 11-01-2009, 10:16 PM   #4
bigblue777
Absolutely! That is why I had a battery charger hooked up from the get go. I pre filled all the injector tops with oil. I also prefilled the oil rails completely...all the way up to the little plugs on top. I also filled the oil galley for the HPOP feed as well. I went ahead and primed and reprimed the fuel system running the fass pump and cracking open the return line from the filter housing. Like I stated earlier, those areas were well covered IMO.
I have since ran down the wiring schematic to and from the FICM and right now it appears that there is no ground being sourced FROM the FICM to the FICM relay, to activate the relay. THERE IS however, 12+v input at #7 pin of FICM plug with KOEO and a constant 12+V at #27 pin whether the key is on or off..... ( ) I can manually depress contact on FICM relay at fuse panel on fenderwell and I will then get a constant 48+ Volts at farthest screw to right on top of FICM...even when cranking engine..though the engine will still not fire!! Something is awry within the FICM IMO...whether its a synch issue or logic issue, I just dont know, as my head is spinning!
Eventually we'll get it figured out, even if I have to drag my truck to a Ford Dealer!
I will say though, she may not run, but she sure looks good!
I appreciate everyone's input.
Thanks guys!
Old 11-02-2009, 12:42 AM   #5
outlaw6oh
outlaw6oh's Avatar
well according to the thing swamps posted elsewhere your FICM is putting out too low of volts
This is posted by Jonathan from swamps:
If your 6.0 will not start cold, the issue may be either the glow plugs or glow plug controller, or it can be the FICM (Fuel Injection Control Module). If after a long cranking with no start you get a lot of white smoke (raw unburnt fuel) out the exhaust, the problem is in the glow plug system. If you do not get any smoke, the problem is probably in the FICM.
The 6.0 injector has two solenoids on it; one turns the injector on (open) and the other turns it off (close). A few years ago, Ford came out with a new program referred to as inductive heating for the FICM, intended to combat issues with missing and rough-running during cold startup due to sticking spool valves in the injectors. This program works by running “extra” current through the close coil to generate heat and warm up the spool. On paper it was an excellent idea, and I advised a lot of potential injector customers to have their FICM’s reflashed rather than buy a set of injectors.
Based on my testing, it appears that the early models of FICM’s only used the inductive heating when the EOT was less than 48*F or so. The “first” updated heating strategy turned it on any time the EOT was less than 184*F, meaning every time you started the truck if it was shut off for more than 10 minutes! Ford’s newest update to the heating strategy has it coming on below 148*F; better, but that’s still a lot of current draw.
Unfortunately, there have been some very serious consequences.
Although the FICM on the 6.0 is way more “intelligent” than the IDM on a 7.3, its basic job is to convert 12VDC to 48VDC and deliver this to the injectors at the proper time. Under normal operating conditions, the FICM typically draws 6-7 amps at 12V into the FICM power supply, which is well within its design limits. However, with the inductive heating active this current draw increases to 24-32 amps—it pegs the 30 amp meter on my test bench! Although the FICM power supply is capable of sustaining this load for short periods of time (1-2 minutes) it eventually gets very hot.
If this was all that happened, things wouldn’t be too bad, but there are several components on the printed circuit board that were not properly soldered during the manufacturing process, and as the PCB heats up and expands, the solder under these components cracks and they lose their electrical connection. The FICM’s 48 volt power supply is actually four separate or independent units; if one of the four goes down, the other three can supply enough current to run the truck, even with the inductive heating active. If two of the four go out, the truck will start and run normally as long as it is warm out, i.e. as long as the inductive heating does not turn on. If three of the four go out, the truck will probably not start or run unless it is at full operating temperature, and even then it may not start. If the injector voltage is over 35 volts, they run OK, although not as well as when it is 48 volts. If the voltage drops below around 24 volts, the injectors cannot fire. While most scan tools will display the FICM voltage, they do not always show the correct value. For instance, AutoEngenuity can only display voltages between 40 to 56 volts, so if the voltage is 35, it will display 40.
How to check your FICM for proper voltage output.
(Perform this check when the engine is completely cold.)
1. Remove the two bolts that hold the coolant reservoir to the cowl and push the reservoir out of the way forward and to your right. You do not need to disconnect any of the hoses.
