p2266 code - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 6.7L Cummins (2007.5-2011)
Thread Details Posted by dodgefarmer2, this thread has received 12 replies and been viewed 2345 times.
Old 11-01-2009, 10:56 PM   #1
dodgefarmer2
dodgefarmer2's Avatar
p2266 code
had a check eng light. read codes, shows a p2266 which means (water in fuel sensor circuit low) changed oil today, drained fuel filter in clean container and nothing but fuel. any ideas on what it means?
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline   Reply With Quote
Old 11-01-2009, 11:39 PM   #2
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
check the plug on the bottom of the fuel filter. could be time to change fuel filter.
"Only accurate rifles are interesting" -Townsend Whelen
2012 Ram 2500 Crew Cab Big Horn
6.7L 68RFE 4wd
Yeah its stock.
Edge Insight CTS / Line-X / Access Bed Cover
B&W Turnover Ball / Companion Hitch
Pac Brake Air Bags
On Board Air
2010 John Deere 2305
2010 Jeep Wrangler JK Unlimited Rubicon
2015 Keystone Impact 311 Toyhauler
9-11-2001 NEVER FORGET
neeltburn is offline   Reply With Quote
The Following User Says Thank You to neeltburn For this addition to TDG:
dodgefarmer2 (11-01-2009)
Old 11-01-2009, 11:56 PM   #3
dodgefarmer2
14995 miles, maybe its programmed in.
Old 11-02-2009, 04:54 PM   #4
carl76
I have 18,000 miles on mine and I haven't seen this code so I don't think it is a milage thing.
2010 big horn edition
6.7
singles club#202
carl76 is offline   Reply With Quote
The Following User Says Thank You to carl76 For this addition to TDG:
dodgefarmer2 (11-03-2009)
Old 11-03-2009, 12:16 AM   #5
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
You have 18k on one fuel filter...
I wouldn't expect it to be mileage related more fuel...if you get really good clean fuel sure it would go longer but I always change my fuel filter every 10-15k..
Though if I got the water in fuel message I would prolly go ahead and change the filter as well.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Old 11-03-2009, 12:34 AM   #6
Dodgefarmer
Dodgefarmer's Avatar
I have on my 07 6.7 cummins 45,000 miles on the current filter, although its prefiltered at my pumps before being pumped. On some equipment I can get 2000 hrs on a filter and go 2+ yrs. when the manual says change fuel filter every 3-600 hrs. Heck I have John Deere stationary pump motors that have gone ~10,000 hrs. Then again I have a prefilter at the tank and they are 3000 gallon tanks at the pump and get filled at least twice per year at each pump.
Life of the filter depends on clean the fuel is,minimizing the moisture that gets into the fuel.
Remember not to talk bad about farmers with your mouth full!
2013 6.7 CTD 2500, 800 ft-lbs torque, 4x4 crewcab Larmine Longhorn edition, 6 sp. auto, 2 tone white/gold
--07 6.7CTD 2500 4x4, Quad Cab, Big Horn Pkg. 3.73, airbags, 6sp auto, with Mag-Hytec deep pan.- sold but not forgotten.
--08 36' Jazz 5th wheel,triple slide, 12,000lbs
--28' 22,400# PJ goosneck beaver tail trailer
--95 & 96 5.9CTD 4x4 5sp. ext. cab. 33x12.50x16 front, 33x15.50x16 rear tires. R-1 tread, wheelbase shortened 30". Used as tugs on farm
--81 IH 1800, DT466 210hp, 10 speed,
--95 FL70, 8.3 cummins 275hp, 10speed
--79 GMC 7000, DD 6V53 210 hp, 6sp ally
-- A whole bunch farm equipment, all colors
singles club # 198
WALNUT MEMBER #11(workers aganist lazy non-producers united together)
Dodgefarmer is offline   Reply With Quote
Old 11-03-2009, 12:35 PM   #7
carl76
since we are on the subject, I was wondering how hard is the filter to change and how does it come off? I open the drain on the bottom every once in a while to check for water but I can't say that I have ever seen any and the water light has never came on but I still check it. I have been thinking of changing the filter for good measure but I didn't quite figure out how it came off.
6.7
singles club#202
Old 11-03-2009, 02:12 PM   #8
SOOTBANDIT
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
They are a BIOTCH!!!!! to change compared to a 5.9 hard not to get fuel everywhere or maybe i ws really drunk the other night when i changed oil and filters they have new housings out now at the dodge dealerships that you can just buy replaceable filters instead of buying whole housings...but that little burger is $7? and the replacement filters are still kinda high at $35
2011.5 6.7 HO Crew Cab Laramie Dually 4x4 H&S A-1 H11 Studs GDP Pro Gate AFE drop in Isspro EV2 Boost/EBP RDS 90 Aux Tank/Toolbox Combo Reese 20k 5th wheel
2007 2500 6.7 4x4 Handshaker SOLD
Military Quote Of The Year
________________________________
"When I joined the military it was illegal to be homosexual, then it became optional. I'm getting out before it becomes mandatory."
MSGT Harry T. Serres, USAF Ret.
SOOTBANDIT is offline   Reply With Quote
Old 11-03-2009, 11:52 PM   #9
dodgefarmer2
code has disappeared for now. thinking of changing mine at 20,000 at the next oil change. it looks like it could be a pain in the @$$
Old 11-04-2009, 03:58 AM   #10
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
This may help for the fuel filter change..
http://www.thedieselgarage.com/forum...ad.php?t=79980
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
dodgefarmer2 (11-04-2009)
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 02:29 AM
code kc04 6.7L Cummins (2007.5-2011) 3 04-19-2009 03:38 PM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 02:36 PM
what does this code mean fender Duramax 2001-2004 (LB7) 7 06-03-2006 05:33 PM
sct and kam code Adam 2003-2007 6.0 Tuner Forum 13 06-02-2006 08:22 PM