2. On top of the FICM is a small cover held on by two #20 Torx screws; remove these two screws and pry the cover off.
3. On 2003 and early 2004 trucks, you will see 7 screw heads under the cover. On 2004 and later trucks you will see 4 screws.
New Page 1
4. Take a multi-meter set on DC volts and connect the ground lead to battery negative, and with the key ON measure the voltage at the screw on your right—closest to the driver’s side fender. Do not let the probe short against the case! The voltage should be right at 48 volts. Anything between 47 and 49 is good.
5. Have an assistant cycle the key and measure the voltage during the initial key-on buzz test. Voltage should not drop below 46 volts.
6. Next measure the voltage while cranking the engine. If voltage stays at or above 45-46 volts, the FICM is fine. Abnormally low battery voltage can give a false low FICM voltage reading, so make sure your batteries are good.
The procedure is the same for FICM’s with 7 screws, except that you will be checking voltage at a different screw, as shown in this picture.
New Page 1
If the voltage is above 46 volts in all the tests, your FICM is in excellent condition. If it is between 36 and 45 volts its OK, but not great. If it is between 25 and 35 volts, you have serious FICM problems.
The Following User Says Thank You to outlaw6oh For this addition to TDG:
bigblue777 (11-02-2009)
Old 11-02-2009, 01:08 AM   #6
bigblue777
New Page 1
New Page 1
EXCELLENT Outlaw, and yes, I had previously researched and copied and conducted the FICM test as SWAMPS outlined above! My results were low voltage (approx 8.5-9.03Volts) EXCEPT, when I manually closed the contact on the FICM RELAY at the fuse box on the fenderwell ( I removed the plastic relay cover from the relay to close the contact) I then saw approx. 48.5Volts at the farthest screw to the right on top of the FICM! ...But even still, the injectors never cycled and the engine would not even hint at firing...?
I am coming to understand that the FICM relay is not activating/closing its contact due to the fact the supplied GROUND circuit that is suppose to be provided by pin#27 at the FICM isnt happening...hence, when the key is turned on, there is no main FICM power being supplied to the FICM!
Also, as I understand, pin#27 will measure B+ voltage at FICM connector WHEN CONNECTOR IS DISCONNECTED FROM FICM, but when connected and key is turned on, pin#27 actually becomes a GROUND circuit for the FICM RELAY BY THE FICM ITSELF....
OH ERIC (ID) AND JOHN G...would you Ford geniuses care to help a fellow 6.0 owner out??? lol
Thanks Outlaw, I appreciate your response.
Old 11-02-2009, 02:30 AM   #7
outlaw6oh
outlaw6oh's Avatar
no problem, beyond that you are beyond my smarts. Hopefully one of the 6.0 geniuses will help ya
Old 01-28-2010, 01:56 PM   #8
jeffro22
jeffro22's Avatar
anyone have a picture of which screw to check with the 7 screw version?
2005 F-250 w/ SCT Looney Tune
MRBP 4" TB Exhaust No Cat
AFE Intake
ARP studs / Black HG's
RCD EGR Delete
Amsoil Oil Bypass, Homemade Coolant filter
Trusted Perf. Reg Return Stage 2
jeffro22 is offline   Reply With Quote
Old 01-28-2010, 02:26 PM   #9
hhrecovery
MAFIA #8
hhrecovery's Avatar
Images: 1
Make sure you have all the connectors on the driver side fender plugged in good.
Aaron - 2004 F350 "Offroad Edition"
2003 F250 "Pulling Truck"
hhrecovery is offline   Reply With Quote
Old 01-28-2010, 03:08 PM   #10
jeffro22
jeffro22's Avatar
I will check that.
Also, the screw for the 7 Pin FICM is in the row with 4 screws and is closest one to the center of the motor, if anyoen finds this thread and needs to know
AFE Intake
RCD EGR Delete
Injector Circut Low Codes...FICM??? Bane 2003-2007 6.0L Power Stroke 3 06-19-2009 01:54 PM
injector test shwillis Duramax 2001-2004 (LB7) 8 03-14-2008 03:38 AM
Buzz Test Fast_Ashley 1994-2003 7.3L Power Stroke 4 03-06-2007 04:02 PM
buzz test trpldigit30 1994-2003 7.3L Power Stroke 5 02-19-2007 10:52 AM
Buzz & Contribution test hheynow 1994-2003 7.3L Power Stroke 1 02-24-2006 04:44 AM
